Re: Locktite on caliper bracket bolts
[Re: burdar]
#2987606
11/21/21 06:21 PM
11/21/21 06:21 PM
Posts: 71 Fort Walton Beach
mothermopar
Fort Walton Beach
You are correct both red and purple locklite require heat for removal. Another option is to use blue as it doesn't require heat but will hold it.
1969 Superbee, Hemi, 4 Spd, Supertrack Pack 2007 Dodge Ram 2500, 4x4, 5.9 Cummins
[Re: IMGTX]
#2987692
11/22/21 01:39 AM
11/22/21 01:39 AM
Posts: 21,473 N.E. OHIO, USA
A12
N.E. OHIO, USA
I use red all the time and never had to use heat to remove it. I would follow the instructions from Dr Diff. He knows his stuff and the bracket bolts aren't removed often anyway for many brake systems. Same here on red Loctite. The most times that I have had to use heat to remove a fastener is when someone uses the brown Loctite........................oops someone just informed me that's not brown Loctite....they said that's RUST
