Page 2 of 3 1 2 3
SOLD!!! TCI SFI Small Block Flexplate [Re: moparts] #2972061
10/08/21 02:01 PM
10/08/21 02:01 PM
Indiana
dragracer1 Offline
dragracer1  Offline
Indiana
SOLD!!!
THANKS MOPARTS x2
I KNOW THAT IF I HAVE SOMETHING RACE RELATED, I CAN GUARANTEE TO SELL IT HERE ON MOPARTS.COM!!!
.TCI SFI Flexplate for 904/727. Part number 145200
3 years old, but still less than 50 passes on it.
Summit: $94.00
Mine: $25.00 + Shipping from 47715
PM me if interested
Small Block Rocker Arm Shafts for Adjustable Rockers - New [Re: dragracer1] #2972635
10/10/21 11:11 AM
10/10/21 11:11 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a new set of small block Mopar rocker arm shafts for LA type cylinder heads. These shafts are made here in the U.S.. They are made from thick induction hardened steel. They feature banana groves and oiling holes that are positioned for the loading of mechanical rocker arms. These shafts have screw in end plugs for inspection and easy cleaning, inspection or if desired to plumb in an oil line. These are drilled on center for 5/16” hold down bolts and are for use with stock small block Mopar heads (273, 318, 340 & 360) or aftermarket cylinder heads including Edelbrock RPM, Indy LAX or other similar shaft mounted cylinder heads where mechanical rocker arms are being used. These are not intended for W2 or W5 heads that use offset drilled shafts and stands.
These shafts will provide the proper oiling to high load areas for adjustable iron and aluminum adjustable rocker arms to minimize wear and maximize performance and parts life. They are far thicker and stiffer than stock or may aftermarket shafts to minimize flex with stiffer aftermarket valve springs.
Price is $180 for the pair shipped within the lower 48 states. I can ship internationally for the additional shipping cost.
Contact procketrichard@hotmail.com for more information and pictures.
SB Shafts Pic 6.jpg (651 downloads)
Mopar Performance Small Block Pistons - New Incomplete Sets [Re: Rocket] #2972637
10/10/21 11:17 AM
10/10/21 11:17 AM
CT
Rocket Offline
Rocket  Offline
CT
I have 12 new Mopar Performance forged flat top pistons and pins. There are 3 different part numbers. There is not one complete set. Here is what I have.
P4876976 – Quantity of 6. Specs are 4.060” bore & ~ 1.67” compression height. These pistons are for a 0.060” overbore 360 with the stock stroke crankshaft or a 0.020” overbore 340 using a 3.58 stroke crankshaft.
Price for the 6 new forged pistons is $350 shipped.
P4876978 – Quantity of 4. Specs are 4.030” bore and ~ 1.67” compression height, These pistons are for a 0.030” overbore 360 with the stock stroke crankshaft
Price for the 4 new forged pistons is $220 plus shipped.
P5007413 – Quantity of 2. Specs are 4.030” bore and ~ 1.47” compression height, These pistons are for a 0.030” overbore 360 with a 4.00” stroke crankshaft.
Price for the 2 new forged pistons is $120 shipped.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
Small Block KB 745 Forged Pistons 4.030 Bore for 4” stroke [Re: Rocket] #2972638
10/10/21 11:20 AM
10/10/21 11:20 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a nice used set of Keith Black dished Forged pistons and pins for a 4.000” stroke crankshaft. Pistons were used for one summer as a mild street build. Engine was rebuilt the following summer into a bracket racing focused application including new pistons, new cam, …
Pistons were used for ~ 500 street miles. They have been fully cleaned and the skirts lightly glass beaded. One piston had some skirt scuffing and has been replaced with a new piston.
Piston specs are as follows:
Bore 4.030 in.
Stroke: 4.000 in.
Rod Length: 6.123 in.
Piston Style: Step head, with two valve reliefs
Piston Material: Forged aluminum
Compression Height (in.): 1.465 in.
Piston Head Volume (cc): +20.50cc
Wrist Pin Style: Press-fit or floating
Pin Diameter (in.): 0.984 in.
Piston Ring Thickness: 1/16 in. x 1/16 in. x 3/16 in.
