Removing "cat" from older car? #2990843
12/01/21 12:42 PM
12/01/21 12:42 PM
Massachusetts
Faust Offline OP
Faust  Offline OP
Massachusetts
I have a very low mileage '85 Caddy Seville. It is time for a new muffler and I am wondering about removing the catalytic converter. Will this make any difference? The car is severely underpowered and even 5 hp would be noticeable. Is there any other antique smog equipment I can remove? My state does not check cars this age. this is the 4.1, not the 8-6-4.
Re: Removing "cat" from older car? [Re: Faust] #2990861
12/01/21 01:43 PM
12/01/21 01:43 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I'd say yes especially if it's original CAT because it may be clogged. You could hollow it out and put it back on. Take a steel rod like piece of rebar and hollow it out or a piece of replacement pipe and you'll get a bit better flow but probably only notice the sound difference and not the extra hp.
Facts are stubborn things.
Re: Removing "cat" from older car? [Re: Faust] #2990865
12/01/21 01:50 PM
12/01/21 01:50 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
From what I know that's a fuel injected V8 and I'm sure it relies on an upstream O2 sensor and if it is in the cat on the upstream side you'll need to retain the O2 sensor for engine (fuel injection) management.
Re: Removing "cat" from older car? [Re: A12] #2990957
12/01/21 06:51 PM
12/01/21 06:51 PM
Houston, Texas
racerx20 Offline
Standard but OK
racerx20  Offline
Standard but OK
Houston, Texas
I know on the 80's Mopar there is only one O2 sensor pre-cat, my 88 CSX-T is cat-less and doesn't know the difference.
1972 Road Runner
1988 Shelby CSX-T
Re: Removing "cat" from older car? [Re: Faust] #2990966
12/01/21 07:27 PM
12/01/21 07:27 PM
IMGTX Offline
IMGTX  Offline
If the CAT looks like this then it would free up exhaust flow but how much power it would gain I am not sure.
This old style of CAT had ceramic balls in it coated with platinum/iridium. They choked the exhaust pretty bad.
Later styles up to today have a honeycomb matrix and flows much better and restrict flow very little, assuming it is not clogged or clogging.
As for the O2 Sensor and EFI. EFI systems require at least one O2 sensor before the cat. The cat cleans up the exhaust and the O2 sensor for the EFI needs to see how dirty or rich the exhaust is to adjust the air/fuel.
The O2 sensors after the cat (95 and newer) have nothing to do with the engine running. They are there to sniff the exhaust and see if the cat is working. If the reading before the cat and after the cat are the same the cat has failed.
If you want to delete the CAT and stay stealthy cut it open and weld a tube through the middle. I do it from the top and weld the top back on. If you don't put a tube inside the cat housing it will have a definite ping sound as the exhaust echos in the hollow cat.
If you remove or gut a cat on a 95 and later system with 2 or more O2 sensors put a spark plug non fouler adapter or O2 Spacer between the REAR O2 sensor(s) and the exhaust. It pulls the rear O2 sensors out of the exhaust flow and tricks the computer into thinking the cat is still there and ok.
Hope it helps.
Re: Removing "cat" from older car? [Re: IMGTX] #2990974
12/01/21 07:52 PM
12/01/21 07:52 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
I can only speak from experience- parents had an 85 coupe de ville with the 4.1. Its a massive turd. You could do a bunch of stuff to it, but naturally aspirated its a dump box, and are infamous for rear main leaks.
Re: Removing "cat" from older car? [Re: moparjim79] #2990983
12/01/21 08:13 PM
12/01/21 08:13 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
About the cats, I pulled a clogged cat off of my mothers Dodge minivan in early Nov, this year (she replaced it with a new one, her money). That OEM cat, at the junk yard, was worth $300, I suspect if I would have resisted a bit, I believe could have gotten more! Before you cut one up, might want to see what its worth scrap. Gene
Re: Removing "cat" from older car? [Re: poorboy] #2990998
12/01/21 08:37 PM
12/01/21 08:37 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
The druggies are stealing them for the money.
Re: Removing "cat" from older car? [Re: poorboy] #2991067
12/01/21 10:03 PM
12/01/21 10:03 PM
Massachusetts
Faust Offline OP
Faust  Offline OP
Massachusetts
Yes, I understand "factory" cats are worth a good piece of change. Aftermarket replacements, not so much. About the druggies someone else mentioned. Without a doubt. I live near a commuter rail station. Not safe to park a modern pick up there, they cut the cats off with a battery Sawzall.
Re: Removing "cat" from older car? [Re: moparjim79] #2991075
12/01/21 10:14 PM
12/01/21 10:14 PM
Massachusetts
Faust Offline OP
Faust  Offline OP
Massachusetts
Yeah, no power, I think 150hp. That is why I was looking for even 5hp. Car & engine only have 60K, so far, so good. I like it (I know it is love it, or hate it) and may swap the engine when I have more energy. It looks like this one, except later alloy wheels. I just stole the picture, no idea about the other cars.
