Page 20 of 20 1 2 18 19 20
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2986566
11/18/21 08:20 PM
11/18/21 08:20 PM
West Palm Beach, Florida
Copper Dart Offline OP
I installed the radiator, upper and lower hoses, trans cooler lines, fan and fan shroud made a little bracket to route the shift cable away from the header. chargerwork hammer weld Progress! Patting myself on the back lol. up
Copper
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2986599
11/18/21 09:22 PM
11/18/21 09:22 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Neil] #2986978
11/19/21 09:14 PM
11/19/21 09:14 PM
More progress on the build. up I can't remember who but a member here on Moparts said
that the a/c blower motor would fit if I use standard stamped steel style valve covers and they were correct! bow
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2987089
11/20/21 08:41 AM
11/20/21 08:41 AM
I forgot to post the shifter cable bracket installed.
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2990030
11/29/21 12:41 AM
11/29/21 12:41 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
More good progress! up
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: DynoDave] #2992074
12/04/21 07:33 PM
12/04/21 07:33 PM
Working on the transmission side of the shifter cable yellow. I didn't like the cheezy shockbrackets so I made my own. Two threaded bosses on the bellhousing looked like they were lonely so I put them into play. up Lucky I have another 727 just sitting in the shop that makes taking measurements and a great platform for fabbing up a bracket boogie
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2992077
12/04/21 07:53 PM
12/04/21 07:53 PM
Installing the bracket on the underside of the car while laying on my back was absolutely NO fun! mad lol The eyelet hole the OEM shift linkage arm is too small and the arm itself is too long so the shifter won't be able to go from park to L because of ratio issues. So I installed another shorter arm with the correct size eyelet hole to fit the cable adjuster pivot all while crawling under the car and trying to contort my limbs to fit in between the floor and exhaust pipes. I learned to keep my mouth shut quite quickly after dropping a wrench wrench and chipping my tooth shocked I think I might just drill another hole on the OEM shifter arm closer to the pivot point to get the correct ratio for this Hurst shifter. shruggy
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2992416
12/05/21 10:31 PM
12/05/21 10:31 PM
The Hurst shifter ratio doesn't match the transmission shift lever by quite a bit. scope See picture and the tiny mark made from trying to drill a new hole.
Trouble is that the lever is made from hardened steel and I can't drill a new hole to achieve the correct ratio. shock I tried two other early levers, all hardened steel! Luckily I had a later (1996 truck) Mopar transmission, it wasn't hardened steel and I was able use it. up
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #2995707
12/16/21 07:18 AM
12/16/21 07:18 AM
More progress on the build. Rear brakes done minus the hydraulic lines at the narrowed diff and the rear rubber line. I'm not sure how i'm going to route it around the 3' exhaust pipe that has invaded the real estate that belonged to the rubber hose. fun fun fun up
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #3028091
03/27/22 04:06 PM
03/27/22 04:06 PM
Just an update.
I keep having inflammation issues in my joints (fingers,elbows and knees mostly) that keep me from getting things done on the project. Between life and regular work, I don't have much left to work on my Dart. I reached out to a local shop that was recommended to me to do the repair or replacement of the factory OEM headliner. Once the headliner is done, i'll be able to install the (new to the car) Ralley dash and have the windshield and back glass re-installed. That will be a great step forward to getting this thing finally burning fuel again.
Wish me luck.
Copper
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #3029165
03/31/22 11:54 AM
03/31/22 11:54 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Health issue are no fun. Glad you are finding a way forward with the project.
DynoDave
Member # 12304
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: DynoDave] #3126392
03/04/23 10:32 AM
03/04/23 10:32 AM
I’m still alive and kicking! The Dart project has been a very slow go lately, but there is light at the end of the tunnel. Not sure exactly what tunnel that is but? Lol.
Mom.
Ricky Valdes
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: Copper Dart] #3127167
03/07/23 07:29 AM
03/07/23 07:29 AM
west palm beach, florida
modelmakerinc Offline
That car is so close to being put back together and enjoyed, drive Bro Ive said it to you a bunch But You really need to set aside a bit of time amongst all the work and other projects that I know you have, but just get-er-done twocents whistling
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Ricky's "Cha-Ching-Cheapo" '70 Swinger Build [Re: modelmakerinc] #3181602
10/06/23 09:16 AM
10/06/23 09:16 AM
Life and finances always seem to put sticks in my spokes. You’re right I need to set aside some time because it’s true. The car is almost finished.
Mom.
Ricky Valdes
