Help needed to identify a crankshaft #2977474
10/23/21 07:47 AM
10/23/21 07:47 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Looking for some help identifying a crankshaft. I'm pretty sure this is a Mopar big block forged crankshaft? However, I would like to know if there are some dimensions that I can quickly take with calipers to understand the current specs? Is there a spec sheet out there that helps enthusiasts?
Re: Help needed to identify a crankshaft [Re: vinnyd76] #2977501
10/23/21 09:08 AM
10/23/21 09:08 AM
A727Tflite Online content
A727Tflite  Online Content
All production rod journals for B/RB are around 2.375”. Mains for a RB are around 2.750”. For a B, 2.625”.
Both use 6 bolt flex plates. Hemi uses 8 bolt flex plate, same dimensions as the RB.
Re: Help needed to identify a crankshaft [Re: A727Tflite] #2977537
10/23/21 11:06 AM
10/23/21 11:06 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Thank you for the helpful info!
Re: Help needed to identify a crankshaft [Re: vinnyd76] #2977547
10/23/21 11:30 AM
10/23/21 11:30 AM
VA
dragon slayer Offline
VA
Stock stroke is 3.75. You can estimate the stroke also.
Re: Help needed to identify a crankshaft [Re: dragon slayer] #2979142
10/28/21 07:42 AM
10/28/21 07:42 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
I once asked if there were any way to tell by eye whether a crank is B or RB.
Dr Diff's reply.
"""If the rear main bearing journal is almost the same diameter as the rear main seal journal, you have an RB crank.
If the main bearing journal is noticeably smaller, you have a B crank."""
obviously need tools for accurate measuring, but that info came in handy when sorting through parts
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
