4 Speed Tranny Question. #2997512
12/22/21 09:00 AM
12/22/21 09:00 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I’m looking at a 74 Cuda for sale and upon inspection and driving noticed the pistol grip shifter wasn’t quite centered in the hump hole and console. Crawled under the car and confirmed the motor to be #s matching but the tranny case is stamped 68. However it has a dual shifter mount tail shaft like a 70 and up would have. Appears like a 70-up tail shaft has been installed on a 68. But I would have thought if the original one was installed that would have had the correct shifter bracket. Any ideas on this one? When driving, the shifter is so far off center to the rear it hits the console in 2nd and 4th gears.
Thanks.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: 4 Speed Tranny Question. [Re: TimS] #2997519
12/22/21 09:50 AM
12/22/21 09:50 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
sounds like it has the wrong mounting plate/bracket. There are different types that shift the shifter foreword or back
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: 4 Speed Tranny Question. [Re: 68LAR] #2997520
12/22/21 10:01 AM
12/22/21 10:01 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
iagree It sounds like they might have an old "Super Shifter" bracket on it and it moved the shifter up and back not for use with console cars. Is it made from steel or aluminum ?
64 Plymouth Savoy
Dana 60
Re: 4 Speed Tranny Question. [Re: fourgearsavoy] #2997538
12/22/21 10:54 AM
12/22/21 10:54 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Didn’t they make a different shifter for console and non consoles like other years. My 70 Challenger had non-console was straight up out of the hump offset to driver.
Re: 4 Speed Tranny Question. [Re: cudaman1969] #2997586
12/22/21 01:29 PM
12/22/21 01:29 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I always thought the E body shifters were the same. B body is different. Console shifters bend toward the driver on a B.
Re: 4 Speed Tranny Question. [Re: TimS] #2997634
12/22/21 04:39 PM
12/22/21 04:39 PM
VA
dragon slayer Offline
VA
The housing would be the same other than bearing sizes potentially. So that is not the issue. Was it an original 4 speed car? As others have said, mount.
Re: 4 Speed Tranny Question. [Re: dragon slayer] #2997638
12/22/21 04:53 PM
12/22/21 04:53 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Yes it is an original 4 speed car. At some point in its life something happened to the #s tranny.
Re: 4 Speed Tranny Question. [Re: fourgearsavoy] #2997790
12/23/21 08:32 AM
12/23/21 08:32 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Not sure what the bracket is made of. I'll have to check that out. What are the original brackets made of?
Re: 4 Speed Tranny Question. [Re: TimS] #2997845
12/23/21 12:20 PM
12/23/21 12:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Factory shifter mounting brackets of that era are cast aluminum, some aftermarket and later factory brackets are stamped steel.
Re: 4 Speed Tranny Question. [Re: John_Kunkel] #2998029
12/23/21 09:35 PM
12/23/21 09:35 PM
Rittman Ohio
Rittman Ohio
Super Shifter mount for E-body
This is the one I use and it puts the shifter right against your leg and high next to your hand.
Gus beer
64 Plymouth Savoy
Dana 60
Re: 4 Speed Tranny Question. [Re: John_Kunkel] #2998111
12/24/21 07:04 AM
12/24/21 07:04 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Looks like the top set. Didn't get close enough to see which one.
Not the Super Shifter.
Re: 4 Speed Tranny Question. [Re: TimS] #2998134
12/24/21 09:42 AM
12/24/21 09:42 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I had the problem years ago in my Cuda. Ended up the motor mounts were off and it moved the motor to the right enough to catch the rubber boot against the opening. An ebody shifter body is the same, it’s the arms that are moves over to the dr side some.
