Anyone have this problem (electrical)
#2974792
10/15/21 10:03 PM
10/15/21 10:03 PM
Posts: 410 MA
BH27G1B
MA
This afternoon I took 2 of my cars for a ride before putting them away for the winter. The first was a '71 Cuda 340. It ran great for about 3 miles, started running rough, then died. After I got it (hauled) back to my yard I replaced the ballast resistor, then it would start..then die. The next car was my 69.5 Superbee. That car ran good, then when I rolled into my driveway, it died also. Same deal...it would start, then die and not run. I happen to try the Cuda after 1/2 hr, it started and ran good. I went back to the Bee and noticed the ballast resistor was hot, put on a used one, and after a few tries got it to run enough to get out back to my building..then it died again. Not until I put in an old ballast resistor, would it run enough, fairly rough, but I got it in the building. Any thoughts ?
Re: Anyone have this problem (electrical)
[Re: poorboy]
#2974870
10/16/21 08:37 AM
10/16/21 08:37 AM
Posts: 410 MA
BH27G1B
MA
Pretty strange for two cars to have the same issue at the same time. I have to wonder if the problem isn't gas related and the ballast was just a fluke that gave the gas issue enough time to run a bit more. Have you bought gas for both at the same time recently? maybe you got some bad gas the last time. The next thought is about the opposite, the current swill they sell as gas doesn't have a very long shelf life anymore, is the gas in both cars more then 6 months old? It was strange that both cars did that. I've been using race gas in all the cars for a few years now, since they don't get driven too often.
[Re: BH27G1B]
#2974875
10/16/21 08:48 AM
10/16/21 08:48 AM
Posts: 2,368 White Plains, NY
VCODE
White Plains, NY
Pretty strange for two cars to have the same issue at the same time. I have to wonder if the problem isn't gas related and the ballast was just a fluke that gave the gas issue enough time to run a bit more. Have you bought gas for both at the same time recently? maybe you got some bad gas the last time. The next thought is about the opposite, the current swill they sell as gas doesn't have a very long shelf life anymore, is the gas in both cars more then 6 months old? It was strange that both cars did that. I've been using race gas in all the cars for a few years now, since they don't get driven too often. I have been using VP Vintage 98 on the cars I do not drive often. After some time I went to start my Cuda. It started and then stalled, I tried that a few times. Start and quit. I remove all the gas and put new gas in and then after a few times trying to start it finally stayed running. So bad gas was the problem. Even when VP said it lasts two years. Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: BH27G1B]
#2974907
10/16/21 10:54 AM
10/16/21 10:54 AM
Posts: 10,702 North Dakota
6PakBee
North Dakota
The old recipe still holds, spark, fuel, and squeeze. I agree that it sounds like fuel. What's the gas smell and look like?
[Re: 6PakBee]
#2974910
10/16/21 10:58 AM
10/16/21 10:58 AM
Posts: 410 MA
BH27G1B
MA
The old recipe still holds, spark, fuel, and squeeze. I agree that it sounds like fuel. What's the gas smell and look like? Race fuel, that's what I have been using for years....no pump gas.
[Re: second 70]
#2974926
10/16/21 11:36 AM
10/16/21 11:36 AM
Posts: 410 MA
BH27G1B
MA
With it being both cars I'd guess gas. All gas even race gas can go bad. Yes, the race gas is a few years old, but it's strange that a different ballast resistor will allow them to run... I'll put in fresh race fuel after removing the gas in them ....next spring. Plus, other cars I have still run fine on the same race gas...strange...maybe it's just a matter of time before it effects them also. I'll try fresh fuel, and new resistors.
[Re: BH27G1B]
#2974954
10/16/21 12:31 PM
10/16/21 12:31 PM
Posts: 1,696 central il.
second 70
central il.
With it being both cars I'd guess gas. All gas even race gas can go bad. Yes, the race gas is a few years old, but it's strange that a different ballast resistor will allow them to run... I'll put in fresh race fuel after removing the gas in them ....next spring. Plus, other cars I have still run fine on the same race gas...strange...maybe it's just a matter of time before it effects them also. I'll try fresh fuel, and new resistors. These are old cars and sometimes it's because of what crud or chemicals that have accumulated in the tanks over the years and got broken down over time. The longer the fuel is in the tank the worse it gets. The cars will start and run fine on what gas was in the carb but when they get the stale gas from the tank the problems start. If it was the ballast they would run fine after you replaced them.
[Re: Pacnorthcuda]
#2974989
10/16/21 01:41 PM
10/16/21 01:41 PM
Posts: 410 MA
BH27G1B
MA
Check the bulkhead connection on both cars. It’s a poor design that commonly fails on these cars as they age. The ignition power is fed though male and female spade fittings that corrode and get hot. Look for damage. Clean, and make sure they are making a tight connection. That's another thing I was considering, and will check and clean the connections on both cars. Thanks !
[Re: Pacnorthcuda]
#2976334
10/19/21 11:52 PM
10/19/21 11:52 PM
Posts: 3,426 Dandridge TN
Dabee
Dandridge TN
Check the bulkhead connection on both cars. It’s a poor design that commonly fails on these cars as they age. The ignition power is fed though male and female spade fittings that corrode and get hot. Look for damage. Clean, and make sure they are making a tight connection. My 69 Super Bee had that problem. When it would stall the first thing I did was unplug the bull head connector and plug it back in. It would start right up. I finally bypassed the connector and never had the problem again.
[Re: Dabee]
#2976358
10/20/21 05:18 AM
10/20/21 05:18 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
Points and condenser or electronic ignition? I can't remember what year points were replaced by electronic. I found that if a points dizzy is exposed to humidity, the points cam gets a light flash of rust and it become abrasive on the cam follower. As the engine runs, the cam follower wears away closing the points adjustment. Remember that little felt pad in the distributor? Its job was to keep a little lube and rust preventative on the cam. Just a thought and my Copper
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
