Re: Flaring tubing problem [Re: Copper Dart] #2980475
11/01/21 09:29 AM
11/01/21 09:29 AM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
That's what I have done.
Re: Flaring tubing problem [Re: Copper Dart] #2980514
11/01/21 11:10 AM
11/01/21 11:10 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by Copper Dart
Originally Posted by 70Duster
Originally Posted by 6PAX
It’s not the sending unit I’m trying to flare. It’s the fuel line where it ends near the gas tank and is connected to the sending unit by a short piece of hose.
There's absolutely no reason or advantage to using a double flare in that application. A single flare is fine. All you need is the OD of the metal line expanded slightly at the end of the line to help prevent the hose from slipping off after its clamped.
iagree
X 2 or 3
And will add doing a double will create a larger OD and sharp ridge that will likely cause the hose to fail prematurely twocents beer
Re: Flaring tubing problem [Re: TJP] #2980529
11/01/21 12:03 PM
11/01/21 12:03 PM
moparx Offline
moparx  Offline
i have made the "bubble" on many fuel lines, using a standard flaring tool, by simply starting a double flare and quitting when the "bubble" looked good to my eyes.
beer
Re: Flaring tubing problem [Re: moparx] #2980671
11/01/21 07:03 PM
11/01/21 07:03 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have the hydraulic flaring tool several have posted here. There is some stainless it simply will not do. Even adding a cheater bar to the clamp handle. Tube just slides. I have double flared some stainless tubing with it with no issue. Depends on the hardness of the tubing.
Doug
Re: Flaring tubing problem [Re: moparx] #2980672
11/01/21 07:03 PM
11/01/21 07:03 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
beer
I do the same to keep hoses from walking off & a place for the clamp to grip.
Re: Flaring tubing problem [Re: 71GTX471] #2980713
11/01/21 08:47 PM
11/01/21 08:47 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
X3 but will clarify, i put the clamp beyond the bubble, not on it beer
Re: Flaring tubing problem [Re: moparx] #2980761
11/01/21 11:51 PM
11/01/21 11:51 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
beer
Yep! Many times over many years!
Re: Flaring tubing problem [Re: Dcuda69] #2981427
11/03/21 06:07 PM
11/03/21 06:07 PM
5thAve Offline
5thAve  Offline
There some different brands and price is always changing but when I was having problems I bought one of these flaring tools and couldn't have been happier with it.
https://www.amazon.com/Titan-51515-Flaring-Tool/dp/B06XPRVCPV/?th=1
