Any GM techs on here 6.0 v8
#2981601
11/04/21 11:05 AM
11/04/21 11:05 AM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
Have a 2005 Chevy 2500 with 6.0 37,000 miles on it P0300 random missfire… mostly on #5 but see it on others too. Seems to act up mainly under load. Compression test good Swapped plugs, coil, injector…. Currently spraying intake gaskets to see if they are leaking
Any ideas on what to check?
Re: Any GM techs on here 6.0 v8
[Re: B3422W5]
#2981609
11/04/21 11:38 AM
11/04/21 11:38 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Seen injector rails get clogged up w/ dirt...a lot of those don't have fuel filters.
[Re: moparjim79]
#2981712
11/04/21 03:57 PM
11/04/21 03:57 PM
B3422W5
Portage,michigan
No, not in 2005. Came out in 2007
