This worked good after the fact.
Could also file this under not enough for 700ish HP either
One of the first 400 block stroker pump gas motors I built was thinner (.035
) than that piece is after boring it to 4.375 bore size
The owner had it sonic tested by a shop close to where he lived, and he said they told him it was fine
That block cracked the #1 cylinder wall on the cam side after 3 pulls, it made 489 HP at 5500 RPM on the second pull
The whole side of that block was junk, I had a decent shop try to sleeve all four cylinders on the driver side, but it would't take, seal up, the sleeves
That was a 1976 block.
