Bracket Racing Ramblings #2976842
10/21/21 02:05 PM
10/21/21 02:05 PM
SW Ohio
cgall Offline OP
cgall  Offline OP
SW Ohio
This season I went back to my old footbrake Duster, ran Pro Bracket at local track. Last year I retired and set a budget for racing, 12 races at local track, no travel, and new set of slicks. I only made it past the third round once all year, there are a lot of sharks racing at this track. Made 59 runs, had no breakage. Had a lot of fun just keeping it real simple, will do the same next year.
Won 19 rounds
Lost 17 rounds
Best ET 1/8th mile 6.503
Best ET 1/4 mile 10.310
Car is '72 Duster, ladder bar, 4.86 gear, 29 X 12.5 tire, pump gas 440 with Eddie heads, 727 manually shifted, weighs 2950 with driver.
Re: Bracket Racing Ramblings [Re: cgall] #2976844
10/21/21 02:14 PM
10/21/21 02:14 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Good for you! I wish those Eddy's were around when i wanted to upgrade waaay-back. They are a great alternative and keep things within there realistic limitations. Thanks for the update.
Re: Bracket Racing Ramblings [Re: HardcoreB] #2976851
10/21/21 02:32 PM
10/21/21 02:32 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Thing has got to be singing in the 1/4 with that steep gear
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Bracket Racing Ramblings [Re: B3422W5] #2976854
10/21/21 02:40 PM
10/21/21 02:40 PM
SW Ohio
cgall Offline OP
cgall  Offline OP
SW Ohio
Yes it does, starts banging 7200 chip about 30 feet out. They run 1/4 mile class once a month on Sundays, I entered it twice.
Re: Bracket Racing Ramblings [Re: B3422W5] #2976856
10/21/21 02:42 PM
10/21/21 02:42 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Its brutal these days. I struggled this year. The thousandths just never seemed to fall my way. I'm thinking I might try something new next year.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Bracket Racing Ramblings [Re: 69dart] #2976859
10/21/21 02:50 PM
10/21/21 02:50 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
I am leaving my muffs on this weekend and trying the street class. It would be nice to at least win a few rounds. My best et is exactly what yours is in the 1/8 . 3600 lb F Body small block with a ton of stroke. LOL
6.50 @105.26
Re: Bracket Racing Ramblings [Re: Kindafast] #2976889
10/21/21 04:40 PM
10/21/21 04:40 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
well you were out and racing . thats always good .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Bracket Racing Ramblings [Re: 69dart] #2976921
10/21/21 06:38 PM
10/21/21 06:38 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
You are 1 that I usually expect to go a lot farther than me. Lol
Keep up the good work
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
