Back up generators? Thoughts, Experiences ??
#2996368
12/18/21 10:59 AM
12/18/21 10:59 AM
Posts: 15,291 Omaha Ne
TJP
Omaha Ne
I am contemplating looking into a back up power source for the house as we are all electric. So where else does one go to get straight (mostly LOL) no BS answers, MOPARTS. I have talked with a few people over the years that have had them and if I recall correctly most said they were a BIG PITA. Due to several outages a year, some that go for 18 hours to 4.5 days (worst one). Most are less than 12 or so hours, but the longer ones are a real PITA. Unfortunately we do not have natural gas and due to our distance from the line it would likely be cost prohibitive coupled with the cost of the generator. So that leaves propane, don't really want a 100+ gallon tank and I'm not really sure where I could place it out of sight but still be accessible for filling So next would be diesel or gas. Realizing that both would require numerous trips to for fuel, my thought was to possibly drain the unused fuel before it went stale and use it in the tractors or cars. Diesel is more efficient but we use less of it through the year. My last Idea was a 3 point generator to run off the tractor itself. It's the cheapest but will likely require frequent fill ups and I'm not sure about having it outside in cra--y weather and running nonstop for days at a time Would really be nice if they would come through and just bury the flippin lines but that's not likely to happen unless somebody like Warren Buffet moves nearby Any comments, ideas, suggestions are appreciated
Re: Back up generators? Thoughts, Experiences ??
[Re: TJP]
#2996400
12/18/21 12:01 PM
12/18/21 12:01 PM
Posts: 22,695 Bitopia
jcc
Bitopia
This may not apply to OP, but others should always consider these seldom noted aspects, any high water will kill a Genset, most enclosures are not rated for high hurricane winds, gasolene powered for more than a day is expensive and very inconvenient, most gensets fail over time from lack of use, automatic transfer switches vs manual are an ,expensive another item to fail at the worst time, utility supplied NG lines are often disrupted in high wind events from uprooted trees, diesel fuel has a limited "shelf life" but is the cheapest long use fuel IMO, and the luxury/cost of running a full house on a properly sized genset is in most cases a waste of money and mainly for bragging rights, .
[Re: TJP]
#2996417
12/18/21 12:32 PM
12/18/21 12:32 PM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Budget? Well I'm not a Rockefeller, or related to Walter Scott but don't want constant issues with maintenance etc. 5K +/- 5 k should get you there EZ with a good USED RV gen .... My buds house is on 12 foot pilings .... I think he’s setting the gen set up 10 foot high.
[Re: TJP]
#2996429
12/18/21 01:11 PM
12/18/21 01:11 PM
Posts: 25,743 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you want a full backup with heat and A/C, you'll probably need at least a 20KW unit.
[Re: dOc !]
#2996541
12/18/21 07:24 PM
12/18/21 07:24 PM
Posts: 3,426 Dandridge TN
Dabee
Dandridge TN
daBeez ... isn’t a Generac a bit loud ? No can’t hear it In the house
[Re: Dabee]
#2996549
12/18/21 07:52 PM
12/18/21 07:52 PM
Posts: 1,593 USA
VS29H0B
USA
Generac propane system has been in place for more than 10 years - works great - not that loud and as previously stated not heard in the house.
Like the women I have dated --- Always looking for a better deal ....
[Re: Andrewh]
#2996604
12/18/21 10:55 PM
12/18/21 10:55 PM
TJP
Omaha Ne
thanks for all the replies The outages are year round it's just the Wife and I but I'm getting a bit tired of freezing my butt off, or sweating it off. Last summer we lost the food, which wasn't that big of a deal, it's more to do with no internet, TV, lights, hot water as well as other inconveniences. Might be a bit of the age thing as well. The last time I looked into having them run a NG line up it was pretty pricey but its worth another call, all's they can do is laugh the backsides off Any one else with input good or bad is appreciated
[Re: Powerflow]
#2996624
12/19/21 12:38 AM
12/19/21 12:38 AM
Posts: 1,151 Cruising!
QuickDodge
Cruising!
A few years back, we had a power outage that affected a large area around our home. The majority of people in several counties lost power. That power outage was unusually long, lasting 11 days. Some people had to wait over 2 weeks to have their power restored. At the time, I was using a gasoline powered generator. Unfortunately, most of the gas stations did not have power. The few stations that were open sold all their gasoline in a short amount of time. So buying gasoline required driving an hour away from home!! (And then waiting in line to buy it!!!) Every two days, I had to spend two hours of driving time just getting fuel for the generator. By the time I started looking for some extra gas cans to purchase, there were none to be found!!
Second thought, during that power outage, a LOT of generators were stolen. Having the generator well secured would be very wise.
Edit: The amount of noise that is acceptable varies from one person to the next. I would suggest, at the minimum, locating the generator away from one's bedroom!
[Re: TJP]
#2996629
12/19/21 01:02 AM
12/19/21 01:02 AM
Posts: 3,041 N.W. Florida
Fat_Mike
N.W. Florida
Disregard what everyone else said (I didn't read it either). EDIT What's your goal? Keep your food cold, keep your @$$ warm, keep your lights on, etc... You can keep your food from going bad with a small generator and a couple extension cords. Opt for something larger based on your needs.
[Re: Fat_Mike]
#2996638
12/19/21 01:53 AM
12/19/21 01:53 AM
Posts: 10,198 Someplace you aren't
SomeCarGuy
I moved to an area served by Duke energy. Never before in my life have I had to deal with outages on a regular basis. It’s totally ridiculous how often we deal with this, in the suburbs of a big city no less. I even moved a few streets away to a neighborhood with BURIED utilities, only to find out they are sent power via the same crappy lines as before, no main feed that is more secure. It’s just unbelievable.
Will be made much worse with the coming of the electric cars I’m sure.
My solution so far has been a Yamaha 2000 watt rig from Costco. Cost like 550 about three years ago when we finally had enough and at least wanted to keep the fridge on. I bought a good heavy cord and this gets us by for the most of a day we are left hanging usually. Just depends on what you want to do.
IIRC a 5k budget won’t get you anything near the juice to run a whole house, at least not a new setup. Trying to think what it cost when I looked about three years ago and I want to think it was more like 8k. As much as it sucks, it would only be worth it if the power is down for several days. You have to keep that jewel up. So far all I’ve done is fire up the little guy a couple times a year and it’s been flawless at running the fridge and then the freezer switching it as needed.
I want my fair share
