Page 2 of 4 1 2 3 4
Re: Why is my Buddy's Olds Street Car so Fast? [Re: fbs63] #2984240
11/11/21 07:04 PM
11/11/21 07:04 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Originally Posted by fbs63
840 hp @3200 lbs. Thats what it should run. My geuss is its lighter than you think. Perfect example of accurate dyno #s matching track performance. Dyno's are a measuring device and need to be calibrated often to stay accurate. They are also easily fooled by entering in inaccurate data points. Temp, water grains, barometric pressure all change results. So you guys who have "840 Dyno tested HP" and the car doesn't perform near that good, what does that tell you?
Exactly! Except you hastily misspelled 'guess' lolol.
Re: Why is my Buddy's Olds Street Car so Fast? [Re: HardcoreB] #2984241
11/11/21 07:22 PM
11/11/21 07:22 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It would need 840 hp uncorrected. This is street car. Is it running through exhaust? Looks like its got a pretty loose converter by the 60-330 incremental. 3200 with driver is pretty light for a GM A body. Especially with all the street equipment. Either it's really sorted out. Or it has some HP enhancement.
Doug
Re: Why is my Buddy's Olds Street Car so Fast? [Re: markz528] #2984246
11/11/21 07:57 PM
11/11/21 07:57 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Originally Posted by markz528
No roll cage (although it is on the agenda). Street car that he drives on a regular basis. 67 Olds Cutlass that his parents bought new. He had an aftermarket big block Olds built. Made 840 hp on the dyno.
I figured it would run high nines given that its a street car without a race suspension and should be relatively heavy.
9.12 @ 149 mph+! I find that crazy!
Not to nitpick but man some of those East coast tracks are fast, real fast. Especially in the Fall.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: Why is my Buddy's Olds Street Car so Fast? [Re: pittsburghracer] #2984259
11/11/21 08:27 PM
11/11/21 08:27 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Hush ! Lmao
....BAD A$$ STREET CAR.....
Re: Why is my Buddy's Olds Street Car so Fast? [Re: pittsburghracer] #2984271
11/11/21 08:53 PM
11/11/21 08:53 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Would be cool if they printed the DA on the timeslip.
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: Why is my Buddy's Olds Street Car so Fast? [Re: GY3] #2984276
11/11/21 09:01 PM
11/11/21 09:01 PM
PA.
"Little"John
"Little"John
PA.
It’s on everyone of my slips because I put it there. Corrected altitude calculated from barometer, humidity, and temp.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.38@138.67
Re: Why is my Buddy's Olds Street Car so Fast? [Re: pittsburghracer] #2984282
11/11/21 09:15 PM
11/11/21 09:15 PM
Morrow, OH
markz528 Online content OP
markz528  Online Content OP
Morrow, OH
Well I can tell you it has no power adders for sure. I am assuming it makes north of 840 hp. What it really weighs I don't know........
It is a 560 cubic inch. It does have a chevy overdrive tranny with lockup converter.
Re: Why is my Buddy's Olds Street Car so Fast? [Re: markz528] #2984308
11/11/21 10:13 PM
11/11/21 10:13 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Any pictures of said car scope?
Re: Why is my Buddy's Olds Street Car so Fast? [Re: racerx] #2984311
11/11/21 10:19 PM
11/11/21 10:19 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Lets see it.
Doug
Re: Why is my Buddy's Olds Street Car so Fast? [Re: racerx] #2984321
11/11/21 10:52 PM
11/11/21 10:52 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
So let me see if I have this correct. We have a 67 Cutlass street car. It has an production style Olds motor. Said motor has good enough cylinder heads, and cam, compression and intake that it can gain 28 mph in the back half. What type of Olds head is this good? Yet it has no cage or roll bar. I'll assume since it doesn't have any bars it probably doesn't have a lot of light weight parts either. Does it run with an exhaust system? So betting close to 3500 w/driver. Discounting the 60ft is it is as fast as my 15-1, -1 indy, .800" lift 572 in a good chassis at 3325lbs. I run brackets in Pro/Mod. There aren't very many car this quick with stock body panels and chassis of any brand at the tracks I've raced at. This guy must be a lot smarter than us.
Doug
Re: Why is my Buddy's Olds Street Car so Fast? [Re: pittsburghracer] #2984324
11/11/21 11:10 PM
11/11/21 11:10 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
laugh2 …..it was a whopping 191ft DA at high noon there today
Re: Why is my Buddy's Olds Street Car so Fast? [Re: dvw] #2984325
11/11/21 11:11 PM
11/11/21 11:11 PM
Morrow, OH
Morrow, OH
So this is the motor. And of course its through a full exhaust! LOL! 3 1/2" all the way..........
He thoroughly impressed me. Hopefully will be putting a cage in it soon.
https://www.enginelabs.com/engine-t...new-school-560-inch-olds-for-the-street/
Re: Why is my Buddy's Olds Street Car so Fast? [Re: markz528] #2984336
11/11/21 11:31 PM
11/11/21 11:31 PM
Morrow, OH
Morrow, OH
Car.........
Re: Why is my Buddy's Olds Street Car so Fast? [Re: dvw] #2984351
11/12/21 12:35 AM
11/12/21 12:35 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
j"why is my buddys olds street car so fast?" ???????????????????????????????????????????????????????????????????????????????????????????????????????????????
I guess the answer to that question seems to be 540ci with 15.2-1 compression and no stone left unturned?
Don't get me wrong, it's a bad ass!!! street car but no need to stumble around in bewilderment shruggy
Re: Why is my Buddy's Olds Street Car so Fast? [Re: INTMD8] #2984352
11/12/21 12:38 AM
11/12/21 12:38 AM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
I'm gonna guess it's lighter than you think too.
Good looking Olds.
Re: Why is my Buddy's Olds Street Car so Fast? [Re: slantzilla] #2984385
11/12/21 06:52 AM
11/12/21 06:52 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
It has a mad max switchable supercharger.
I want my fair share
Re: Why is my Buddy's Olds Street Car so Fast? [Re: SomeCarGuy] #2984399
11/12/21 08:03 AM
11/12/21 08:03 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Please tell me it didn't run that on those wheels and tires! Great engine build! Love seeing different stuff like that.
Re: Why is my Buddy's Olds Street Car so Fast? [Re: fbs63] #2984404
11/12/21 08:31 AM
11/12/21 08:31 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Nice build. A race engine run on the street. The car looks very deceiving as well. Pretty impressive. And I'll go with my last comment. Those involved with this build are smarter than me.
Doug
Re: Why is my Buddy's Olds Street Car so Fast? [Re: dvw] #2984408
11/12/21 09:03 AM
11/12/21 09:03 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
bill trovato built my neighbors 496 and 540 for his cutlass. my neighbors car won't run any times like the '66 car, but his '70's cutlass is a bad a$$ street car.
Re: Why is my Buddy's Olds Street Car so Fast? [Re: dvw] #2984409
11/12/21 09:04 AM
11/12/21 09:04 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
Doug
deep pockets and determination.
Page 2 of 4 1 2 3 4
