A-body Glide trany mount #2974675
10/15/21 02:56 PM
10/15/21 02:56 PM
Indiana
dragracer1 Offline OP
Indiana
Hey ya'll, I have a 74 Scamp running the 408 that I am going from a 904 to a BTE Powerglide. Its already equipped the small block SFI bellhousing. But I still need the new trany mount. Im having troubles figuring out the best way to go about it. Any good reference pics to help a moparts brotha out would be AMAZING!!!
BP
Re: A-body Glide trany mount [Re: dragracer1] #2974769
10/15/21 09:10 PM
10/15/21 09:10 PM
okla.
sam64 Offline
sam64  Offline
okla.
I Made a cardboard pattern of crossmember bolt holes and used 3/8 plate steel cut to same shape as original crossmember the used 3/16 plate to make bracket for 2 bolt turbo 350 chevy mount.
Re: A-body Glide trany mount [Re: sam64] #2974913
10/16/21 11:01 AM
10/16/21 11:01 AM
PA
moparacer Offline
moparacer  Offline
PA
When I first put the glide in my Dart I used original crossmember, notched it and welded a piece of angle on it if I remember correctly. This was a big block though. I still might have it. Will look and take a pic and post it if I do.
Whatever you do just make sure you run a stock rubber mount on it. Nothing solid.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: A-body Glide trany mount [Re: moparacer] #2975218
10/17/21 06:40 AM
10/17/21 06:40 AM
Indiana
Indiana
GOOD STUFF FELLAS, THATS 2 GREAT IDEAS AND WELCOMED INFO!!
Re: A-body Glide trany mount [Re: dragracer1] #2975261
10/17/21 10:21 AM
10/17/21 10:21 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
This was in a 69 B body and th400 but maybe it will help.I have other pics I can find but let me know if you are interested. Here is a link to my post with pics if what I did. trans xmember mod link https://board.moparts.org/ubbthread...to-rb-in-69-b-body-info.html#Post2811941
Re: A-body Glide trany mount [Re: Clanton] #2975395
10/17/21 06:11 PM
10/17/21 06:11 PM
Indiana
Indiana
Excellent! Thank you a ton my friend!!!!
Re: A-body Glide trany mount [Re: dragracer1] #2975443
10/17/21 09:10 PM
10/17/21 09:10 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I am glad it will help someone.I held the trans up with an ATV jack while I kept test fitting.If you have a question just ask not that mine is anything special.
