Ignition Cylinder Broken Lever - Never saw this before #2983132
11/08/21 04:30 PM
11/08/21 04:30 PM
Canada
E
EW1BH27 Offline OP
EW1BH27  Offline OP
E
Canada
Finally got to tearing into my column to replace the key-in buzzer switch I thought was bad. Turns out I didn't need to buy the switch after all. Originally the buzzer would sound even without a key in and door open. The broken lever must have jammed the switch permanently depressed. It eventually jarred itself out because I found it inside the collar.
Any recommendations on where to buy a 1970 E body ignition cylinder? I plan to swap out the tumbler pins too, so my original key will work. Thanks.
Re: Ignition Cylinder Broken Lever - Never saw this before [Re: EW1BH27] #2983299
11/09/21 12:13 AM
11/09/21 12:13 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
That's a 70 type with the "knife" type hold in tab. Laters' have the round pushbutton.
Early were also a satin finish. I once adopted a round type cyl to a slot column by drilling a hole for the
button (where the slot is) to release into.
Not that difficult, but better then waiting to find the early style.
Re: Ignition Cylinder Broken Lever - Never saw this before [Re: PhillyRag] #2983341
11/09/21 08:54 AM
11/09/21 08:54 AM
Canada
E
EW1BH27 Offline OP
EW1BH27  Offline OP
E
Canada
Repops are available in both styles, was wondering if one vendor is favored over another.
