Re: lost cam lobe on break in twice
[Re: RapidRobert]
#299229
04/26/09 11:23 AM
04/26/09 11:23 AM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
My MP509 just went flat as well, in addition to 4 lifters being collapsed
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: rusthole]
#299230
04/26/09 11:52 AM
04/26/09 11:52 AM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
Are you following proper break in procedure by getting the engine up to enough RPM right away for breakin of the cam?
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: rusthole]
#299231
04/26/09 12:27 PM
04/26/09 12:27 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
I have the "hemi" springs rated to .500 lift, so I guess I am slightly weak with the springs. I lubed the lifters on the bottom and sides and made sure they spin looslely. I have a standard valvetrain. Maybe I should upgrade to solid lifters if that helps? Need to get this thing going!
well, springs rated to 500 lift but trying to use them with a 509 cam ain't going to work well unless you are real lucky. Spring goes to coil bind and is solid - something has to give. with luck it will be a push rod bending. Springs should have at least (preferably more) .060 more travel than the valve lift. Same with clearance from the retainer to the guide/seal clearance. To avoid possible further problems the entire engine should be torn down and flushed and cleaned to get the filings that are all through the engine out.
#299233
04/26/09 01:36 PM
04/26/09 01:36 PM
I wouldn't put a mopar cam in my motor if you gave it to me for free!!!,,i;ve had very good luck with Lunati cams for a few years now,no problem breaking them in either..then again we don't break them in like everyone else,thats probably why they live...
[Re: RapidRobert]
#299234
04/26/09 01:46 PM
04/26/09 01:46 PM
Posts: 7,506 Az
Crizila
Az
Don't think you have a coil bind problem or you would have more than one lifter problem - and other broken / bent stuff.
Fastest 300
#299235
04/26/09 01:50 PM
04/26/09 01:50 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
When I ran into a core shifted cam from RB I found out that only 2 vendors provided cam cores, Engine Power and Crane. I also found out if you bought a shelf grind from Comp you got the Crane core, but if you bought a custom grind you got the EP core. Apparently the problems are/were with the Crane cores. I don't know where the Purple cams come from, but in this day and age there are cams better suited to individual combos than the Mopar grinds.
I tried to find the lengthy thread I had posted dealing with this issue but apparently it's purged from the system. The extensive picture file I have is locked up in a crashed hard drive. Anybody installing a cam should look for core shift issues. The problem is that the lobes don't line up under the lifters correctly. This prevents the lifters from spinning and/or quickly wears off the taper on the lobes. More than likely, this isn't the issue here, but it could be. Unless you know what to look for when installing the cam, the diagnosis would be attributed to wrong oil, lifter rotation, spring pressure etc.
[Re: Crizila]
#299237
04/26/09 04:25 PM
04/26/09 04:25 PM
MoparforLife
Upper Midwest
Maybe - maybe not. Says a different lobe each time.
[Re: Classof70Chally]
#299238
04/26/09 04:43 PM
04/26/09 04:43 PM
Posts: 30,460 Florida STAYcation
dOOc
The village idiot's idiot
Florida STAYcation
Been there, done that. Time for a roller.
Now THAT sounds like the ticket ...but ...
How about the reports about the rollers coming apart OR the guide-bars falling off ? ...I have not heard of ANY fail-safe upgrade here.
Anyone see that new Comp Cams new process on the lobes of a regular non-roller cam ?
[Re: dOOc]
#299239
04/26/09 06:19 PM
04/26/09 06:19 PM
Posts: 5,164 CT
GTX MATT
CT
It seems like alot of people have problems with the purpleshafts nowadays. I know someone who wasted one of the revised 484 grinds on break in, but he bought another one and recently switched to the revised 509 and didnt have problems with those.
[Re: 85_Ram_4speed]
#299240
04/26/09 06:28 PM
04/26/09 06:28 PM
So care to share how you do it, it is it some big trade secret?
Ya' we put the cam in,fire the car up set the timing and idle check oil pressure and temp..take the car for a blast,come back change oil and filter..We don't start it let it sit there running at 2500 rpms for a certain time,always get a kick out of that..oh and we NEVER had cam failure with this procedure can't say the same for the method everyone else thinks your suppose to use
#299242
04/26/09 08:21 PM
04/26/09 08:21 PM
Posts: 1,607 Lapeer, MI.
todd440
Lapeer, MI.
Yes, I'm with him. I never break in a cam at 2000 rpm for 20 minutes. Make sure it's timed, prefill the carb, start and run at maybe 1400, bliping the gas now and then for 4-5 minutes. Slight cool down, and repeat. I've never wiped a cam.
[Re: modelmakerinc]
#299243
04/26/09 08:44 PM
04/26/09 08:44 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
ive done rockwell harness tests on cam cores their ok it was all the newer lifters that are a joke. most cam corps use all the same blanks for cams. all the good lifter corps are gone
If the cam 's hardness is good but the lifters aren't then why does the cam lobe fail and not the lifter?
The cam and lifters need to be hard to prevent excessive wear, but the lifter has to be harder than the cam. The lifter has to be harder because it has load on one contact point all the time, where as the cams contact loaded point is spread all around the cams lobe. Once the smooth contact surfaces are gone for different reasons (low zinc/pho, soft lobes, soft lifters, stuck lifters, improper break in, etc), friction increases and wear starts. That's when the harder lifter will rapidly take out the cam lobe.
[Re: B5 Bee]
#299244
04/26/09 08:55 PM
04/26/09 08:55 PM
MoparforLife
Upper Midwest
The cam lob has a slight taper and the lifter has a slight 'dome'. The lifter does not contact the full face of the lifter or vice versa. The lifter also is supposed to spin as th cam shaft rotates so that the contact patch is not constant. If the lifter does not spin in the bore the cam and lifter will be destroyed in very short order.
[Re: MoparforLife]
#299245
04/26/09 09:05 PM
04/26/09 09:05 PM
B5 Bee
Pangaea
The point I was making is the load is focused on one small area on the lifter but spread out all over the lobe. Sure the lifter spins which helps to spread the load, but it is still a concentrated area compared to the lobe.
[Re: MoparforLife]
#299247
04/26/09 09:51 PM
04/26/09 09:51 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
How much lifter rotation is there in say spinning the motor over one revolution?
I mean say you mark the lifter and the bore....and you turn the motor over one revolution....how far should the lifter turn from the mark on the block?
Moparlee
[Re: rusthole]
#299248
04/26/09 10:18 PM
04/26/09 10:18 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I was able to find the lifter from the wasted lobe and looked more closely at it. It looks like the scarring is all in one direction- like it never rotated. I will change to another brand with a lift no more than .500 and clean up my lifter bores. No cam lube on the sides!
So have you pulled the motor down after losing 2 cams?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
