Could they put the oil filter in any worse place possible #2974710
10/15/21 05:31 PM
10/15/21 05:31 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Holy Chit. What a royal pain in the buttocks to get that filter out.
Cummins diesel in a ram truck
Re: Could they put the oil filter in any worse place possible [Re: Sammy] #2974713
10/15/21 05:44 PM
10/15/21 05:44 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
What Year DODGE ? and which engine , 5.9 12 valve , 5.9 24 valve , 6.7 ? drive
Re: Could they put the oil filter in any worse place possible [Re: Sammy] #2974736
10/15/21 07:16 PM
10/15/21 07:16 PM
Guitar Jones Offline
They aren't that bad, but to answer your question, yes, yes they could.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Could they put the oil filter in any worse place possible [Re: Guitar Jones] #2974739
10/15/21 07:20 PM
10/15/21 07:20 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
If you have the oil filter tool that fits over the bottom of the filter and a long extension, it's not that bad. 2010 Dodge Cummins. Change the oil filter on one of the first generation Hemi's and you'll think that Cummins is a walk in the park.
Re: Could they put the oil filter in any worse place possible [Re: 6PakBee] #2974839
10/16/21 01:14 AM
10/16/21 01:14 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I take all the air hoses off to the turbo, easier to get to then. But my 92 and 06 are a pain no doubt
Re: Could they put the oil filter in any worse place possible [Re: cudaman1969] #2974855
10/16/21 07:03 AM
10/16/21 07:03 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I think they are in the same spot for all for all of the Cummins motors that came in the dodge trucks? Not super easy for sure, but not the hardest I have ever changed.
68 Barracuda Formula S 340
Re: Could they put the oil filter in any worse place possible [Re: Bad340fish] #2974912
10/16/21 11:00 AM
10/16/21 11:00 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Doing a Cummins up to a 2013 isn't a problem at all, the filter drops straight down without spilling. When they changed the frame in 2014, the crossmember under the motor got wider so no more dropping the filter straight down, now you have to pull it out the side while tipping it so it spills oil. You can buy a cap to cover the old filter so it doesn't spill.
Re: Could they put the oil filter in any worse place possible [Re: hemi70se] #2975150
10/16/21 08:27 PM
10/16/21 08:27 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Just installed a remote mount oil filter mount goes between wheel well plastic and front bumper makes it a lot easier to change filter. 2019 6.7
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Could they put the oil filter in any worse place possible [Re: Savoy1964] #2975175
10/16/21 09:58 PM
10/16/21 09:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
3.2 V6 is a nasty one to change the oil filter on.
Re: Could they put the oil filter in any worse place possible [Re: hemi70se] #2975244
10/17/21 09:26 AM
10/17/21 09:26 AM
I just loosen the filter, put a plastic bag around it then spin it off. No fuss, no mess.
Re: Could they put the oil filter in any worse place possible [Re: Guitar Jones] #2975427
10/17/21 07:44 PM
10/17/21 07:44 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
My 2004 Dodge is easy to change the filter on. The fuel filter can piss me off if my 5 gallon bucket I stand on to do it flies out from under my feet! laugh2
Re: Could they put the oil filter in any worse place possible [Re: JDMopar] #2979095
10/27/21 11:26 PM
10/27/21 11:26 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Don't work on many now that we are a Alfa/Fiat dealer. If I remember I do them though the fender well.
Re: Could they put the oil filter in any worse place possible [Re: JDMopar] #2979149
10/28/21 08:33 AM
10/28/21 08:33 AM
an8sec70cuda Offline
Just laughed out loud when I read this! laugh2
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Could they put the oil filter in any worse place possible [Re: Sammy] #2979310
10/28/21 04:57 PM
10/28/21 04:57 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Try a Liberty 4x4 with the 3.7
Coming soon!!!!
Re: Could they put the oil filter in any worse place possible [Re: an8sec70cuda] #2979337
10/28/21 06:20 PM
10/28/21 06:20 PM
JDMopar Offline
JDMopar  Offline
bow laugh2 It's a 4WD...not lifted or even big tires. I'm 6' tall, and can reach it easily standing on the upside down bucket.......till it ain't there anymore! rant
Re: Could they put the oil filter in any worse place possible [Re: JDMopar] #2979407
10/28/21 09:21 PM
10/28/21 09:21 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
13 and newer…. Throw 4 shop rags below filter. Remove filter and lower onto bed of rags. Spin block off tool on filter. Tip and remove filter.
https://www.napaonline.com/en/p/SER57180?cid=paidsearch_shopping_dcoe_google_monthly-special_202110
Re: Could they put the oil filter in any worse place possible [Re: J_BODY] #2979506
10/29/21 08:37 AM
10/29/21 08:37 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have a 2004 3500 Ram with a CTD. I just changed my oil last weekend. As mentioned filter wrench that caps the end of the filter and a long extension or 2 and it is simple to spin off and drops straight down.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Could they put the oil filter in any worse place possible [Re: 6PKRTSE] #2982234
11/05/21 10:35 PM
11/05/21 10:35 PM
Same deal on my 2006 Ram 3500 4x4 up
I fill the new filter up(it takes 4 or 5 times filling it and letting the oil soak in until it won't take anymore scope up) before installing it to make sure of no dry starts also up scope
Re: Could they put the oil filter in any worse place possible [Re: Mr.Yuck] #3001769
01/03/22 09:56 PM
01/03/22 09:56 PM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
Yes sir! The engineer that come up with that idea should be punched squarely in the jaw! If you have chick hands it might not be bad but if you're anybody that's anywhere near an average size person forget about it it's a pain!
Re: Could they put the oil filter in any worse place possible [Re: V10nacuda] #3002265
01/05/22 12:54 PM
01/05/22 12:54 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Cup style filter socket and a long extension is the best way I have found. for the liberty 3.7
