Re: Big Block valve cover ID
[Re: NITROUSN]
#2978412
10/25/21 10:21 PM
10/25/21 10:21 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
I am going to guess that they are 1964 vintage and possibly c-body. You can still get the parts. pcv Pretty sure '65 and up C body only had ONE big spark plug wire bracket on the passenger side rear only. If not '65, '67 to '68, plug wire routing and brackets changed in '69. No C bodies in '64.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#2978421
10/25/21 10:51 PM
10/25/21 10:51 PM
3hundred
Colleyville
I've changed my mind, now I think they're late '50's to '63.
[Re: hemienvy]
#2978434
10/26/21 12:12 AM
10/26/21 12:12 AM
3hundred
Colleyville
That's right, I missed the 6 bolt detail. So 1964 big car I guess?
[Re: AndyF]
#2978442
10/26/21 12:42 AM
10/26/21 12:42 AM
Posts: 9,092 Rogue River, OR
Jeremiah
Rogue River, OR
They are definitely sweptline era truck. I have a set that came off of a '68 W200 with a 383 2-barrel.
[Re: hemienvy]
#2978447
10/26/21 12:58 AM
10/26/21 12:58 AM
Jeremiah
Rogue River, OR
The breather slips off for an oil fill. They didn't add the oil fill cap until after the breather stands went away.
[Re: 3hundred]
#2978554
10/26/21 11:34 AM
10/26/21 11:34 AM
Posts: 18,389 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I am going to guess that they are 1964 vintage and possibly c-body. You can still get the parts. pcv Pretty sure '65 and up C body only had ONE big spark plug wire bracket on the passenger side rear only. If not '65, '67 to '68, plug wire routing and brackets changed in '69. No C bodies in '64. Ok no c-bodys. So how about 1964 chrysler with a 361 or a 383???.
