392 thermostat #2983336
11/09/21 08:46 AM
11/09/21 08:46 AM
Monroe NC
Luvcars69 Offline OP
Monroe NC
Hey guys how cold from stock can I go on my 19 Scat without lighting off the CEL? I've put a few 190* in the 5.7 Pursuits I've been reconditioning & selling with no problems. Thanks in advance for the help. Been 10 years since I've had the time to be on the board.
Also what cams exist for the 5.7 & 392 can I use beyond stock & remain emissions legal. I emailed Comp cams weeks ago but no answer.
Making cars faster one at a time!
19 Challenger Scat Pack white
16 Ram Sport SB Regular cab black
14 Charger Pursuit silver
78 Magnum 400 gray
69 SuperBee 512 Passion 4-speed 4:10
Re: 392 thermostat [Re: Luvcars69] #2983344
11/09/21 09:34 AM
11/09/21 09:34 AM
K
Kiddart Offline
Kiddart  Offline
K
I am running a 185* degree in mine. not sure I would go less than that as the PCM is programmed to run and change parameters/Auto adjust at 200* operating temp. but so far 185* has been good
Thank you
Kiddart
Re: 392 thermostat [Re: Kiddart] #2983839
11/10/21 02:51 PM
11/10/21 02:51 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Just food for thought: I was on a modern charger forum where a member was performing the benefits/draw backs of certain "bolt ons", a 180 t-stat was one of the pieces. He said while it did let the car remain at a cooler IDLE temp, it really did not change the driving temps( I can verify this, I also installed one with the same results bought on sale from MMX) the said test car actually was slower after the install.
He provided a handful of track timeslips to back up his claims.
Re: 392 thermostat [Re: moparjim79] #2983849
11/10/21 03:29 PM
11/10/21 03:29 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I put a 180 in my 2020 TA 392 it runs cooler, stock it ran 210, now it runs 185-195, the oil temp went from 228 down to 219ish, this is driving not sitting, the transmission shifts much better running cooler ?? as far as performance I dont know. this is summer time driving in Southeast Texas.
Re: 392 thermostat [Re: CSK] #2984064
11/11/21 10:51 AM
11/11/21 10:51 AM
Monroe NC
Monroe NC
Ok thanks guys, I'm going to go with a 190. Car is in NC & just a toy just want it to run a little cooler. Using 90 octane with no alcohol & 1/2 gallon of toluene to every 5 gallons of gas. Huge seat of pants difference!
Can anyone shed light on cams?
78 Magnum 400 gray