Re: Removing "cat" from older car? [Re: larrymopar360] #2991247
12/02/21 12:58 PM
12/02/21 12:58 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
We used to do this back in the day when cats got clogged up. They also used to sell "test tubes", pieces of pipe that bolted in to replace cats. Marketed as a diagnostic tool to run while you ordered a new cat. Guess how often the test tubes were removed...
Re: Removing "cat" from older car? [Re: Ramrod39] #2991249
12/02/21 01:02 PM
12/02/21 01:02 PM
Massachusetts
Faust Offline OP
Faust  Offline OP
Massachusetts
Originally Posted by Ramrod39
[quote=larrymopar360
Yeah, I remember those in the J.C. Whitney catalogs, remember those?
Re: Removing "cat" from older car? [Re: Faust] #2991456
12/02/21 11:36 PM
12/02/21 11:36 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Sounds like time for an LS swap to me! boogie drive
Re: Removing "cat" from older car? [Re: JDMopar] #2991463
12/03/21 12:08 AM
12/03/21 12:08 AM
Massachusetts
Faust Offline OP
Faust  Offline OP
Massachusetts
That is the favored swap for them at the moment, particularly LS4.
Re: Removing "cat" from older car? [Re: Faust] #2991597
12/03/21 12:03 PM
12/03/21 12:03 PM
moparx Offline
moparx  Offline
in my experience "unclogging" cats, most guys just do the "jam a pipe into them" pick out the big chunks, and call it done.
then said "jammers" complain afterward the car ran better, but it's now back to where it was, or worse.
the problem with doing this on the car [or off for that matter] is you get the big chunks, but not all of the material. what's left will eventually find it's way to the muffler, then clog it up, choking off the exhaust.
the only sure fire way was mentioned above. take the cat off, cut open the top, remove the material, then weld the top back on. that way, you can be sure all the material is gone.
or get a "test pipe" [made or bought] installed.
i have fixed too many "jammer" repairs over the years, and heard them cry about buying new mufflers.
anyone that talks about punching out cats these days, i just tell them to not come back complaining to me when the car starts to run worse than before.
beer
Re: Removing "cat" from older car? [Re: Faust] #2991636
12/03/21 01:24 PM
12/03/21 01:24 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
When I read the title of this thread a totally different image went through my head. A long time ago my wife's brother asked thier dad if he could borrow his car to go on a date. Dad said you have a good car , take it. He said but my car stinks real bad I can't take it on a date. Dad says let's find out why it stinks. They opened the hood and there was a dead cat laying on the intake manifold. Dad tried to pull the cat out by the leg and the leg just pulled out like an overdone turkey drumstick.
Re: Removing "cat" from older car? [Re: GomangoCuda] #2991766
12/03/21 06:49 PM
12/03/21 06:49 PM
Massachusetts
Faust Offline OP
Faust  Offline OP
Massachusetts
When I was a kid, I found a cat trapped between my battery and the hood.
Re: Removing "cat" from older car? [Re: Faust] #2991831
12/03/21 10:00 PM
12/03/21 10:00 PM
Castlegar, BC, Canada
That AMC Guy Offline
I had no choice but to remove the cat from the '88 Dodge Ram V6 I've been putting back together. Not only did the truck not come with a cat, an OE one is not available and aftermarket ones are pointless since the truck is over 25 years old and exempt!
Some vehicles, it's as easy as cutting them out, and welding in pipe. Some vehicles, like my Ram, had an air tube run from the air pump and not only pumped air into the manifolds, it pumped air into the cat as well. These are the ones you gotta watch out for because you don't want those air pipes turning into exhaust leaks. Since my air pump was also gone, I figured I'd delete the tubing and plug off the manifolds. Well, those plugs would've wound up being really odd sizes and drilling the holes bigger in my case, just wasn't an option. Not only that, a y-pipe for the V6 Ram is unobtainium. But I could find a y-pipe from a Dakota.... but that necessitated finding Dakota manifolds. THAT actually turned out to be a stroke of luck because '94-and-up manifolds no longer have the air injection ports.
But then, I needed a Dakota trans dipstick tube. rolleyes because the one for the Ram manifolds ran right where the Dakota manifolds run. Ugh. What a debacle. Luckily it all worked out in the end.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Removing "cat" from older car? [Re: moparx] #2991912
12/04/21 08:52 AM
12/04/21 08:52 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
beer
Some people are lazy, you gotta jam that pipe through, then drop it a few times, then jam it again, don't stop until you can see clean metal around the edges lol. Or so I have heard.
68 Barracuda Formula S 340
Re: Removing "cat" from older car? [Re: Bad340fish] #2991992
12/04/21 02:19 PM
12/04/21 02:19 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I was unsuccessful at keeping Lucky (RIP) out of my Dart during construction, until I finally put the glass in smile
