Source for RV2 A/C Compeessor Rebuid Kit? #2980224
10/31/21 12:03 PM
10/31/21 12:03 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Howdy,
I am in the process of reinstalling the air conditioning on our 66 Coronet 500. I would prefer to go through the compressor however I am not finding parts other than Classic Auto Air. Is there a better place to source these pars?
Thanks for any insight!
Re: Source for RV2 A/C Compeessor Rebuid Kit? [Re: Jeremiah] #2980277
10/31/21 02:40 PM
10/31/21 02:40 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
You could buy this from NAPA and use it or rob the parts you need from it too if you don't find a source for rebuild parts.
https://www.napaonline.com/en/p/TEM252106?impressionRank=2
Re: Source for RV2 A/C Compeessor Rebuid Kit? [Re: A12] #2980317
10/31/21 04:45 PM
10/31/21 04:45 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I see that the "Remanufactured compressors come with the R12/R134A/1234yf required O-rings /sealing washers to install the compressor" I didn't know that there were O-rings compatible with both R12 and R134A.
Wife says too many cars, liquidation coming soon......
Re: Source for RV2 A/C Compeessor Rebuid Kit? [Re: Jeremiah] #2980502
11/01/21 09:43 AM
11/01/21 09:43 AM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
When I was going to reseal my compressor in my 79 Cordoba, found it easier to just get a reman off Rock Auto. Mine wasn't labeled clearly what oil was prefilled in it, so I flushed out with new PAG oil a couple of times to ensure I had compatible oil in it. I went through it checking all bolts and torques. I recall one bolt being incorrect and swapped from my old compressor. Been over 2 years now and that system is crazy cold. I did put a new expansion valve and evap as well, so that I am sure helped.
Re: Source for RV2 A/C Compeessor Rebuid Kit? [Re: 6PakBee] #2980534
11/01/21 11:26 AM
11/01/21 11:26 AM
Rio Linda, CA
John_Kunkel Offline
Much ado about nothing
John_Kunkel  Offline
Rio Linda, CA
"A better type of O-ring for air conditioning applications is HNBR which stands for Hydrogenated NBR (sometimes called Hydrogenated Nitrile, or Highly Saturated Nitrile Rubber, or HNB). The compatibility of HNBR with Mineral oil, PAG, POE, R-12, R-134a, R-1234yf is very good. Another advantage is that its temperature range is -22F to 302F. They are green in color."
Doing my best to irritate the herd.
Re: Source for RV2 A/C Compeessor Rebuid Kit? [Re: John_Kunkel] #2980690
11/01/21 06:40 PM
11/01/21 06:40 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Theres a complete RV2 on CL eastern NC $55
Re: Source for RV2 A/C Compeessor Rebuid Kit? [Re: John_Kunkel] #2980814
11/02/21 08:25 AM
11/02/21 08:25 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Thanks, John. I have an assortment of green A/C O-rings but I was under the impression that they were R-134A compatible only. Thanks again.
