Where to find water valve for 71 B body Strato Vent #2981729
11/04/21 04:34 PM
11/04/21 04:34 PM
Canada
demon Offline OP
demon  Offline OP
Canada
I've been striking out. Where can I find a water valve for a 1971 B body with Strato-Vent? I don't mind modifyling a similar valve if necessary, but sure would like a correct one.
Re: Where to find water valve for 71 B body Strato Vent [Re: demon] #2981751
11/04/21 05:34 PM
11/04/21 05:34 PM
Andrewh Online content
Andrewh  Online Content
so that is interesting.
I found one listed already sold.
https://www.forbbodiesonly.com/moparforum/threads/nos-1971-73-b-body-strato-vent-water-valve.166403/
but looking up that part number
there are 2 modern ones. half plastic.
ford valve
all plastic
dodge valve
That appear to be the same design.
and then this one that says it is for that car, but completly different
https://www.ebay.com/p/1241995178
Re: Where to find water valve for 71 B body Strato Vent [Re: demon] #2981752
11/04/21 05:36 PM
11/04/21 05:36 PM
md
mopars4ever Offline
mopars4ever  Offline
md
3579173 is the part number. Check on B bodies only. Someone there may have one if you post a want ad.
Re: Where to find water valve for 71 B body Strato Vent [Re: mopars4ever] #2982061
11/05/21 01:21 PM
11/05/21 01:21 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Do you have your old correct one?
There’s a few other brand cars that have the same exact valve but use a different bracket. It may be cheaper to find and all brass NOS version for another car and modify your OE bracket to work. I’ve seen it done with riveting the bracket to the vacuum diaphragm. The valve section is just held on by two screws, IIRC
Like 67-69 Camaro? This was talked about years ago here… use both Moparts search functions
Re: Where to find water valve for 71 B body Strato Vent [Re: autoxcuda] #2982821
11/07/21 03:53 PM
11/07/21 03:53 PM
Canada
demon Offline OP
demon  Offline OP
Canada
Thanks for the help everyone. Yes, I have my original valve but it is seized inside.
I have tried searching on here, but no success.
If I can modify another version and transfer my bracket, that is fine.
I just need a functioning valve, and preferably a correct appearance
Re: Where to find water valve for 71 B body Strato Vent [Re: demon] #2982829
11/07/21 04:27 PM
11/07/21 04:27 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
there is a GM valve that is very similar with a different bracket ................ but would this work? scope
at WALLMART
Re: Where to find water valve for 71 B body Strato Vent [Re: 6bblgt] #2982832
11/07/21 04:40 PM
11/07/21 04:40 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
here's the GM part ..... work I forget the application
Re: Where to find water valve for 71 B body Strato Vent [Re: 6bblgt] #2982834
11/07/21 04:41 PM
11/07/21 04:41 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
& the MOPAR one scope
Re: Where to find water valve for 71 B body Strato Vent [Re: 6bblgt] #2983046
11/08/21 10:54 AM
11/08/21 10:54 AM
Canada
demon Offline OP
demon  Offline OP
Canada
That looks like it could be converted. Anyone know what application it is?
Thank you for the help!
Re: Where to find water valve for 71 B body Strato Vent [Re: demon] #2983111
11/08/21 02:43 PM
11/08/21 02:43 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
That’s the one I think I found that was used for the resto of a 71 Charger strato vent car.
I think 67 to 69 Camero’s. Can’t remember if all or one particular year.
Current offerings may have been updated too. So look on eBay for old NOS boxes.
