Replace trunk floor with 1 quarter off? #2981428
11/03/21 06:10 PM
11/03/21 06:10 PM
Indiana
68_661charger Offline OP
Indiana
I think I know the answer by looking at the car but will a one piece trunk pan fit in place on a 68 Charger with only one quarter removed ? Or only through the back with valance or taillamp panel off? Thanks in advance all.
Re: Replace trunk floor with 1 quarter off? [Re: 68_661charger] #2981475
11/03/21 08:37 PM
11/03/21 08:37 PM
N
NITROUSN Offline
NITROUSN  Offline
N
It should slide right in with the quarter off.
Re: Replace trunk floor with 1 quarter off? [Re: NITROUSN] #2981512
11/03/21 10:07 PM
11/03/21 10:07 PM
Indiana
Indiana
Ok I assumed no it wouldn't. Maybe have to remove trunk gutter too?
Re: Replace trunk floor with 1 quarter off? [Re: 68_661charger] #2981588
11/04/21 10:06 AM
11/04/21 10:06 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Never attempted it in that way.......but I believe the wheelhouse assembly and the structure above it will interfere.
FWIW, on my '69 GTX I was able to slip the 1 piece trunk floor in with one quarter off but I also had the wheelhouse assy removed at the same time.
Trunk gutters were left in place/intact, but all the spot welds at the rear crossmember were all removed which allowed some movement to get it all installed.
Rich H.
Esse Quam Videri
Re: Replace trunk floor with 1 quarter off? [Re: 68_661charger] #2981598
11/04/21 10:43 AM
11/04/21 10:43 AM
Canada
demon Offline
demon  Offline
Canada
No, It will not go in from the side. The wheelhouse and trunk hinge support is in the way.
Here's a link to how I do it.
The Charger is one of the easier cars to do install the trunk floor from the rear. Only need to remove the rear valance. But bear in mind, the 68-70 Charger bodies are one of the most complex cars to restore. There's a lot going on back there
https://board.moparts.org/ubbthread...-floor-installation-yes-it-will-fit.html
Re: Replace trunk floor with 1 quarter off? [Re: demon] #2981606
11/04/21 11:29 AM
11/04/21 11:29 AM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Probably not what you want, but I would consider sawing it in half, sawzall put it in place and weld it back together. weld
I am not a real body man and I have never played one on tv.
Re: Replace trunk floor with 1 quarter off? [Re: GomangoCuda] #2981656
11/04/21 01:44 PM
11/04/21 01:44 PM
Canada
demon Offline
demon  Offline
Canada
that would be a lot more work, for less quality results.
The one piece trunk floor will slide in from the rear easily on a 68-70 Charger. The trunk floor welds to the rear valance, so that needs to be drilled apart anyway. It's simply a case of drilling the valance free from the tail panel and ends, and then it's off, leaving a nice wide opening for the new panel to slide right in.
Odds are, the rear valance and or valance corners and rear crossmember will have rust issues too, so this allows you to access, and repair or replace those pieces too.
Re: Replace trunk floor with 1 quarter off? [Re: demon] #2981719
11/04/21 04:10 PM
11/04/21 04:10 PM
laugh2 I did say you probably wouldn't like it. If the valence should come off anyway then that is apparently the Correct way to do it. I was just throwing out another option in case the proper way was too painful.
As far as looks go a can of splatter paint and a trunk mat will cover that. If it looks hideous but no one can see it then shruggy
Warned you I wasn't a body man. fan
Re: Replace trunk floor with 1 quarter off? [Re: GomangoCuda] #2981829
11/04/21 09:02 PM
11/04/21 09:02 PM
Indiana
Indiana
Ok sounds good, thanks all.
