Re: pinion angle
[Re: DoubleD]
#2995360
12/14/21 08:11 PM
12/14/21 08:11 PM
Posts: 17,843 S.E. Michigan
ZIPPY
S.E. Michigan
AND ….. here we go , ! ! ! would not be a complete year without the annual pinion angle argument and discussion post ! Some things never change
Rich H.
Esse Quam Videri
Re: pinion angle
[Re: SCATPACK 1]
#2995400
12/14/21 11:50 PM
12/14/21 11:50 PM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Question If u set pinion angle with a set of 28 inch tall tires and then switch to 30 inch tall tires, what does this taller tire do to pinion angle Nothing, unless you raise or lower the housing in the car at the same time.
Re: pinion angle
[Re: tubtar]
#2995559
12/15/21 05:14 PM
12/15/21 05:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Question If u set pinion angle with a set of 28 inch tall tires and then switch to 30 inch tall tires, what does this taller tire do to pinion angle Makes them higher off the ground ? It doesnt do anything to the pinion angle but it does tilt the whole car more.. puts more weight on the front end and most likely to cause you to spin more
Re: pinion angle
[Re: CMcAllister]
#2995568
12/15/21 05:45 PM
12/15/21 05:45 PM
Posts: 4,714 Moved to N.E. Tennessee
GomangoCuda
I need to make a set of these. I have a bunch of 2x4 cut offs I can use up. I might attach plywood around the outside to eliminate any chance of the wobleeze. Is that a word?
