Anyone have this problem (electrical) #2974792
10/15/21 10:03 PM
10/15/21 10:03 PM
MA
BH27G1B Online content OP
BH27G1B  Online Content OP
MA
This afternoon I took 2 of my cars for a ride before putting them away for the winter. The first was a '71 Cuda 340. It ran great for about 3 miles, started running rough, then died. After I got it (hauled) back to my yard I replaced the ballast resistor, then it would start..then die. The next car was my 69.5 Superbee. That car ran good, then when I rolled into my driveway, it died also. Same deal...it would start, then die and not run. I happen to try the Cuda after 1/2 hr, it started and ran good. I went back to the Bee and noticed the ballast resistor was hot, put on a used one, and after a few tries got it to run enough to get out back to my building..then it died again. Not until I put in an old ballast resistor, would it run enough, fairly rough, but I got it in the building. Any thoughts ?
Re: Anyone have this problem (electrical) [Re: BH27G1B] #2974813
10/15/21 10:54 PM
10/15/21 10:54 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
ignition coil overheated perhaps?
happened to me on my truck once after i messed around with the ballast resistor.
Re: Anyone have this problem (electrical) [Re: BH27G1B] #2974814
10/15/21 10:56 PM
10/15/21 10:56 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
First thing is that ballast resistors are suposed to be hot so doesn't give you much of a clue.
Re: Anyone have this problem (electrical) [Re: stumpy] #2974831
10/16/21 12:36 AM
10/16/21 12:36 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Pretty strange for two cars to have the same issue at the same time. I have to wonder if the problem isn't gas related and the ballast was just a fluke that gave the gas issue enough time to run a bit more. Have you bought gas for both at the same time recently? maybe you got some bad gas the last time. The next thought is about the opposite, the current swill they sell as gas doesn't have a very long shelf life anymore, is the gas in both cars more then 6 months old?
Re: Anyone have this problem (electrical) [Re: BH27G1B] #2974833
10/16/21 12:44 AM
10/16/21 12:44 AM
The ballast "resistor" is a wire wound resistor design the reduce the voltage to the coil, as it gets hotter the resistance goes up and reduces the voltage to the positive side of the coil even more.
Mopar engineers design the wiring to the ballast resistor to have a 12 volt bypass on the starter circuit to provide 12 volts to the coil in the start position only, bypassing the ballast resistor to help the motor start quicker and better, hot or cold up scope
Re: Anyone have this problem (electrical) [Re: poorboy] #2974870
10/16/21 08:37 AM
10/16/21 08:37 AM
MA
MA
It was strange that both cars did that. I've been using race gas in all the cars for a few years now, since they don't get driven too often.
Re: Anyone have this problem (electrical) [Re: BH27G1B] #2974875
10/16/21 08:48 AM
10/16/21 08:48 AM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
I have been using VP Vintage 98 on the cars I do not drive often. After some time I went to start my Cuda. It started and then stalled, I tried that a few times. Start and quit. I remove all the gas and put new gas in and then after a few times trying to start it finally stayed running. So bad gas was the problem. Even when VP said it lasts two years.
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Anyone have this problem (electrical) [Re: Cab_Burge] #2974876
10/16/21 08:50 AM
10/16/21 08:50 AM
MA
MA
I always toss out resistors that failed in the past, but keep used older ones that were fine back then, if I happen to replace them with new ones while diagnosing other failing electrical components. I wonder if the older used ballast resistors have a "usefull" life expectancy. Every one I tried yesterday was one that I kept as a spare, not brand new......
Re: Anyone have this problem (electrical) [Re: BH27G1B] #2974907
10/16/21 10:54 AM
10/16/21 10:54 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The old recipe still holds, spark, fuel, and squeeze. I agree that it sounds like fuel. What's the gas smell and look like?
Re: Anyone have this problem (electrical) [Re: 6PakBee] #2974910
10/16/21 10:58 AM
10/16/21 10:58 AM
MA
MA
Race fuel, that's what I have been using for years....no pump gas.
Re: Anyone have this problem (electrical) [Re: BH27G1B] #2974914
10/16/21 11:02 AM
10/16/21 11:02 AM
central il.
second 70 Offline
second 70  Offline
central il.
With it being both cars I'd guess gas. All gas even race gas can go bad.
Re: Anyone have this problem (electrical) [Re: second 70] #2974926
10/16/21 11:36 AM
10/16/21 11:36 AM
MA
MA
Yes, the race gas is a few years old, but it's strange that a different ballast resistor will allow them to run... I'll put in fresh race fuel after removing the gas in them ....next spring. Plus, other cars I have still run fine on the same race gas...strange...maybe it's just a matter of time before it effects them also. I'll try fresh fuel, and new resistors.
Re: Anyone have this problem (electrical) [Re: BH27G1B] #2974951
10/16/21 12:18 PM
10/16/21 12:18 PM
MA
MA
Thanks for all your input. I agree....Replace and add fresh fuel, and I think a new ballast resistor won't hurt , as possibly a better one that is on the cars gave a stronger spark and allowed it to run for a short while.
Re: Anyone have this problem (electrical) [Re: BH27G1B] #2974954
10/16/21 12:31 PM
10/16/21 12:31 PM
central il.
second 70 Offline
second 70  Offline
central il.
These are old cars and sometimes it's because of what crud or chemicals that have accumulated in the tanks over the years and got broken down over time. The longer the fuel is in the tank the worse it gets. The cars will start and run fine on what gas was in the carb but when they get the stale gas from the tank the problems start. If it was the ballast they would run fine after you replaced them.
Re: Anyone have this problem (electrical) [Re: second 70] #2974959
10/16/21 12:38 PM
10/16/21 12:38 PM
Kirkland, Washington
Pacnorthcuda Offline
Check the bulkhead connection on both cars. It’s a poor design that commonly fails on these cars as they age. The ignition power is fed though male and female spade fittings that corrode and get hot. Look for damage. Clean, and make sure they are making a tight connection.
Re: Anyone have this problem (electrical) [Re: Pacnorthcuda] #2974989
10/16/21 01:41 PM
10/16/21 01:41 PM
MA
MA
That's another thing I was considering, and will check and clean the connections on both cars. Thanks !
Re: Anyone have this problem (electrical) [Re: Pacnorthcuda] #2975167
10/16/21 09:44 PM
10/16/21 09:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
Re: Anyone have this problem (electrical) [Re: Pacnorthcuda] #2976334
10/19/21 11:52 PM
10/19/21 11:52 PM
Dandridge TN
Dabee Online content
Dabee  Online Content
Dandridge TN
My 69 Super Bee had that problem. When it would stall the first thing I did was unplug the bull head connector and plug it back in. It would start right up. I finally bypassed the connector and never had the problem again.
Re: Anyone have this problem (electrical) [Re: Dabee] #2976358
10/20/21 05:18 AM
10/20/21 05:18 AM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
Points and condenser or electronic ignition? I can't remember what year points were replaced by electronic. I found that if a points dizzy is exposed to humidity, the points cam gets a light flash of rust and it become abrasive on the cam follower. As the engine runs, the cam follower wears away closing the points adjustment. Remember that little felt pad in the distributor? Its job was to keep a little lube and rust preventative on the cam. Just a thought and my twocents
Copper
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Anyone have this problem (electrical) [Re: BH27G1B] #3041950
05/13/22 09:04 AM
05/13/22 09:04 AM
MA
MA
UPDATE
I installed new ballast resistors on both cars and had no problems while taking them both for a ride.......so far.
