black suede OEM dash powder for powdercoating... #298063
04/24/09 09:53 AM
04/24/09 09:53 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
EDIT: I have found a place that can powder coat my dash. It'll be a lot cheaper if I can either supply him with powder or locate where the powder is for our dashes.. He's not accustomed to powder coating OEM black suede.. Anyone have a source for the proper powder?
Thanks again...
Troy
Hey gang..
Comtemplating two possibilities, painting my dash frame or having it powder coated.. Anyone have experience with outcome and price between the two?
I'm also thinking about the grille header on my '68 Charger R/T.
Troy
Troy
Houston Mopar Connection Club
Re: Anyone powercoat their dash frame and grille header [Re: hemi68charger] #298064
04/24/09 11:48 AM
04/24/09 11:48 AM
Silicon valley
A12bee Offline
super street
A12bee  Offline
super street
Silicon valley
I had my bee's dash powder coated. Finish looks as original. I got the mixture info from AZA12bee as he had his done before me and the look is dead nuts on. If you need I will see if I can find that code and or post a pic.
-Paul
This space left intentianlly blank.
Re: Anyone powercoat their dash frame and grille header [Re: A12bee] #298065
04/24/09 12:07 PM
04/24/09 12:07 PM
Houston, Tx
Houston, Tx
-Paul
I would love that.. Remember about what it cost?
Thanks..
Troy
Troy
Re: Anyone powercoat their dash frame and grille header [Re: hemi68charger] #298066
04/25/09 09:16 AM
04/25/09 09:16 AM
runningman Offline
super street
runningman  Offline
super street
I would like this info also, thanks!
Re: Anyone powercoat their dash frame and grille header [Re: hemi68charger] #298067
04/25/09 11:30 AM
04/25/09 11:30 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I had both done. Here are before and after on the header.
Re: Anyone powercoat their dash frame and grille header [Re: NITROUSN] #298068
04/25/09 11:31 AM
04/25/09 11:31 AM
N
NITROUSN Offline
NITROUSN  Offline
N
before 2
Re: Anyone powercoat their dash frame and grille header [Re: NITROUSN] #298069
04/25/09 11:31 AM
04/25/09 11:31 AM
N
NITROUSN Offline
NITROUSN  Offline
N
after 1
Re: Anyone powercoat their dash frame and grille header [Re: NITROUSN] #298070
04/25/09 11:32 AM
04/25/09 11:32 AM
N
NITROUSN Offline
NITROUSN  Offline
N
after 2
Re: Anyone powercoat their dash frame and grille header [Re: NITROUSN] #298071
04/25/09 01:24 PM
04/25/09 01:24 PM
Houston, Tx
Houston, Tx
Pete, is that paint or powdercoated?
Looks great...
Troy
Troy
Re: Anyone powercoat their dash frame and grille header [Re: hemi68charger] #298072
04/25/09 01:37 PM
04/25/09 01:37 PM
Jacksonville Florida
elitecustombody Offline
Usually getting things powdercoated will cost less than getting them painted,there is no need to sand,grind and wire the rust off,all parts are blasted and special etch-primed prior powdercoating,also it's alot more durable than any paint
Re: Anyone powercoat their dash frame and grille header [Re: hemi68charger] #298073
04/25/09 02:11 PM
04/25/09 02:11 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Looks great...
Troy
Troy it is powdercoated. I had the dash frame done also but cant find my pics. They may be on my lap top out in the shop. Will post them when I can.
Re: Anyone powercoat their dash frame and grille header [Re: A12bee] #298074
04/25/09 02:29 PM
04/25/09 02:29 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
-Paul
Was the original dash finish a suede finish? I didn't know they could do non-glossy with powder coating if so...
Re: Anyone powercoat their dash frame and grille header [Re: In_The_Pink] #298075
04/25/09 02:54 PM
04/25/09 02:54 PM
N
NITROUSN Offline
NITROUSN  Offline
N
They have hundreds of colors, gloss , and textures available.
Re: Anyone powercoat their dash frame and grille header [Re: hemi68charger] #298076
04/25/09 02:57 PM
04/25/09 02:57 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Re: Anyone powercoat their dash frame and grille header [Re: NITROUSN] #298077
04/26/09 11:41 PM
04/26/09 11:41 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Suede Powder Coated Dash Frame...
Re: Anyone powercoat their dash frame and grille header [Re: 1_WILD_RT] #298078
04/27/09 06:35 AM
04/27/09 06:35 AM
Houston, Tx
Houston, Tx
Does anyone know of a source to get about 5 to 10 lbs of the black suede powder?
Troy
Re: powercoat their dash frame: powder supplier... [Re: hemi68charger] #298079
04/27/09 03:05 PM
04/27/09 03:05 PM
Houston, Tx
Houston, Tx
Thanks again...
Troy
Troy
Re: powercoat their dash frame: powder supplier... [Re: hemi68charger] #298080
04/27/09 03:58 PM
04/27/09 03:58 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Troy,.....The closest your going to get to black suede, is "black textured" from www.eastwood.com
black textured #11870 2 lbs $25, 5lbs $48, 10 lbs $95...
.are you sure you want suede for the dash frame?......I always finish the steering columns in suede, dashes generally in satin,
if you need satin powder, the # is 10103 same prices
if you log onto eastwood for powder tech info use keyword...... powder,....hope this helps
Re: powercoat their dash frame: powder supplier... [Re: DAYCLONA] #298081
04/27/09 09:10 PM
04/27/09 09:10 PM
Houston, Tx
Houston, Tx
Whew.. Thanks Mike... That's exactly what I was looking for..... I'll check out eastwood now.. I'll contact Dave at ECS for the VIN resto. product, I have NOS rivets already...
Troy
Re: Anyone powercoat their dash frame and grille header [Re: elitecustombody] #298082
04/27/09 09:27 PM
04/27/09 09:27 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
You can't powder coat filler and if the surface has any defects, it will show. Also, I believe it generally will be thicker than painted? Any fine details like stamped in date codes will not be sharp.
