4 Speed Tranny Question.
#2997512
12/22/21 09:00 AM
12/22/21 09:00 AM
Posts: 2,179 Walton, Indiana
TimS
Walton, Indiana
I’m looking at a 74 Cuda for sale and upon inspection and driving noticed the pistol grip shifter wasn’t quite centered in the hump hole and console. Crawled under the car and confirmed the motor to be #s matching but the tranny case is stamped 68. However it has a dual shifter mount tail shaft like a 70 and up would have. Appears like a 70-up tail shaft has been installed on a 68. But I would have thought if the original one was installed that would have had the correct shifter bracket. Any ideas on this one? When driving, the shifter is so far off center to the rear it hits the console in 2nd and 4th gears.
Thanks.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: 4 Speed Tranny Question.
[Re: TimS]
#2997519
12/22/21 09:50 AM
12/22/21 09:50 AM
Posts: 4,006 South Park, Pa.
68LAR
South Park, Pa.
sounds like it has the wrong mounting plate/bracket. There are different types that shift the shifter foreword or back
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: 68LAR]
#2997520
12/22/21 10:01 AM
12/22/21 10:01 AM
Posts: 10,551 Rittman Ohio
fourgearsavoy
Rittman Ohio
sounds like it has the wrong mounting plate/bracket. There are different types that shift the shifter foreword or back It sounds like they might have an old "Super Shifter" bracket on it and it moved the shifter up and back not for use with console cars. Is it made from steel or aluminum ?
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: cudaman1969]
#2997586
12/22/21 01:29 PM
12/22/21 01:29 PM
TimS
Walton, Indiana
Didn’t they make a different shifter for console and non consoles like other years. My 70 Challenger had non-console was straight up out of the hump offset to driver. I always thought the E body shifters were the same. B body is different. Console shifters bend toward the driver on a B.
[Re: dragon slayer]
#2997638
12/22/21 04:53 PM
12/22/21 04:53 PM
TimS
Walton, Indiana
The housing would be the same other than bearing sizes potentially. So that is not the issue. Was it an original 4 speed car? As others have said, mount. Yes it is an original 4 speed car. At some point in its life something happened to the #s tranny.
[Re: fourgearsavoy]
#2997790
12/23/21 08:32 AM
12/23/21 08:32 AM
TimS
Walton, Indiana
sounds like it has the wrong mounting plate/bracket. There are different types that shift the shifter foreword or back It sounds like they might have an old "Super Shifter" bracket on it and it moved the shifter up and back not for use with console cars. Is it made from steel or aluminum ? Not sure what the bracket is made of. I'll have to check that out. What are the original brackets made of?
[Re: TimS]
#2997845
12/23/21 12:20 PM
12/23/21 12:20 PM
Posts: 25,730 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Factory shifter mounting brackets of that era are cast aluminum, some aftermarket and later factory brackets are stamped steel.
[Re: John_Kunkel]
#2998029
12/23/21 09:35 PM
12/23/21 09:35 PM
fourgearsavoy
Rittman Ohio
Super Shifter mount for E-body This is the one I use and it puts the shifter right against your leg and high next to your hand. Gus
[Re: John_Kunkel]
#2998111
12/24/21 07:04 AM
12/24/21 07:04 AM
TimS
Walton, Indiana
Factory shifter mounting brackets of that era are cast aluminum, some aftermarket and later factory brackets are stamped steel. Looks like the top set. Didn't get close enough to see which one. Not the Super Shifter.
