Page 6 of 7 1 2 3 4 5 6 7
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2987331
11/20/21 10:44 PM
11/20/21 10:44 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The shell left for the blaster this week...
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2988794
11/24/21 08:47 PM
11/24/21 08:47 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The shell was blasted and is back in the shop! Epoxy coming soon...
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2988927
11/25/21 10:52 AM
11/25/21 10:52 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Happy Thanksgiving!
The shell is sealed in epoxy.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2990025
11/29/21 12:23 AM
11/29/21 12:23 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Looking good!
I like the frame notches for the exhaust resonators. up
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: DynoDave] #2990576
11/30/21 05:55 PM
11/30/21 05:55 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Bottom of hood was blasted and primed.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2991891
12/04/21 01:48 AM
12/04/21 01:48 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
New lead in A pillar, C pillar, and rocker/quarter seam.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2994489
12/11/21 11:29 PM
12/11/21 11:29 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
New lead on the other C pillar...and the Charger was moved from the rotisserie to the roller stands.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2995019
12/13/21 06:48 PM
12/13/21 06:48 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Cool! Starting to look like a car again!
'63 Dodge 330
11.19 @ 121 mph
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: GY3] #2996288
12/17/21 10:25 PM
12/17/21 10:25 PM
Superfreak
Superfreak
Great looking lead work. I need a little tutilidge on this so I can do my mine.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: ] #2996304
12/18/21 12:12 AM
12/18/21 12:12 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: Neil] #3002693
01/06/22 07:13 PM
01/06/22 07:13 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
A few more roof dents were remedied. The trunk lid and hood bracing was sealed to prevent oil canning. And doors were weighted to simulate normal load.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #3005915
01/16/22 12:51 PM
01/16/22 12:51 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
All sheetmetal is back on the car...dialing in front end panels is next, which won't take long since it's been done before.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #3007799
01/22/22 10:32 AM
01/22/22 10:32 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Don't know which I'm more envious of, the car or the wide open land outside your shop! work shock
Great work! thumbs
John
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: SattyNoCar] #3007803
01/22/22 10:53 AM
01/22/22 10:53 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Front panel alignment done. If I didn't mention it before, the hood hinges have been rebuilt.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #3010681
01/30/22 10:26 PM
01/30/22 10:26 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Roof ribs are glued to the roof skin. And the roof skins were covered with Kilmat.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #3070164
08/21/22 02:02 PM
08/21/22 02:02 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Been awhile...stuff has been happening at a slow but steady pace so I'll try to catch up on the progress posts. The trim along the tops of the doors was deleted so those holes were welded closed. Also patched one last spot in the door jamb at bottom of the passenger side A pillar
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #3070165
08/21/22 02:03 PM
08/21/22 02:03 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The gutter trim is also being eliminated. The gap at the top of the A pillar was filled in and the aft end of the gutter was extended slightly so water will not run into the bottom corner of the window.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #3070166
08/21/22 02:04 PM
08/21/22 02:04 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Been prepping for paint...
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #3070172
08/21/22 02:12 PM
08/21/22 02:12 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #3070495
08/22/22 03:15 PM
08/22/22 03:15 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Wow, that's looking awesome!
'63 Dodge 330
11.19 @ 121 mph
