Re: 318 Poly question
[Re: 6PakBee]
#2977585
10/23/21 01:56 PM
10/23/21 01:56 PM
Posts: 20,748 A collage of whims
topside
A collage of whims
Anyone contemplating building a Poly should pick up Victory Library's "Chrysler Poly Performance" - I think a member here wrote it but can't recall his name. It's a great resource & delves into a lot of stuff. I've had a few - '63, '64 & '65 318s - and they didn't seem very octane-sensitive to me, they'd run on anything. Not sure I'd worry much about improving quench. Then again, they were stockers, never pushed the CR, just drove them. Decent street motors, and not everything needs to make 600HP. They used heavier castings than LA is what I've heard, and metal costs money. Chrysler would do anything to save a buck. It's tempting to think "BBC" when looking at the valve arrangement, but ported Poly heads seem to max out at around 250/200 CFM I/E. Subtract about 50CFM each side for stock.
[Re: topside]
#2977608
10/23/21 03:13 PM
10/23/21 03:13 PM
Posts: 10,702 North Dakota
6PakBee
North Dakota
Anyone contemplating building a Poly should pick up Victory Library's "Chrysler Poly Performance" - I think a member here wrote it but can't recall his name. It's a great resource & delves into a lot of stuff. I've had a few - '63, '64 & '65 318s - and they didn't seem very octane-sensitive to me, they'd run on anything. Not sure I'd worry much about improving quench. Then again, they were stockers, never pushed the CR, just drove them. Decent street motors, and not everything needs to make 600HP. They used heavier castings than LA is what I've heard, and metal costs money. Chrysler would do anything to save a buck. It's tempting to think "BBC" when looking at the valve arrangement, but ported Poly heads seem to max out at around 250/200 CFM I/E. Subtract about 50CFM each side for stock. Thanks for the tip, just ordered the booklet.
[Re: 6PakBee]
#2977682
10/23/21 06:37 PM
10/23/21 06:37 PM
Posts: 43,517 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I just picked up a low mile 66 318 poly and 727 trans, my first ride was a 66 Satellite with a poly and I was always intrigued with it...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2977774
10/24/21 06:21 AM
10/24/21 06:21 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Huge commitment building a stroker Poly! A few (pre 66) friends have started and baled out, but one fine Moparmate has carried on through 'thick and thin'... Divorce, baliffs, forced to move house and no money for beer and Mopar Mags... Once you begin the POLY Project its for life, not just for Christmas...(10 years and counting) He laughs in the face of WEDGE heads now... But a trip to San Diego to see 'Gary Pavlovich' in person and he was struck dumb, with POLY POWER!!! It was a revelation and Epiphany all in one moment! He couldn't believe how folks has dissed the lowly Poly and how the head design was being used in modern V8 engines... Its like Betamax and VHS, the best product doesn't always win out? Its all about 'supply and demand'... 400 cfm Chev-head, can't be bad...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
[Re: 6PakBee]
#2979818
10/30/21 09:31 AM
10/30/21 09:31 AM
6PakBee
North Dakota
Have read the entire "Poly Performance" booklet over three times and there is one dimension I can't find. Is the center-center lifter bore spacing for a cylinder the same for the 318 poly as it is for an LA engine? Thanks!
[Re: 6PakBee]
#2979849
10/30/21 11:25 AM
10/30/21 11:25 AM
Posts: 6,560 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Have read the entire "Poly Performance" booklet over three times and there is one dimension I can't find. Is the center-center lifter bore spacing for a cylinder the same for the 318 poly as it is for an LA engine? Thanks! Yes. The reason the push rod angle for an LA is less than ideal is because the lifter location and angle was not changed. A Poly head can be run on an LA block with some minor modifications, external oil drains from the heads and pushrod clearancing the block. Kevin
