Re: Block
[Re: cesar perez]
#2978826
10/27/21 10:07 AM
10/27/21 10:07 AM
Posts: 13,319 Marion, South Carolina [><]
an8sec70cuda
GOOD question. From what I've heard, you need to look into other options. Indy or BMP/World for aluminum. Callies for cast iron.
Re: Block
[Re: jughed]
#2979096
10/27/21 11:34 PM
10/27/21 11:34 PM
Posts: 5,103 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Pick the phone up and call FHO or Best Machine and you will get an answer from people that would know. I get to look at a new KB raised cam block every time I go and work on the Cuda.
1971 HEMI E BODY REGISTRY
Re: Block EDITED 10/28/21
[Re: kwikblownhemi]
#2979117
10/28/21 01:37 AM
10/28/21 01:37 AM
Posts: 43,007 Bend,OR USA
Cab_Burge
Call them and ask them Then wait 2+ years for the block that will be shipped next week. They are advertising jackets now. i was told around 2 1/2 years when I ordered my standard deck 4.500 bore wedge block back in 2017, it was a little early (3 months) when it was delivered I had Tim do all the machine work by a shop near the foundry he uses here in the U.S. I've ended up with three race blocks now so I'm going to sell the KB motor ready to run and custom build it for the new owner, I have the B1 heads with Jesel paired shaft 1.70 ratio rocker arm system, cast single intake or I can build it with a custom made sheet metal dual 4500 Crab set up also, cam and compression ratio will be made for what the customer wants PM me on here or e mail me at cabburge@wans.net if your interested
Re: Block
[Re: FastmOp]
#2979133
10/28/21 07:04 AM
10/28/21 07:04 AM
Posts: 1,825 NW Indiana
fbs63
NW Indiana
My indy block has been great No reason not to use an Indy block. I know some people have had issues but if you did I'm sure they would take care of it now. I have used 4 or 5 and not had a problem.
