Where to find water valve for 71 B body Strato Vent
#2981729
11/04/21 04:34 PM
11/04/21 04:34 PM
Posts: 1,179 Canada
demon
Canada
I've been striking out. Where can I find a water valve for a 1971 B body with Strato-Vent? I don't mind modifyling a similar valve if necessary, but sure would like a correct one.
Re: Where to find water valve for 71 B body Strato Vent
[Re: mopars4ever]
#2982061
11/05/21 01:21 PM
11/05/21 01:21 PM
Posts: 27,444 So Cal
autoxcuda
So Cal
Do you have your old correct one?
There’s a few other brand cars that have the same exact valve but use a different bracket. It may be cheaper to find and all brass NOS version for another car and modify your OE bracket to work. I’ve seen it done with riveting the bracket to the vacuum diaphragm. The valve section is just held on by two screws, IIRC
Like 67-69 Camaro? This was talked about years ago here… use both Moparts search functions
[Re: 6bblgt]
#2983046
11/08/21 10:54 AM
11/08/21 10:54 AM
Posts: 1,179 Canada
demon
Canada
here's the GM part ..... I forget the application That looks like it could be converted. Anyone know what application it is? Thank you for the help!
[Re: demon]
#2983111
11/08/21 02:43 PM
11/08/21 02:43 PM
autoxcuda
So Cal
here's the GM part ..... I forget the application That looks like it could be converted. Anyone know what application it is? Thank you for the help! That’s the one I think I found that was used for the resto of a 71 Charger strato vent car. I think 67 to 69 Camero’s. Can’t remember if all or one particular year. Current offerings may have been updated too. So look on eBay for old NOS boxes.
