Re: Rattle can or automotive paint for engine?? [Re: 6PakBee] #2997018
12/20/21 12:29 PM
12/20/21 12:29 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Originally Posted by 6PakBee
Originally Posted by moparmarks
Some more motors.
Any chance of getting the paint codes you use or is it one of those "if you look it's obvious" kind of thing.
For my Street Hemi Orange I had them mix up EV2 without the yellow metallic.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Rattle can or automotive paint for engine?? [Re: moparmarks] #2997057
12/20/21 02:23 PM
12/20/21 02:23 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
Some more motors.
That's exactly what I use in urethane, with or without flattening agent added. up
Re: Rattle can or automotive paint for engine?? [Re: moparmarks] #2997062
12/20/21 02:29 PM
12/20/21 02:29 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Some more motors.
Great information. Thanks for sharing!!!
Re: Rattle can or automotive paint for engine?? [Re: VITC_GTX] #2997145
12/20/21 09:00 PM
12/20/21 09:00 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
All paint no spray cans or guns..stays nice for years and it self levels
https://youtu.be/NI5rdp0R15o
Re: Rattle can or automotive paint for engine?? [Re: moparmarks] #2997249
12/21/21 10:23 AM
12/21/21 10:23 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Some more motors.
up Thanks! If you have any more, keep them coming.
Re: Rattle can or automotive paint for engine?? [Re: 6PakBee] #2997256
12/21/21 11:01 AM
12/21/21 11:01 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
MP Turquoise on the 440....
PPG 3116 enamel without catalyst on the low deck/raw aluminum heads
PPG Shopline 3116 Single stage catalyzed Urethane on the Hemi
3116 was recommended by Steve Dulcich circa 2001, later on I found out it was the
exact formula MP used on crate engines for many years.
TBH I preferred the coverage of the old enamel the PPG store doesn't want to sell anymore, and
will give the Hemi one more coat + will probably clear coat it with some kind of high solids
clear.
When I run out of 3116 I'm probably going to generic/industrial Omaha Orange as used on various municipal
truck applications and so on as it's more easily obtained in enamel and will use a catalyst.....
They all have their ups and downs, it seems I can more easily get a thin, slightly dull OE looking finish with
spray cans than I can with a gun and higher quality paint, but the higher quality paint lasts longer and looks
much better.
Rich H.
Esse Quam Videri
Re: Rattle can or automotive paint for engine?? [Re: ZIPPY] #2997310
12/21/21 02:07 PM
12/21/21 02:07 PM
Falcon, CO
Mad-Max Offline
Mad-Max  Offline
Falcon, CO
I really like and have been using Duplicolor Engine Primer Grey (DE1612) and Cummins Engine Beige (DE1638) - used it on my 440 to gain another 10 lbs of torque grin
- Sam
71 Demon (project): 318, A-833od, 8-3/4, 3.23's
14 Wrangler JKU M-380 "Kilroy" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s
07 Ram 3500 MegaDually 4x4 "Big Mack": 5.9 6BT, G56 'Toy Hauler'
52 Willys M-38 "Poncho"
Re: Rattle can or automotive paint for engine?? [Re: Mad-Max] #2997782
12/23/21 07:58 AM
12/23/21 07:58 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i've done the buy paint and spray it on and rattle can. pro's and cons either way you go. last two i did was plastikote rattle can and it did what i wanted. i'm not sure there's any paint out there that will 100% protect against hot anti-freeze or hot alcohol gas. best bet is to be pro-active with leaks.
Re: Rattle can or automotive paint for engine?? [Re: lewtot184] #2997786
12/23/21 08:17 AM
12/23/21 08:17 AM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
I painted my engine first with Mopar Performance paint and got some gasoline on the intake. The paint started to blister. So I stripped the engine again. Sprayed a 6" panel with the Mopar paint and took it to a PPG paint store, They took a digital picture of the panel and mixed the color with their industrial paint mixture. Reduced and hardened required. The color was perfect to the panel, and nothing effects the color; gas or oil. Got it all for $90 with enough for two engines.
Re: Rattle can or automotive paint for engine?? [Re: maximus] #2997819
12/23/21 10:54 AM
12/23/21 10:54 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
All mine are single stage urethane out of a gun. Have some that have been painted nearly 20 years and look new. Just did my race car block and heads. The small block was done in 2003
Doug
Re: Rattle can or automotive paint for engine?? [Re: dvw] #2997830
12/23/21 11:28 AM
12/23/21 11:28 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
All my engines are painted with Dupicolor Hemi orange engine enamel. I hit them with light coat of self etching primer first. Then spray orange. No complaints. My Charger 440 Six Pack engine has been in since 2007 and the Challenger Hemi since since 2017. Roached Runner 383 engine is no installed also.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Rattle can or automotive paint for engine?? [Re: 6PKRTSE] #2998169
12/24/21 11:41 AM
12/24/21 11:41 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Great subject and Happy Christmas.
I only see one engine paint available for us Limeys!
VHT enamel.
I always put it straight to metal, and a lifetime later I find they have hi temp primer...
It also says “cure at 200 degrees for twenty minutes or run engine”
That would explain why it never lasted lol... violin
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: Rattle can or automotive paint for engine?? [Re: Gtxxjon] #2998226
12/24/21 03:10 PM
12/24/21 03:10 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
I’ve always used duplicolor engine enamel.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Rattle can or automotive paint for engine?? [Re: mopardude318] #2998271
12/24/21 07:44 PM
12/24/21 07:44 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Where did you get that B&M super charger?
Abe Lincoln
Re: Rattle can or automotive paint for engine?? [Re: dart4forte] #2998282
12/24/21 09:26 PM
12/24/21 09:26 PM
Gilroy,CA.
Gilroy,CA.
I found that 8 years ago on Craig’s list NOS complete, B&M cast the manifold. I will be going with a 671 in the summer time. This little 162 runs out of steam on my 408.
Re: Rattle can or automotive paint for engine?? [Re: mopardude318] #2998300
12/24/21 11:55 PM
12/24/21 11:55 PM
Livonia,MI
1968fury Offline
1968fury  Offline
Livonia,MI
Bill hirsch paint is amazing. gas resistant I've sprayed it or used a foam brush on cast iron.
71 scamp 340 509 cam 456 gear,68 fury1 318 3spd on the tree,50 merc flathead 3x2 3spd w/overdrive
Re: Rattle can or automotive paint for engine?? [Re: 1968fury] #2998304
12/25/21 12:46 AM
12/25/21 12:46 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You don’t need high temp paint. Normal car urethane will standup to anything. You can even bondo up parts to make them smooth. Notice the missing Indy logo on the head and valve cover. No pits in the intake. Yup it’s bondo, 9 years and counting.
Doug