Compression ratio with a 65CC chamber, head gasket compressed thickness of 0.040 and installed at 0.0 deck height will be ~ 9.90 to one.
Price is $450 plus shipping cost.
Moroso Replace Water Pump Belt 97230 - New [Re: Rocket] #2972640
10/10/21 11:23 AM
10/10/21 11:23 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a new replacement water pump belt for the Moroso remote mount electric water pump #63750. Part number of the belt is 97230.
Price is $17 shipped in the lower 48 states.
Moroso WP belt Pic 1.jpg (656 downloads)
Moroso WP belt Pic 2.jpg (653 downloads)
Edelbrock Elite 10” Air Cleaner - New [Re: Rocket] #2972642
10/10/21 11:30 AM
10/10/21 11:30 AM
CT
Rocket Offline
Rocket  Offline
CT
This is a new Edelbrock Elite 10” air cleaner part # 4210 and 2” paper element.
Price is $70 plus shipping.
Eddy Air Ceaner 1.jpeg (649 downloads)
Eddy Air Ceaner 2.jpeg (652 downloads)
Eddy Air Ceaner 3.jpeg (651 downloads)
Electric Fan & Controller [Re: Rocket] #2972644
10/10/21 11:33 AM
10/10/21 11:33 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a used electric fan and controller. The parts are in nice shape. Overall measurements are 16.75" x 16.25" x 4.0". The fan blades themselves are 15" diameter.
AutoMeter Ultra Lite 5” Tachometer - New [Re: Rocket] #2972647
10/10/21 11:36 AM
10/10/21 11:36 AM
CT
Rocket Offline
Rocket  Offline
CT
AutoMeter Ultra Lite 5” tachometer with shift line part # 3911 new in the box.
see link for all details
AutoMeter 3911 AutoMeter Ultra-Lite Analog Gauges | Summit Racing
Price is $260 shipped in the lower 48 states.
Autometer Tach 1.jpeg (741 downloads)
Autometer Tach 2.jpeg (738 downloads)
904 RACE BUILT TRANS - $600 - OBO [Re: birdtracker] #2972722
10/10/21 03:12 PM
10/10/21 03:12 PM
Indiana
dragracer1 Offline
dragracer1  Offline
Indiana
Complete 904 Race Prepped transmission (minus valve body). Built for small block transbrake bracket motor. Only garage run time since rebuild. Its got all the good stuff. TCI case, new deep pan. 2.74 low gear, A &A front pump. Premium bands, clutches.
[i]Exact same setup went 5.90's behind my brothers 415 Challenger and won 20 Grand in 2 years, so a good/very consistent setup to say the least.
$600.00 OBO - NO SHIPPING - LOCATED IN SOUTHERN INDIANA.
PM ME IF INTERESTED
904 COMPLETE EMPTY CASE - REDUCED [Re: moparts] #2972779
10/10/21 06:31 PM
10/10/21 06:31 PM
Indiana
dragracer1 Offline
dragracer1  Offline
Indiana
COMPLETE 904 CASE. Includes Case, extension housing, deep pan (dinged up). CASE/HOUSING IN EXCELLENT CONDITION!!...JUST NEEDS A GOOD COAT OF PAINT.
$250.00 + SHIPPING FROM 47715
$225.00 + SHIPPING FROM 47715.
$165.00 + SHIPPING FROM 47715.
PM me if interested.
MSD stuff [Re: dragracer1] #2972942
10/11/21 10:06 AM
10/11/21 10:06 AM
an8sec70cuda Offline
Happy Birthday an8sec70cuda  Offline
MSD 8972 3 step retard box. Old, but works just as it should. Comes w/ 2 sets of retard modules ($60+ new) from 2 to 14 degrees I believe. The modules themselves are inaccurate, so just verify the timing being pulled.
$110 shipped to the lower 48.
Email me at owensjc@scdot.org
You can PM me here, but I only check in here during the week.
paypal accepted if you cover the fee.
msd 8972-2.jpg (728 downloads)
msd 8972-1.jpg (725 downloads)
CHIP
'70 hemicuda...8 sec street car
'69 road runner 440 w/ Indy SRs
'69 road runner 440-6, 4 speed...Dad's ride
'71 Demon 340 resto project
'06 GMC 2500HD LBZ Duramax...toy hauler
'16 Grand Caravan SXT...baby hauler
Re: MSD stuff [Re: an8sec70cuda] #2972943
10/11/21 10:08 AM
10/11/21 10:08 AM
sold, thanks!
