Unique battery mount question... #2987317
11/20/21 09:57 PM
11/20/21 09:57 PM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
Anyone ever mount a battery (lightweight mini or otherwise) directly below the OE location?? Like mounting the tray to the frame rail and/inner fender??
I like the idea of the battery down there as I don’t like the look in the stock spot. And I’d rather not put in in the trunk, so I was thinking a lightweight mini battery down there.
Experience? Thoughts??
Thanks!
Re: Unique battery mount question... [Re: cudadoug] #2987322
11/20/21 10:18 PM
11/20/21 10:18 PM
AndyF Offline
AndyF  Offline
I used a small racing battery in my Duster and built a small tray for it that mounted in roughly the stock location. I decided that it made a lot more sense to put a small battery up front than a regular battery in the trunk. When you weigh all the extra cables, switches and stuff it works out to be less weight to have a small battery up front.
Re: Unique battery mount question... [Re: cudadoug] #2987341
11/20/21 11:45 PM
11/20/21 11:45 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Not experience, I agree but the plates should be aligned with the wheelbase (opposite of shown) to prevent G force from trying to snap them off.
Boffin Emeritus
Re: Unique battery mount question... [Re: cudadoug] #2987382
11/21/21 03:03 AM
11/21/21 03:03 AM
Take the stock battery tray and mount it down there, shorten up the two support straps and use them also up twocents wrench sawzall weld up
Re: Unique battery mount question... [Re: polyspheric] #2987475
11/21/21 12:52 PM
11/21/21 12:52 PM
AndyF Offline
AndyF  Offline
What plates?
Re: Unique battery mount question... [Re: AndyF] #2987480
11/21/21 01:14 PM
11/21/21 01:14 PM
cudadoug Offline OP
cudadoug  Offline OP
Yes, bonus on the overall weight which is the main reason I was thinking a light battery. Is that a 17 or 18 Braille? Work out okay?
Re: Unique battery mount question... [Re: polyspheric] #2987491
11/21/21 01:47 PM
11/21/21 01:47 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
that's a lithium battery you can mount those upside down, sideways will make no difference !
Re: Unique battery mount question... [Re: DoubleD] #2987540
11/21/21 03:44 PM
11/21/21 03:44 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
A small battery could be put in the wheelhouse with minimal effort...
One could add a tray & holder to the bumper brackets, or use existing fasteners/holes.
Maybe even place it back by the firewall.
Re: Unique battery mount question... [Re: topside] #2987618
11/21/21 07:07 PM
11/21/21 07:07 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I put a 4.5 pound lithium on the inside of the frame rail, under the drivers side floor. I mounted the master switch there as well with a remote control rod protruding thru the back of the car. Less cable = less weight and less voltage drop.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Unique battery mount question... [Re: Hemi_Joel] #2987633
11/21/21 08:36 PM
11/21/21 08:36 PM
cudadoug Offline OP
cudadoug  Offline OP
4.5 pounds??!! May I ask what battery that is??
Re: Unique battery mount question... [Re: cudadoug] #2987637
11/21/21 08:59 PM
11/21/21 08:59 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
That would be the anti-gravity. It cranks my 13 and 1/2 to 1 Hemi over like the plugs were out of it.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Unique battery mount question... [Re: Hemi_Joel] #2987683
11/22/21 12:18 AM
11/22/21 12:18 AM
cudadoug Offline OP
cudadoug  Offline OP
Holy smokes! That is bang for the buck right there!!! Thank you Joel!
Re: Unique battery mount question... [Re: Hemi_Joel] #2987714
11/22/21 08:46 AM
11/22/21 08:46 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
Kind of liking this ideal work up i'm in need of a battery for next year anyway . plus the ideal of less voltage drop is a win ,win up Good post.
Re: Unique battery mount question... [Re: racerx] #2987743
11/22/21 10:10 AM
11/22/21 10:10 AM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
Wow. I just looked at their equivalent for a stock Group 24 battery. Over $800 for their Group-35/Q85. But in the right application, a big stroker comes to mind, it may be a good option.
Re: Unique battery mount question... [Re: 6PakBee] #2987767
11/22/21 11:35 AM
11/22/21 11:35 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
To keep the cable short, I mounted the NHRA mandatory cut off switch right next to the battery. The shaft of the switch is oriented vertically, protruding through the floor. A 5/16 inch by 030 wall stainless tube runs from the switch lever, under the seat, back through the trunk, and out the back of the car, and as a T handle on it to operate it remotely. A side benefit is that I can reach to turn it off and on from the driver's seat. The stainless tube weighs barely more than a pound.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Unique battery mount question... [Re: Hemi_Joel] #2987768
11/22/21 11:40 AM
11/22/21 11:40 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Roger, if you have an alternator, I don't see why you would need that big group 24. 900 cranking amps from the little 4 and 1/2 lb, $350 ATX 20 is more than enough for any racing engine. Unless you are ice racing in Beulah North Dakota when it's 30 below. wave
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Unique battery mount question... [Re: Hemi_Joel] #2987797
11/22/21 12:50 PM
11/22/21 12:50 PM
AndyF Offline
AndyF  Offline
That was the conclusion I came to with my Duster. My car sits in a heated garage so no need for a dump truck battery. I don't use the car as a snow plow or a tow truck, it only gets fired up on nice days so no need for a bunch of cold cranking amps. I measured how long the battery took to recharge after starting and it was typically less than 3 minutes.
Re: Unique battery mount question... [Re: Hemi_Joel] #2987800
11/22/21 12:58 PM
11/22/21 12:58 PM
moparx Offline
moparx  Offline
two questions if i may, Joel.
is that stainless tube seamless ?
and pertaining to that ATX battery, how does that last if one does mostly street driving ?
i wouldn't like having to buy a battery every couple of years.
as to the battery mounting, the inner fender of my charger under the factory battery tray, is crusty from the battery, so i was going to cut that out and mount a smaller battery directly on the front rail.
beer
Re: Unique battery mount question... [Re: moparx] #2987808
11/22/21 01:22 PM
11/22/21 01:22 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
X, I think it was seamless tube. The battery operates fine off of an alternator. I bought the battery in early 2017. They said it should last up to 10 years. After October 2018, I didn't try to use it again until mid 2021. It wouldn't hold a charge. I called them, they said send them the battery. After testing it, they said I should have had it on a charger more frequently for long term storage. I think I charged it once or twice in the 2-1/2 years. They offered me 40% credit on a replacement due to the battery being over 4 years old. I thought that was fair enough. The battery I bought from them in 2017 was an ATX-20 with 720 CCA. I used the 40% credit on an upgrade to the ATX-20-HD to get the 900 CCA, even though the old one was enough. It wasn't that much more $, especially with the 40% off. The new battery will get charged monthly when in storage! Hoping to get 10 years.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Unique battery mount question... [Re: cudadoug] #2987896
11/22/21 04:22 PM
11/22/21 04:22 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
My most recent solution to battery relocation is really not unique, its more OEM BMW style, under the back seat, over the area where an OEM muffler would be and thru the floorplan. That in my case makes for an in seat driver accessible battery shut off relatively uncomplicated, and now below the COG, and rearward. But then, I don't have to worry about my front tires lifting off the pavement. grin
