Re: Could they put the oil filter in any worse place possible
[Re: Sammy]
#2974736
10/15/21 07:16 PM
10/15/21 07:16 PM
Guitar Jones
They aren't that bad, but to answer your question, yes, yes they could.
[Re: Guitar Jones]
#2974739
10/15/21 07:20 PM
10/15/21 07:20 PM
Posts: 10,721 North Dakota
6PakBee
North Dakota
If you have the oil filter tool that fits over the bottom of the filter and a long extension, it's not that bad. 2010 Dodge Cummins. Change the oil filter on one of the first generation Hemi's and you'll think that Cummins is a walk in the park.
[Re: cudaman1969]
#2974855
10/16/21 07:03 AM
10/16/21 07:03 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I think they are in the same spot for all for all of the Cummins motors that came in the dodge trucks? Not super easy for sure, but not the hardest I have ever changed.
68 Barracuda Formula S 340
[Re: hemi70se]
#2975150
10/16/21 08:27 PM
10/16/21 08:27 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
Just installed a remote mount oil filter mount goes between wheel well plastic and front bumper makes it a lot easier to change filter. 2019 6.7
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: hemi70se]
#2975244
10/17/21 09:26 AM
10/17/21 09:26 AM
Guitar Jones
Doing a Cummins up to a 2013 isn't a problem at all, the filter drops straight down without spilling. When they changed the frame in 2014, the crossmember under the motor got wider so no more dropping the filter straight down, now you have to pull it out the side while tipping it so it spills oil. You can buy a cap to cover the old filter so it doesn't spill. I just loosen the filter, put a plastic bag around it then spin it off. No fuss, no mess.
[Re: JDMopar]
#2979095
10/27/21 11:26 PM
10/27/21 11:26 PM
Posts: 858 Southeast Pa.
SALEM1912
Southeast Pa.
Don't work on many now that we are a Alfa/Fiat dealer. If I remember I do them though the fender well.
[Re: JDMopar]
#2979149
10/28/21 08:33 AM
10/28/21 08:33 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
My 2004 Dodge is easy to change the filter on. The fuel filter can piss me off if my 5 gallon bucket I stand on to do it flies out from under my feet! Just laughed out loud when I read this!
[Re: J_BODY]
#2979506
10/29/21 08:37 AM
10/29/21 08:37 AM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I have a 2004 3500 Ram with a CTD. I just changed my oil last weekend. As mentioned filter wrench that caps the end of the filter and a long extension or 2 and it is simple to spin off and drops straight down.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#2982234
11/05/21 10:35 PM
11/05/21 10:35 PM
Posts: 43,191 Bend,OR USA
Cab_Burge
I have a 2004 3500 Ram with a CTD. I just changed my oil last weekend. As mentioned filter wrench that caps the end of the filter and a long extension or 2 and it is simple to spin off and drops straight down. Same deal on my 2006 Ram 3500 4x4 I fill the new filter up(it takes 4 or 5 times filling it and letting the oil soak in until it won't take anymore ) before installing it to make sure of no dry starts also
[Re: Mr.Yuck]
#3001769
01/03/22 09:56 PM
01/03/22 09:56 PM
Posts: 767 NW PA
V10nacuda
NW PA
Try a Liberty 4x4 with the 3.7 Yes sir! The engineer that come up with that idea should be punched squarely in the jaw! If you have chick hands it might not be bad but if you're anybody that's anywhere near an average size person forget about it it's a pain!
[Re: V10nacuda]
#3002265
01/05/22 12:54 PM
01/05/22 12:54 PM
Posts: 1,990 Apollo, PA.
B1MAXX
Apollo, PA.
Cup style filter socket and a long extension is the best way I have found. for the liberty 3.7
