Anyone have a Sciatica ? #2996056
12/17/21 10:16 AM
12/17/21 10:16 AM
Penna
70satelliteguy Offline OP
Penna
Mostly a problem when I drive for more than 1/2 hour. How long did yours last. They say it usually goes away after 6-8 weeks on it's own but stretching exercies help.
Thank's Mike
Re: Anyone have a Sciatica ? [Re: 70satelliteguy] #2996062
12/17/21 10:31 AM
12/17/21 10:31 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
I had a back surgery 25 years ago and live with varying levels of this as well as regular flair ups and remedies. Stretching is mandatory, just remember that when it subsides it’s not time to stop the stretches (human nature I suppose, pain goes away and I don’t like to stretch), and if the pain is constant (during a flair up) you can alternate heat and ice, use a TENS unit (electro stim to force the muscles to relax), and ibuprofen. During flair ups it’s almost impossible to stretch, and you need to be far more careful doing so.
Good luck
Re: Anyone have a Sciatica ? [Re: AAR#2] #2996087
12/17/21 11:37 AM
12/17/21 11:37 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I fight back pain all the time
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Anyone have a Sciatica ? [Re: 70satelliteguy] #2996107
12/17/21 12:39 PM
12/17/21 12:39 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Everything AAR#2 said, but I'd add a couple things:
Ibuprofen is horrible for you, although it works well for inflammation. I'm not saying "don't use it" but I prefer to use natural anti-inflammatories such as curcumin.
Start taking good calcium and collagen to maintain your bone and joint health.
Most importantly, once your pain goes away, do an internet search for "core strengthening exercises" and get your core muscles strengthened up.
If you don't do something now, your situation will only get worse. twocents
Re: Anyone have a Sciatica ? [Re: Fat_Mike] #2996186
12/17/21 04:53 PM
12/17/21 04:53 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Is that GM product ?? Nah. must be a VW 'cause its a pain in the azz !!
Re: Anyone have a Sciatica ? [Re: Stanton] #2996189
12/17/21 05:06 PM
12/17/21 05:06 PM
K
Kiddart Offline
Kiddart  Offline
K
look into a entry level Yoga class at your local YMCA. it really helps, gets and keeps you in the routine of stretching
Thank you
Kiddart
Re: Anyone have a Sciatica ? [Re: Stanton] #2996206
12/17/21 05:53 PM
12/17/21 05:53 PM
Penna
Penna
"Ibuprofen is horrible for you"
It does help quite a bit for me but I know it can ruin your kidneys if you take too much of it or for too long. I'm several weeks into this and hoping it just goes away. Is steroid injection and option anyone has tried?
Mike
Re: Anyone have a Sciatica ? [Re: 70satelliteguy] #2996214
12/17/21 06:35 PM
12/17/21 06:35 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Sciatica is something that comes and goes. It seems to come on with certain weather, sitting for a long time, standing for a long time, lifting stuff, etc, etc.. I used to take Ibuprofin but can't now because of other medication but I can take Tylenol and it works well. I only take it if I'm going to be driving for extended periods. Otherwise I just deal with it - stretching, changing positions, whining, etc. I go to a back quack once a month but I don't think that does much good.
Re: Anyone have a Sciatica ? [Re: 70satelliteguy] #2996215
12/17/21 06:40 PM
12/17/21 06:40 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Mike
Steroid injections work for some, not for me, and why I ended up under a knife. Yes ibufrofen can be bad with regular usage so I do everything I can to stay off them, but sometimes it gets you over a bad flair up. I should have mentioned the core exercises as mentioned above, and of course if you are carrying extra weight losing it will help too.
Bottom line is it’s work, and never completely in the clear it seems for those that experience it
Edited to send a shout out to the gal that has helped keep me from the operating room, a good deep tissue massage therapist can help as well.
Re: Anyone have a Sciatica ? [Re: AAR#2] #2996221
12/17/21 07:17 PM
12/17/21 07:17 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I got it, nothing helps like hanging upside down on my perversion table for 5 minutes.
Re: Anyone have a Sciatica ? [Re: HotRodDave] #2996241
12/17/21 08:08 PM
12/17/21 08:08 PM
Penna
Penna
From what I understand since my symptoms are just a nerve pain from my hip to my knee JUST when seated, I probably just have to keep stretching the Piliformis muscle in my butt to alleviate my pain. Fine at all other times.
"I got it, nothing helps like hanging upside down on my perversion table for 5 minutes"
I don't think my wife would let me do anything perverted Dave!!!
