black suede OEM dash powder for powdercoating...
#298063
04/24/09 09:53 AM
04/24/09 09:53 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
EDIT: I have found a place that can powder coat my dash. It'll be a lot cheaper if I can either supply him with powder or locate where the powder is for our dashes.. He's not accustomed to powder coating OEM black suede.. Anyone have a source for the proper powder?
Thanks again... Troy
Hey gang.. Comtemplating two possibilities, painting my dash frame or having it powder coated.. Anyone have experience with outcome and price between the two?
I'm also thinking about the grille header on my '68 Charger R/T.
Troy
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Anyone powercoat their dash frame and grille header
[Re: hemi68charger]
#298064
04/24/09 11:48 AM
04/24/09 11:48 AM
Posts: 586 Silicon valley
A12bee
super street
super street
Silicon valley
I had my bee's dash powder coated. Finish looks as original. I got the mixture info from AZA12bee as he had his done before me and the look is dead nuts on. If you need I will see if I can find that code and or post a pic. -Paul
This space left intentianlly blank.
[Re: A12bee]
#298065
04/24/09 12:07 PM
04/24/09 12:07 PM
hemi68charger
Houston, Tx
I would love that.. Remember about what it cost?
Thanks.. Troy
[Re: NITROUSN]
#298071
04/25/09 01:24 PM
04/25/09 01:24 PM
hemi68charger
Houston, Tx
I had both done. Here are before and after on the header.
Pete, is that paint or powdercoated? Looks great... Troy
[Re: hemi68charger]
#298073
04/25/09 02:11 PM
04/25/09 02:11 PM
Posts: 18,424 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Troy it is powdercoated. I had the dash frame done also but cant find my pics. They may be on my lap top out in the shop. Will post them when I can.
[Re: A12bee]
#298074
04/25/09 02:29 PM
04/25/09 02:29 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
Was the original dash finish a suede finish? I didn't know they could do non-glossy with powder coating if so...
[Re: 1_WILD_RT]
#298078
04/27/09 06:35 AM
04/27/09 06:35 AM
hemi68charger
Houston, Tx
Does anyone know of a source to get about 5 to 10 lbs of the black suede powder?
Re: powercoat their dash frame: powder supplier...
[Re: hemi68charger]
#298079
04/27/09 03:05 PM
04/27/09 03:05 PM
hemi68charger
Houston, Tx
[Re: hemi68charger]
#298080
04/27/09 03:58 PM
04/27/09 03:58 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Troy,.....The closest your going to get to black suede, is "black textured" from www.eastwood.com black textured #11870 2 lbs $25, 5lbs $48, 10 lbs $95... .are you sure you want suede for the dash frame?......I always finish the steering columns in suede, dashes generally in satin, if you need satin powder, the # is 10103 same prices if you log onto eastwood for powder tech info use keyword...... powder,....hope this helps
[Re: DAYCLONA]
#298081
04/27/09 09:10 PM
04/27/09 09:10 PM
hemi68charger
Houston, Tx
Whew.. Thanks Mike... That's exactly what I was looking for..... I'll check out eastwood now.. I'll contact Dave at ECS for the VIN resto. product, I have NOS rivets already...
[Re: elitecustombody]
#298082
04/27/09 09:27 PM
04/27/09 09:27 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
Usually getting things powdercoated will cost less than getting them painted,there is no need to sand,grind and wire the rust off,all parts are blasted and special etch-primed prior powdercoating,also it's alot more durable than any paint
You can't powder coat filler and if the surface has any defects, it will show. Also, I believe it generally will be thicker than painted? Any fine details like stamped in date codes will not be sharp.
