Re: pinion angle [Re: DoubleD] #2995360
12/14/21 08:11 PM
12/14/21 08:11 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Originally Posted by DoubleD
Originally Posted by n20mstr
AND ….. here we go , ! ! !
wrench
would not be a complete year without the annual pinion angle argument and discussion post !
Some things never change wink
Rich H.
Esse Quam Videri
Re: pinion angle [Re: SCATPACK 1] #2995400
12/14/21 11:50 PM
12/14/21 11:50 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted by SCATPACK 1
Question
If u set pinion angle with a set of 28 inch tall tires and then switch to 30 inch tall tires, what does this taller tire do to pinion angle
Nothing, unless you raise or lower the housing in the car at the same time.
Re: pinion angle [Re: tubtar] #2995559
12/15/21 05:14 PM
12/15/21 05:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Question
Makes them higher off the ground ?
It doesnt do anything to the pinion angle but it does tilt the whole car more.. puts more weight on the front
end and most likely to cause you to spin more
wave
Re: pinion angle [Re: CMcAllister] #2995568
12/15/21 05:45 PM
12/15/21 05:45 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Originally Posted by CMcAllister
Easy. Cheap. Works.
I need to make a set of these. I have a bunch of 2x4 cut offs I can use up. I might attach plywood around the outside to eliminate any chance of the wobleeze. Is that a word? wave
Re: pinion angle [Re: GomangoCuda] #2995598
12/15/21 06:51 PM
12/15/21 06:51 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Mine, about 25 years old, 1” plywood sides 3/4” top
