Moroso gold valve covers #2992551
12/06/21 01:02 PM
12/06/21 01:02 PM
White House,TN
stroked470 Online content OP
stroked470  Online Content OP
White House,TN
I am getting ready to install a set of Moroso Gold valve covers on my 440. What are my options to hook up a PCV or other crankcase evacuation without installing some sort of baffle. I know a PCV will pull oil out with no baffle in them.
Re: Moroso gold valve covers [Re: stroked470] #2992561
12/06/21 01:44 PM
12/06/21 01:44 PM
Missouri
randavis Offline
randavis  Offline
Missouri
You could use valve cover spacers, but they are pricey. Medice Mfg makes them. I have a set on my 511 RB with the old cast aluminum M/T valve covers which have baffels in both sides.
I run the Hughes aluminum roler tip rockers on a Comp cam with .595 lift and have plenty of clearance.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: Moroso gold valve covers [Re: randavis] #2992577
12/06/21 02:06 PM
12/06/21 02:06 PM
moparx Offline
moparx  Offline
maybe use one of those oil vapor catch cans intended for new engines plumbed inline with the PVC ?
beer
Re: Moroso gold valve covers [Re: moparx] #2992607
12/06/21 04:23 PM
12/06/21 04:23 PM
White House,TN
White House,TN
I didnt even think about a catch can. Ill look at some.
Re: Moroso gold valve covers [Re: stroked470] #2992635
12/06/21 05:35 PM
12/06/21 05:35 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
I used some of the grommets that I had to cut a hole in for the breather and I didn't cut a large enough hole. crankcase pressure built up and I ended up with oil all over my motor after cruising on the highway (the dipstick spewed).
I started thinking about the old chrome Moroso covers I might use on a big block, no baffles.
I might see if I can fab something like this...
https://www.summitracing.com/parts/...VLTNWx0te1BTMbmrw-mdcYrQizRoC8y8QAvD_BwE
Re: Moroso gold valve covers [Re: krautrock] #2992826
12/07/21 10:18 AM
12/07/21 10:18 AM
White House,TN
White House,TN
years ago i had a 470 with Indy 440-1 heads and used there valve covers. There were no baffles in them so i used epoxy and stuck a set of Moroso baffles in them so i could use the exhaust evac setup. I never had any problems but i dont think i want to rely on epoxy on a street car.
Re: Moroso gold valve covers [Re: stroked470] #2993096
12/08/21 01:38 AM
12/08/21 01:38 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Run a Chrysler style baffled breather with a good amount of steel/baffling in it (the Moroso screw on type are great) and then run a GM type (straight) PCV in line to the carb.
Re: Moroso gold valve covers [Re: GTX MATT] #2993115
12/08/21 07:08 AM
12/08/21 07:08 AM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
Those valve covers look great but warp easily if over torqued even the slightest. Go lightly on the bolt tightening.
drive
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
Re: Moroso gold valve covers [Re: B Dartman] #2994308
12/11/21 12:20 PM
12/11/21 12:20 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
I agree what I did to remedy this prob was to siliconed in some billet 3/8 valve cover spacers, not only do they look great but they seal like billet valve covers now
