It would be a lot simpler if the idiots that built this place had taken up the local utility company on their offer when they ran the gas lines through the area. I've been told by the neighbors they offered to run the line for free if you signed a contract to have at least
ONE gas appliance for 10 years. that was a no brainer IMO. The biggest hog is the heat pump/AC unit.
I may give them a call to see if there is any current "deal". The way the property is laid out, aesthetically it's going to be enough of a challenge to locate a unit much less a Propane tank. I'm assuming they need reasonable access to fill it
![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
In addition, not sure how fond the driveway would be of a loaded propane truck
Just a side note, we're a good 700 ft off the street. thanks for all the comments and suggestion so far.
![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
