Source for RV2 A/C Compeessor Rebuid Kit?
#2980224
10/31/21 01:03 PM
10/31/21 01:03 PM
Posts: 9,098 Rogue River, OR
Jeremiah
Rogue River, OR
Howdy,
I am in the process of reinstalling the air conditioning on our 66 Coronet 500. I would prefer to go through the compressor however I am not finding parts other than Classic Auto Air. Is there a better place to source these pars?
Thanks for any insight!
Re: Source for RV2 A/C Compeessor Rebuid Kit?
[Re: A12]
#2980317
10/31/21 05:45 PM
10/31/21 05:45 PM
Posts: 10,700 North Dakota
6PakBee
North Dakota
I see that the "Remanufactured compressors come with the R12/R134A/1234yf required O-rings /sealing washers to install the compressor" I didn't know that there were O-rings compatible with both R12 and R134A.
[Re: 6PakBee]
#2980534
11/01/21 12:26 PM
11/01/21 12:26 PM
Posts: 25,729 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I see that the "Remanufactured compressors come with the R12/R134A/1234yf required O-rings /sealing washers to install the compressor" I didn't know that there were O-rings compatible with both R12 and R134A. "A better type of O-ring for air conditioning applications is HNBR which stands for Hydrogenated NBR (sometimes called Hydrogenated Nitrile, or Highly Saturated Nitrile Rubber, or HNB). The compatibility of HNBR with Mineral oil, PAG, POE, R-12, R-134a, R-1234yf is very good. Another advantage is that its temperature range is -22F to 302F. They are green in color."
[Re: John_Kunkel]
#2980690
11/01/21 07:40 PM
11/01/21 07:40 PM
Posts: 1,893 Harriman NY
71GTX471
Harriman NY
Theres a complete RV2 on CL eastern NC $55
[Re: John_Kunkel]
#2980814
11/02/21 09:25 AM
11/02/21 09:25 AM
6PakBee
North Dakota
I see that the "Remanufactured compressors come with the R12/R134A/1234yf required O-rings /sealing washers to install the compressor" I didn't know that there were O-rings compatible with both R12 and R134A. "A better type of O-ring for air conditioning applications is HNBR which stands for Hydrogenated NBR (sometimes called Hydrogenated Nitrile, or Highly Saturated Nitrile Rubber, or HNB). The compatibility of HNBR with Mineral oil, PAG, POE, R-12, R-134a, R-1234yf is very good. Another advantage is that its temperature range is -22F to 302F. They are green in color." Thanks, John. I have an assortment of green A/C O-rings but I was under the impression that they were R-134A compatible only. Thanks again.
