440 backfires #2973729
10/12/21 09:59 PM
10/12/21 09:59 PM
Buckle of corn belt ,c. lll.
420SIX Offline OP
420SIX  Offline OP
Original 440 w/70 k on it. Seems to be one cylinder backfires through the carb and exhaust. Does so intermittently. Compression 120 in all cylinders. Thinking valves are hanging up ? Worn guides ?
Re: 440 backfires [Re: 420SIX] #2973753
10/12/21 11:26 PM
10/12/21 11:26 PM
New York, USA
Chargerfan68 Offline
New York, USA
I’ve had backfire on exh side only….turned out to be broken valve spring. But, you have both int and ex backfiring.
Re: 440 backfires [Re: 420SIX] #2973773
10/13/21 02:08 AM
10/13/21 02:08 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
get some trans fluid and pour it in carb with engine running till it smokes real good then por fast enough to stall it !
let sit for 30 min.
put 3 oz. in fuel tank
this will free stickey valves !
start and drive
Re: 440 backfires [Re: calrobb2000] #2973809
10/13/21 08:44 AM
10/13/21 08:44 AM
420SIX Offline OP
420SIX  Offline OP
Worth a try..Easier than pulling the heads
Re: 440 backfires [Re: 420SIX] #2973810
10/13/21 08:47 AM
10/13/21 08:47 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Friend just went through this and found a bad plug wire!
1969 Hemi Roadrunner 2nd owner
Re: 440 backfires [Re: 420SIX] #2973819
10/13/21 09:27 AM
10/13/21 09:27 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Put a vacuum gauge on it. low steady vacuum is a problem, or something that affects all the cylinders, worn timing chain, lean fuel etc. . If the needle bounces it is a valvetrain issue, broken valve spring flat cam etc. If it has normal vacuum then it may be electrical.
https://m.roadkillcustoms.com/diagnose-common-engine-problems-vacuum-gauge/#:~:text=Vacuum%20Gauge%20Engine%20Condition%20Indicators%20%20%20,Confirms%20worn%20rings.%20%2012%20more%20rows%20
Re: 440 backfires [Re: jwb123] #2973829
10/13/21 10:26 AM
10/13/21 10:26 AM
So Near, Yet So Far
topside Online content
topside  Online Content
So Near, Yet So Far
Has anyone worked on it recently ?
Had something like that when 2 wires were crossed (to wrong spark plugs) on right bank.
Think it was #4 and #6.
Verify dist cap & rotor are healthy & clean (carbon tracking).
Re: 440 backfires [Re: topside] #2973887
10/13/21 11:45 AM
10/13/21 11:45 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Counterclockwise
Re: 440 backfires [Re: FastmOp] #2973888
10/13/21 11:56 AM
10/13/21 11:56 AM
West Virginia
B1Frank Offline
B1Frank  Offline
West Virginia
I had one 440 do that....turned out to be a cam with a bad lobe, ...that was it.
Re: 440 backfires [Re: FastmOp] #2973889
10/13/21 12:00 PM
10/13/21 12:00 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Probably been checked, but make sure one advance weight isn’t stuck. Will backfire on decel.
Re: 440 backfires [Re: Leigh] #2974109
10/13/21 08:33 PM
10/13/21 08:33 PM
Alberta
440_Offroader Offline
Alberta
Fouled spark plug?
