Re: Throw-out Bearing Recommendation - 23-Spline
[Re: floyd]
#2994570
12/12/21 11:22 AM
12/12/21 11:22 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
When I put in my Center Force like 20 years ago the bearing that came with it went bad quick.Got lucky and my buddy at AZ had an old Timken that had sat for years.Been in since like 03 and no problems.IIRC Summit still carrys some decent ones Rocky
Chrysler Firepower
[Re: floyd]
#2994580
12/12/21 11:40 AM
12/12/21 11:40 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I've had bad luck with the TO bearings in the last few years. All made in China, which can be generally hit and miss, but they all use the cheapest grease known to man in them, which I think is the problem with the ones I had trouble with. Several lasted only a few thousand miles, and were verifiabilly, fully retracted when not being used. Try Brewer's.
I ended up going with a hydraulic unit from American Powertrain, which is amazing.
If you are able to swap out the old bearing with one from National or King Bearing, you would be money ahead.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2994585
12/12/21 11:53 AM
12/12/21 11:53 AM
Posts: 10,702 North Dakota
6PakBee
North Dakota
I can't find a listing for King throwout bearings. Is it listed as something else?
[Re: floyd]
#2994586
12/12/21 11:54 AM
12/12/21 11:54 AM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
Can't help you on manufacture but in case you didn't know, the bearing assembly needs to jive with your pressure plate choice. Diaphragm, Borg and Beck[ what our cars came with] and Long[ what Ford used] all take different overall length units. The Long style does not work with stock flywheels so most likely you don't have that but some aftermarket wheels can come drilled for it. The other two have the same bolt pattern. Whose cloth unit are you using? Maybe source from them?
Carl Kessel
[Re: Dan Brewer]
#2994865
12/13/21 10:20 AM
12/13/21 10:20 AM
Posts: 4,114 MD
floyd
MD
[Re: floyd]
#2994872
12/13/21 10:42 AM
12/13/21 10:42 AM
Posts: 766 Ohio
Dan Brewer
Ohio
[Re: 6PakBee]
#2994914
12/13/21 01:53 PM
12/13/21 01:53 PM
jbc426
West Coast, USA
I can't find a listing for King throwout bearings. Is it listed as something else? https://www.kingbearings.com/
[Re: Sniper]
#2996019
12/17/21 07:42 AM
12/17/21 07:42 AM
jbc426
West Coast, USA
maybe called a release bearing ? maybe because they sell engine bearings, not throwout bearings? My bad. They don't carry roller bearings at all. SKS and other roller bearing manufacturers carriy the replacement double sealed replacement bearing.
