Solid roller lifter on hydraulic roller
#2980813
11/02/21 09:22 AM
11/02/21 09:22 AM
Posts: 3,149 Md.
carnut68
Md.
Anyone on here doing this? Mostly strip some street use. I am considering going hydraulic roller, a friend suggested checking into this. Parts availability is going to be an issue. 511 rb, indy ez.
America First!
Re: Solid roller lifter on hydraulic roller
[Re: carnut68]
#2980831
11/02/21 10:23 AM
11/02/21 10:23 AM
Posts: 710 Lake Villa Il
INTMD8
Lake Villa Il
It can be done but my suggestion would just have a low lash solid ground for your combination.
[Re: INTMD8]
#2980846
11/02/21 11:15 AM
11/02/21 11:15 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Yes this can be done but there are a few things that you need to make sure of before proceeding.
1. Make sure your cam is billet not cast, if Cast, don't do it. 2. Like INIMD8 said, tighten up the lash to almost nothing, .004 - .005 (I just spoke to Lunati last week and that is what they told me to do)
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: carnut68]
#2980853
11/02/21 11:27 AM
11/02/21 11:27 AM
Posts: 759 Southington Ct.
turbobitt
Southington Ct.
If you have the cam manufacture and lobe numbers it would be easier to make a determination. Certain lobe profiles will easily run either/or, Some hydraulic profiles are to aggressive to run on solid lifters.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: WadeMetzinger]
#2980863
11/02/21 11:32 AM
11/02/21 11:32 AM
Posts: 3,149 Md.
carnut68
Md.
1. Make sure your cam is billet not cast, if Cast, don't do it. 2. Like INIMD8 said, tighten up the lash to almost nothing, .004 - .005 (I just spoke to Lunati last week and that is what they told me to do) I'm considering the XR 286 HR-10 Comp, their website states billet steel. I'm aware of the lash and having to experiment with it.
America First!
[Re: carnut68]
#2980893
11/02/21 01:06 PM
11/02/21 01:06 PM
Posts: 701 Northern California
lilcuda
Northern California
Way too much hassle In my experience. I use to own the 68 Valiant that Tim Werner built. AndyF built the engine and it had solid lifters on a hydraulic roller. The lash needed to be right at about zero cold so it would open up to .006 to .008 hot. I was concerned about hanging a valve open, so I set them at about .001 to .0015 cold. The valvetrain was noisy. It just didn't sound happy. If I had kept that car, I would have swapped in a solid roller.
If you're building the engine, just put a tight lash solid roller in it.
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
[Re: carnut68]
#2980952
11/02/21 03:32 PM
11/02/21 03:32 PM
Posts: 30,989 Oregon
AndyF
Yes I did it before with a Comp Cam in a SB Mopar. The hyd roller lifters wouldn't fit in the block so we switched to solid roller lifters. Comp told us to tighten the lash to almost zero and let the aluminum heads grow some lash. It worked just fine on the dyno and for racing.
[Re: lilcuda]
#2980953
11/02/21 03:35 PM
11/02/21 03:35 PM
AndyF
I agree, I wouldn't build an engine that way for a daily driver or even a regular driver. Tim's car was about 95% race car.
[Re: AndyF]
#2980958
11/02/21 03:46 PM
11/02/21 03:46 PM
Posts: 3,149 Md.
carnut68
Md.
I agree, I wouldn't build an engine that way for a daily driver or even a regular driver. Tim's car was about 95% race car. This is 95% race car an occasional cruise night car. Just trying to get parts together b/4 they dry up.
America First!
[Re: carnut68]
#2980966
11/02/21 04:15 PM
11/02/21 04:15 PM
AndyF
[Re: AndyF]
#2980971
11/02/21 04:27 PM
11/02/21 04:27 PM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
This is 95% race car an occasional cruise night car. I don’t understand why you wouldn’t just use a solid roller for that application.
[Re: fast68plymouth]
#2980975
11/02/21 05:07 PM
11/02/21 05:07 PM
Posts: 3,149 Md.
carnut68
Md.
This is 95% race car an occasional cruise night car. I don’t understand why you wouldn’t just use a solid roller for that application. I was considering a hydraulic street roller set up when a friend suggested I look into it. It's not set in stone. With the lack of parts availability, whats the wait period looking like on a custom ground roller [solid]? I was just looking at whats available on the shelves at this point. Also my valve springs are set up for sft cam Comp 928s. That was the thought behind a hydraulic roller.. A 511ci in an A body isn't going to take much to get it moving.
America First!
[Re: carnut68]
#2980985
11/02/21 05:51 PM
11/02/21 05:51 PM
Posts: 53 Northern Bavaria / Germany
MichaelF
1. Make sure your cam is billet not cast, if Cast, don't do it. 2. Like INIMD8 said, tighten up the lash to almost nothing, .004 - .005 (I just spoke to Lunati last week and that is what they told me to do) I'm considering the XR 286 HR-10 Comp, their website states billet steel. I'm aware of the lash and having to experiment with it. Be careful, this Cam is on a cast core. I do have one here, can show pics if necessary. Obviously the data at comps HP is wrong. Michael
[Re: MichaelF]
#2980987
11/02/21 06:12 PM
11/02/21 06:12 PM
Posts: 9,388 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Were the old early gentle roller cams of the past a different core? Ive still some reed cast core solid roller cams and used early early crane rollers on them.
Were they a different material or hardened?
STOP POTATO HATE!
[Re: MichaelF]
#2981003
11/02/21 06:51 PM
11/02/21 06:51 PM
Posts: 3,149 Md.
carnut68
Md.
1. Make sure your cam is billet not cast, if Cast, don't do it. 2. Like INIMD8 said, tighten up the lash to almost nothing, .004 - .005 (I just spoke to Lunati last week and that is what they told me to do) I'm considering the XR 286 HR-10 Comp, their website states billet steel. I'm aware of the lash and having to experiment with it. Be careful, this Cam is on a cast core. I do have one here, can show pics if necessary. Obviously the data at comps HP is wrong. Michael That is some good info. Thank you.
America First!
[Re: carnut68]
#2981257
11/03/21 10:41 AM
11/03/21 10:41 AM
fast68plymouth
So. Burlington, Vt.
I don’t believe any BBM roller cams are ground on cast cores. Some SB yes...... BBM, no. I’d love to see a pic of a BBM roller from Comp that’s on a cast core.
[Re: carnut68]
#2981553
11/04/21 03:26 AM
11/04/21 03:26 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I'm considering the XR 286 HR-10 Comp, their website states billet steel. I'm aware of the lash and having to experiment with it. Running that cam in my 505" rb (0.030" over 440 with 4.25" stroke) Running with Stealth heads, 10.3:1 compression, and 1.6:1 HS Rockers. It is a fairly tame cam (running EFI), makes good torque, but I limit peak RPM to 6,000 RPM. Using ISKY 8005A valve springs that are just a bit stiffer than the Comp 925-16 valve springs. Retainers (for the Isky springs) are Comp 748-16 Video was when it had a RPM Intake and 750 cfm carb, TTI 1-7/8" headers, and 2.5" TTI X-pipe exhaust with the TTI supplied Super Turbo Mufflers. https://www.youtube.com/watch?v=0ui4GCHn_7o
