How fast have you been with a standard stroke 383? #2995770
12/16/21 11:15 AM
12/16/21 11:15 AM
USA
hudsonhornet7x Offline OP
USA
Have fast have you been with a standard stroke 383?
What heads and cam did you use?
What car was it in?
The 383 never gets much credit but I have always admired them. So let's hear some success stories.
Re: How fast have you been with a standard stroke 383? [Re: hudsonhornet7x] #2995798
12/16/21 12:39 PM
12/16/21 12:39 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
People have run in the 9’s with them in SS.
My heap has only been able to muster an 11.18@123 at 3550lbs running unported 906’s, RPM intake and SFT cam.
Re: How fast have you been with a standard stroke 383? [Re: fast68plymouth] #2995847
12/16/21 03:54 PM
12/16/21 03:54 PM
CA
jung Offline
jung  Offline
CA
That's mega!
Re: How fast have you been with a standard stroke 383? [Re: fast68plymouth] #2995939
12/16/21 09:13 PM
12/16/21 09:13 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Thats not bad for a 383 @3550 lbs. What were the 60'?
consider this a bump i have a 383 that i would like to put in something one day.
Re: How fast have you been with a standard stroke 383? [Re: hudsonhornet7x] #2995948
12/16/21 09:42 PM
12/16/21 09:42 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Due to the large chamber, short stroke and large rod ratio, the charge motion, vacuum, etc. near TDC is unlike larger engines.
I'll bet the cam should look different as o I/E bias, OL, LSA.
Boffin Emeritus
Re: How fast have you been with a standard stroke 383? [Re: polyspheric] #2996053
12/17/21 10:08 AM
12/17/21 10:08 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Been so long since he's posted but, Hutch is running respectable with his '383' crank motor.
Re: How fast have you been with a standard stroke 383? [Re: hudsonhornet7x] #2996057
12/17/21 10:18 AM
12/17/21 10:18 AM
Idaho
LaRoy Engines Offline
Idaho
150.246 mph. But that was at Bonneville in 1959 with a 361 in a '59 Plymouth. Does that count?
Re: How fast have you been with a standard stroke 383? [Re: fast68plymouth] #2996094
12/17/21 12:08 PM
12/17/21 12:08 PM
So. Burlington, Vt.
So. Burlington, Vt.
There have been quite a few 383 powered NHRA Stockers that get into the 10’s pretty regularly.
Those are way more impressive than my heap running 11’s with a cam that has .100” more lift, a big carb, and an aftermarket intake manifold.
Re: How fast have you been with a standard stroke 383? [Re: fast68plymouth] #2996104
12/17/21 12:28 PM
12/17/21 12:28 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
What are these quicker 383 engines revving to?
Not a real accurate comparison here but the basically factory original, stock stroke 383 with a factory "335 hp" hydraulic cam in my Coronet won't go much beyond 4,500 rpm. shruggy
'71 Duster
'17 Ram 1500
Re: How fast have you been with a standard stroke 383? [Re: RMCHRGR] #2996112
12/17/21 12:53 PM
12/17/21 12:53 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Likely rpm limited by the hydraulic lifters and the way they pump up at that rpm and hold valves off the seat. I have used hydraulic cams that required adjusting them out to .006 using a feeler gauge. That did away with any possibility of pump up.
Re: How fast have you been with a standard stroke 383? [Re: John Brown] #2996149
12/17/21 02:29 PM
12/17/21 02:29 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Did the same with mine, zero lash (when pushrod stopped turning lock it down), 6800 easy with a .509 cam 11.60s @ 118 in a Duster street hemi converter.
Re: How fast have you been with a standard stroke 383? [Re: RMCHRGR] #2996204
12/17/21 05:45 PM
12/17/21 05:45 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The cam does not limit RPM, only power. With enough spring you can blow it up.