CHIP
piston rings [Re: an8sec70cuda] #2972947
10/11/21 10:13 AM
10/11/21 10:13 AM
Hastings 4.280" bore ring set. Part number 2M 5519 030
These are not file fit, 1/16", 1/16", 3/16", std tension
The box has been opened, but they were never installed.
$70 shipped
rings 3.jpg (724 downloads)
CHIP
Re: piston rings [Re: an8sec70cuda] #2972948
10/11/21 10:16 AM
10/11/21 10:16 AM
[b][/b]PBM ring set for 4.31" bore. Part number PS 14310 DS
$70 shipped
rings 1.jpg (722 downloads)
CHIP
Re: For Sale - Race Parts - 4th Quarter [Re: moparts] #2973173
10/11/21 09:45 PM
10/11/21 09:45 PM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
Blower Drive Service "BDS" RB 440 Polished Aluminum Blower intake manifold with gaskets, brand new, never been installed on an engine $900.00 (708) 288-2879
parts 10-11-2021 023.JPG (611 downloads)
parts 10-11-2021 027.JPG (611 downloads)
parts 10-11-2021 014.JPG (611 downloads)
parts 10-11-2021 029.JPG (610 downloads)
Re: For Sale - Race Parts - 4th Quarter [Re: dsd70bee] #2973293
10/12/21 07:47 AM
10/12/21 07:47 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Gen III Hemi T&D 8360 rockers.
New in the box. $3000
Save $200 and the 8 week wait.
Pm here.
Re: For Sale - Race Parts - 4th Quarter [Re: moparts] #2973397
10/12/21 12:37 PM
10/12/21 12:37 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
All High Performance Parts:
Vintage M/T + Holley Aluminum Valve Covers $150pr,
New Big Block Mopar Performance Aluminum Waterpump Housing $175,
Holley Dominator Carb #4575 $385,
Holley 750 Cfm Double Pumper Carb #4779 $265,
New Mopar Performance Small Block Electronic Ignition Kit $185,
New Mopar Performance E-Body + 71-4 B-Body Offset Front Spring Hangers #4120080 $45pr,
Vintage Lakewood “Traction Action” Traction Bars $70pr,
New Lakewood Driveshaft Loop #18000, In Box $40,
New Mopar Performance P4529436 B/E-Body Big Block Headers + Collectors, 1-3/4” Tube, 3” Collectors $140
tonysparts.com
302-398-0821,
tonymopar@aol.com
Tonys Parts
Harrington Delaware 19952
Reverse pattern push button 727 transmission [Re: TONY_DAGOSTINO] #2973512
10/12/21 02:30 PM
10/12/21 02:30 PM
New Jersey
Dartforforty Online content
Dartforforty  Online Content
New Jersey
Transmission was behind a 499 RB engine. Comes complete with 9 inch 4500-4800 stall torque converter, push button cables, and locking dip stick tube. Deep pan with drain plug. Has about 30 quarter mile runs since freshened. This transmission was converted to a slip yoke. $1200.00
Pick up only in Millstone Twsp New Jersey PM me through the board for more information
Ed
STAR Vacuum Tank [Re: dragracer1] #2974096
10/13/21 07:56 PM
10/13/21 07:56 PM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
STAR Oil/ Air Seperator Tank
Like New.
$200 plus the ride
Blacklick, OH
Casey FJ
Re: For Sale - Race Parts - 4th Quarter [Re: moparts] #2974171
10/13/21 10:55 PM
10/13/21 10:55 PM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
1 Pr. Mickey Thompson "M/T" cast aluminum 426 HEMI valve covers, these are for the 1964 & 1965 K-heads, not street HEMI, excellent used condition, no damage or modifications $750.00 for the Pr. (708) 288-2879
parts 10-13-2021 027.JPG (269 downloads)
parts 10-13-2021 036.JPG (270 downloads)
parts 10-13-2021 032.JPG (270 downloads)
parts 10-13-2021 040.JPG (271 downloads)
Page 2 of 3 1 2 3