Mike
Re: Anyone have a Sciatica ? [Re: 70satelliteguy] #2996247
12/17/21 08:19 PM
12/17/21 08:19 PM
S E Michigan
E
ekim Offline
ekim  Offline
E
S E Michigan
hr dave tell us more about hanging on your board.
how long have you been using one? did your dr recommend it? im 6ft 3 and 240 lbs, what is the weight limit?
Re: Anyone have a Sciatica ? [Re: 70satelliteguy] #2996379
12/18/21 11:26 AM
12/18/21 11:26 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
[quote=70satelliteguy]From what I understand since my symptoms are just a nerve pain from my hip to my knee JUST when seated, I probably just have to keep stretching the Piliformis muscle in my butt to alleviate my pain. Fine at all other times.
I had that , lucky a guy at work had just gone thru knee surgery and he had this little cooler / pump thing .. put ice in it and has a bag you strap on the part that hurts .. it would make the pain co away
Re: Anyone have a Sciatica ? [Re: ekim] #2996405
12/18/21 12:14 PM
12/18/21 12:14 PM
IMGTX Offline
IMGTX  Offline
I have one. Use it a lot when I can. My Doctor didn't recommend it but when I mentioned it he said it wouldn't hurt and could help. For me it was a big help.
My board is good for 350 lbs and wasn't too expensive. Approx $200 a few years back.
It needs to be adjustable for your height and I prefer the locking pin as opposed to the strap to limit rotation.
Start small at 15 to 20 degrees and move up over time to where you think it is comfortable. I can do full 90 degree inversion and drink a bottle of water while playing games on my cell phone. The wife thinks I am weird. I think hangin upside down drinking at keg parties was good training. Who says all those crazy days were wasted time.
After you hang for a while and are ready to get up put the board at a level position and lay there for a while. It kinda lets your body relax with the stretch. I will often get off the board and take a nap to keep the load off my back for a bit and it helps the effect last longer.
I can't do sit ups because of the pressure it puts on my spine but I can do crunches while hanging upside down.
Re: Anyone have a Sciatica ? [Re: 70satelliteguy] #2996409
12/18/21 12:20 PM
12/18/21 12:20 PM
IMGTX Offline
IMGTX  Offline
Thank's Mike
I can't drive either of my trucks for more than an 1/2 hour BUT I can drive my Stealth which has lumbar supports for 6 to 8 hours with no problem. If you can't drive something with better support get a lumbar pad. I have 2 and use one at the office on occasion and one on trips when I can't use my car.
It may help.
Re: Anyone have a Sciatica ? [Re: IMGTX] #2997434
12/21/21 09:31 PM
12/21/21 09:31 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Almost the exact same story right down to my wife making fun of me for those things he mentioned here butt I got mine at salvation army for $50 and my chiropractor recommended it and the doctor said to not to...
Mine is a "teeters hang up" the only thing I can find about weight limit is a sticker that says "do not use setting A for users over 220#"
Also there is nothing to exactly limit the rotation on mine, my weight and the geometry of it keeps it from going quite straight up and down unless I use my arms on the floor to "walk" myself all the way upside down and even then just past center it will hit a bar, you don't really need to go all the way vertical upside down.
I am surprised how often I see them at yard sales and such for cheap, they must not work for everyone butt I love mine.
Re: Anyone have a Sciatica ? [Re: HotRodDave] #2997439
12/21/21 09:46 PM
12/21/21 09:46 PM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
You guys dont do the oddball stretches to "floss" your nerves? It works well for me.
https://www.spineuniverse.com/conditions/sciatica/nerve-flossing-sciatica
Better vids then this is you look or them, I lay on my stomach and reach back and grab the front of my foot one at a time or both and look like im doing things a duck does.
STOP POTATO HATE!
Re: Anyone have a Sciatica ? [Re: HotRodDave] #2997940
12/23/21 04:56 PM
12/23/21 04:56 PM
robertop Offline
robertop  Offline
And where did you buy your "perversion" table? Let me know, I could use something like that, but I also would need a helper...
Re: Anyone have a Sciatica ? [Re: robertop] #2998182
12/24/21 12:17 PM
12/24/21 12:17 PM
moparx Offline
moparx  Offline
and what kind of "uniform" would your helper be wearing ? whistling apimp devil punkrocka biggrin
beer
Re: Anyone have a Sciatica ? [Re: moparx] #3000359
12/31/21 04:18 PM
12/31/21 04:18 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
I have a mild case of it. Mine virtually went away while I was convalescing from COVID and my heart attack. I was doingIbu as well, maybe 1/2 pill a day. But now I can’t take it. Find a massage therapist.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