Boffin Emeritus
Re: How fast have you been with a standard stroke 383? [Re: polyspheric] #2996209
12/17/21 06:22 PM
12/17/21 06:22 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I had 1.5” triple springs off a E Modified small block
Re: How fast have you been with a standard stroke 383? [Re: LaRoy Engines] #2996234
12/17/21 07:54 PM
12/17/21 07:54 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Close enough!!! bow thumbs
Kevin
Re: How fast have you been with a standard stroke 383? [Re: Twostick] #2996404
12/18/21 12:11 PM
12/18/21 12:11 PM
UK
rb446 Offline
rb446  Offline
UK
I'm sure you guys remember the SS/IA Rod Shop Dodge now running here in UK, I saw it run a best of 10.2 in 2020 he blew the 7500rpm+ 383 motor so now has a Hemi in it.
https://duckduckgo.com/?q=rod+shop+dodge+challenger+launch+at+santa+pod&t=chromentp&iar=images&iax=images&ia=images&iai=https%3A%2F%2Fsantapod.co.uk%2Fimages%2Fdrivers2018%2FDuncanWattsm.jpg
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: How fast have you been with a standard stroke 383? [Re: rb446] #2996824
12/19/21 08:56 PM
12/19/21 08:56 PM
I think I remember Dave Wren running in the 9.80s back a long time ago with his 1971 Cuda 383 SS/I car in the mid 1970s boogie
If I'm remembering correctly he let the clutch out at 8800 RPM and shifted it around 8200 RPM shock shruggyThat motor was a unbored 400 block given to him by the Mopar factory drag engineers that they had built and flogged a bunch on the dyno before giving it to him to race to outrun the 350 Chevy in that class: devil:
Re: How fast have you been with a standard stroke 383? [Re: Cab_Burge] #2996886
12/19/21 11:26 PM
12/19/21 11:26 PM
Ontario Canada
Hutch Offline
Hutch  Offline
Ontario Canada
My car is a 3100 lb 69 Roadrunner and has been as fast as 9.87@137 mph. It's a 1964 block bored 4.310 stage VI early straight plug heads 2.14, 1.81 valves, long connecting rods, 11:1 compression and a DC 590 camshaft 5 degrees retarded . I shift normally at 7800 and it runs 10.00 at 134 to 135. When I beat it up a bit and shift at 8400 it has run its best numbers. Did break a Jesel belt a few years ago and buggered up my heads and it's been a turd running 10.20's ever since. Hoping to get everything back on track this winter.
Hutch
Re: How fast have you been with a standard stroke 383? [Re: Hutch] #2996965
12/20/21 09:46 AM
12/20/21 09:46 AM
Johnstown
69dart Offline
69dart  Offline
Johnstown
My roadster has been 9.60's and 5.80's in the 1/8th getting flogged several hundred laps a year.
It only weighs around 2100 with me. Its been a pretty solid combo. I have 2 engines and both shortblocks are the same. Stock crank, eagle rods, TRW (boat anchor) dome pistons.
I have tried lots of cams, intakes, spacers, and carbs trying to find the fastest/most consistent combo. I like the baby solid rollers, I have tired bigger cams but they didnt show any gains.
I want to throw some hose at it and see if it will run 5.50's.
Thinking I may drop a stroker crank in one of them on the next freshen in another 1000 runs or so.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: How fast have you been with a standard stroke 383? [Re: 69dart] #2996978
12/20/21 10:25 AM
12/20/21 10:25 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
There was a time in the 80’s and 90’s, folks would prefer a 383 engine.
I guess they were ‘cheap and cheerful’ and plenty around, even in the UK.
My first experience of Street driven Mopar 383 ‘drag cars’ in the early 80’s, was they ran quick!
Before Aluminium heads and only purple shaft cams, they was King... penguin
The 906 head was the ‘bees knees’ back then and strokers were unheard of.
Then the 90’s came and folks were running into the tens with iron head 440’s.
My old iron headed 452 actually ran into the nines with no NOS.
The best 383 I ever remembered was Steve Case’s, plum crazy Challenger.
Street driven TEN second car and a real R/T too...
Been around forever and still doing it large with a 383ci lol... drive
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: How fast have you been with a standard stroke 383? [Re: Gtxxjon] #2996983
12/20/21 10:37 AM
12/20/21 10:37 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
There was a fantastic 383ci engine article in an old Mopar book, ''Musclecar and Hi-Po engines''
Chrysler themselves got Victor Edelbrock to do a 'Hotrod' article on a NEW factory 383ci engine in 1967!
They had been hearing of ‘bad press’ for the 335hp ‘383ci’ so 'MOTHER MOPAR' wanted to put the record straight lol.
On the Dyno, a brand new low mileage 383ci made only 280 horses... fan
So with lots of machine work and the right camshaft, they got it up to 420 horses. drumhit
The article does not say which heads were used 516 or 915 (440) heads?
The biggest problem being was 'factory over-tight' clearances.
''Freeing the horsepower'' was just more piston to wall and bearing gaps, worth 100hp... drinking
