For Sale - Small Block Engine - 4th Quarter #2969190
10/01/21 12:24 PM
10/01/21 12:24 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts] #2969244
10/01/21 01:37 PM
10/01/21 01:37 PM
MI
6PAX Offline
6PAX  Offline
MI
Used chrome thermostat housing. $5
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner flexible hose. $20
Original Cal Custom 14" finned aluminum air cleaner with filter. $100
1970 Style single nipple oil breather with hose. $30
New 12" oval 4 barrel finned aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $60
Original Cal Custom 9" finned air cleaner top and base. $75
AC alternator bracket from a mid 70s 360. $10
Good used intake to water pump crossover hose from a mid 70s 360 with AC. $5
Mr. Gasket 1" thick carb spacer. $15
Small block passenger side biscuit motor mount bracket. $30
137 New Spectre brand radiator and heater hose clamp covers. Some chrome, some red and some blue anodized. Various sizes. $50 for the lot.
Two 318 driver side spool motor mounts pt#3642811. One is used and one is NOS. $20 for the used. $35 for the NOS.
New Cloyes C-3028 small block Mopar timing chain. $25
Brand new in the box Edelbrock 1403 500 cfm carb. with electric choke. Includes gasket, wiring, instructional dvd. $350
5 Blade radiator cooling fan pt. #4266059. $40
14" Aluminum air cleaner with large Mopar logo on the lid. $80
Carb. throttle linkage stud. $10
Vintage Cal Custom scoop style air cleaner. Includes often missing matching wingnut. $300
Alternator date coded 1965. $35
Stewart Warner mechanical oil pressure and water temp gauges. I recently took these out of my car and they worked fine. $60
Email: gt340 @ yahoo.com
1970 Carter AVS 340 Automatic with ECS [Re: moparts] #2969330
10/01/21 04:40 PM
10/01/21 04:40 PM
Northwest Indiana
19Coronet66 Offline
19Coronet66  Offline
Northwest Indiana
For sale is a rebuilt 1970 Carter AVS. Carb number is 4937s with a date code of M3. Application is for a 340 with automatic transmission and ECS. Has the correct Delco Remy idle solenoid. Carb has been sitting on a shelf since the late 80's. Put a kit in it along with a new choke pull off, a new insulated base gasket (not pictured) new gasket for the air cleaner, new jets & metering rods and orange springs along with new flat covers for the metering rods & pistons. Carb has been converted to the 2 step metering rods. It's been set up like a 650 CFM Edelbrock AVS2. Will include the other new 4 sets of springs to tune to your needs. $225 plus shipping.
PM if interested
DSC00575 (2).JPG (567 downloads)
DSC00579 (2).JPG (568 downloads)
DSC00580 (2).JPG (566 downloads)
DSC00582 (2).JPG (567 downloads)
Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts] #2969660
10/02/21 03:33 PM
10/02/21 03:33 PM
IA
TLT Offline
TLT  Offline
IA
Edelbrock 318 Streetmaster aluminum intake. Low rise single plane with 318 sized ports and dual carb flange. Older design, but worked great on my mild 318. Great for a budget build 318 street car and even works good on a near stock 360. Threads good, overall nice condition. Having issues with my pictures, will email better ones if interested. $80 + shipping. Cash-App, Zelle, or mailed payments accepted, email tlt85360@gmail ifinterested. Thanks!
Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts] #2971619
10/07/21 08:00 AM
10/07/21 08:00 AM
IA
TLT Offline
TLT  Offline
IA
Comp cams hydraulic flat tappet camshaft, new in box with paperwork and lube. Current price is $180+, I will sell for $90 + shipping.
I can email pictures if interested, my files are too big to fit on here.
260-268 advertised duration
212-218 duration @ .050"
.444" valve lift
108 lobe sep
Part# 20-306-4
great street performance cam.
New in box hydraulic lifters Engine-Tech 2011. $40 + S/H
68-73 340 throttle bracket. $20 + S/H
FBO distributor limiting plate, new in package, $25 shipped to your door in lower 48 states.
billet aluminum 727 filter spacer, $15 + S/H
Will trade all 5 above items for a good used Edelbrock Performer intake manifold, Weiand action plus, etc. for small block or a good used 340 square bore intake manifold for AVS.
Thanks!
Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts] #2971776
10/07/21 05:10 PM
10/07/21 05:10 PM
IA
TLT Offline
TLT  Offline
IA
Hughes SB rocker hold down stud kit #7440, new in box, never used, sells for $99.95, you can have it for $50 + shipping.
Email me at tlt85360@gmail for more info and pictures.
SALE PENDING,
thanks Moparts!
Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts] #2972182
10/08/21 07:36 PM
10/08/21 07:36 PM
michigan
myduster400 Offline
myduster400  Offline
michigan
Local pick up ONLY. Livonia Mi area
All parts are used unless noted. Email me for questions or pics...............Myduster400@yahoo.com
Edelbrock streetmaster 318----------------------$50
Oil pan and pick up---------------------------------$25
Assorted freeze plugs-----------------------------$5
Aluminum 2" spacer--------------------------------------$50
3 Holley elec. fuel pumps (blue) & 2 regulators-----$100
Russell fuel filter---------------------------------------------$10
Top Gun nitous bottle, mounts, hose & selinoid------$50
New Edelbrock Chrysler thot A/T lever (1481)-------$5
New Edelbrock Chrysler A/T 1/4" rod (8003)----------$5
Lokar throttle cable-------------------------------------------$15
2" Sunpro oil gauge------------------------------------------$5
48" 4ga battery cable----------------------------------------$5
Aeroquip Fittings
3 FBM1033 new in package------------------------------$15ea
1 FBM1033 used--------------------------------------------$10
2 FBM1023 new in package------------------------------$15ea
! FBM1023 used---------------------------------------------$10
Assorted Aeroquip fittings---------------------------------$25
Assorted lengths of stainless steel braided hoses--$50
Small Block Rocker Arm Shafts for Adjustable Rockers - New [Re: myduster400] #2972648
10/10/21 11:42 AM
10/10/21 11:42 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a new set of small block Mopar rocker arm shafts for LA type cylinder heads. These shafts are made here in the U.S.. They are made from thick induction hardened steel. They feature banana groves and oiling holes that are positioned for the loading of mechanical rocker arms. These shafts have screw in end plugs for inspection and easy cleaning, inspection or if desired to plumb in an oil line. These are drilled on center for 5/16” hold down bolts and are for use with stock small block Mopar heads (273, 318, 340 & 360) or aftermarket cylinder heads including Edelbrock RPM, Indy LAX or other similar shaft mounted cylinder heads where mechanical rocker arms are being used. These are not intended for W2 or W5 heads that use offset drilled shafts and stands.
These shafts will provide the proper oiling to high load areas for adjustable iron and aluminum adjustable rocker arms to minimize wear and maximize performance and parts life. They are far thicker and stiffer than stock or may aftermarket shafts to minimize flex with stiffer aftermarket valve springs.
Price is $180 for the pair shipped within the lower 48 states. I can ship internationally for the additional shipping cost.
Contact procketrichard@hotmail.com for more information and pictures.
SB Shafts Pic 6.jpg (222 downloads)
Mopar Performance Small Block Pistons - New Incomplete Sets [Re: Rocket] #2972650
10/10/21 11:44 AM
10/10/21 11:44 AM
CT
Rocket Offline
Rocket  Offline
CT
I have 12 new Mopar Performance forged flat top pistons and pins. There are 3 different part numbers. There is not one complete set. Here is what I have.
P4876976 – Quantity of 6. Specs are 4.060” bore & ~ 1.67” compression height. These pistons are for a 0.060” overbore 360 with the stock stroke crankshaft or a 0.020” overbore 340 using a 3.58 stroke crankshaft.
Price for the 6 new forged pistons is $350 shipped.
P4876978 – Quantity of 4. Specs are 4.030” bore and ~ 1.67” compression height, These pistons are for a 0.030” overbore 360 with the stock stroke crankshaft
Price for the 4 new forged pistons is $220 plus shipped.
P5007413 – Quantity of 2. Specs are 4.030” bore and ~ 1.47” compression height, These pistons are for a 0.030” overbore 360 with a 4.00” stroke crankshaft.
Price for the 2 new forged pistons is $120 shipped.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
Small Block KB 745 Forged Pistons 4.030 Bore for 4” stroke [Re: Rocket] #2972652
10/10/21 11:46 AM
10/10/21 11:46 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a nice used set of Keith Black dished Forged pistons and pins for a 4.000” stroke crankshaft. Pistons were used for one summer as a mild street build. Engine was rebuilt the following summer into a bracket racing focused application including new pistons, new cam, …
Pistons were used for ~ 500 street miles. They have been fully cleaned and the skirts lightly glass beaded. One piston had some skirt scuffing and has been replaced with a new piston.
Piston specs are as follows:
Bore 4.030 in.
Stroke: 4.000 in.
Rod Length: 6.123 in.
Piston Style: Step head, with two valve reliefs
Piston Material: Forged aluminum
Compression Height (in.): 1.465 in.
Piston Head Volume (cc): +20.50cc
Wrist Pin Style: Press-fit or floating
Pin Diameter (in.): 0.984 in.
Piston Ring Thickness: 1/16 in. x 1/16 in. x 3/16 in.
Compression ratio with a 65CC chamber, head gasket compressed thickness of 0.040 and installed at 0.0 deck height will be ~ 9.90 to one.
Price is $450 plus shipping cost.
1990 Dodge Ram 318 Engine - $300 [Re: moparts] #2973643
10/12/21 06:57 PM
10/12/21 06:57 PM
Danville, NH
Mopar_Mike Offline
Mopar_Mike  Offline
Danville, NH
1990 (I believe) Dodge Ram 318 V8 Engine. Got this with a few other items and I have no need for it. Was told it ran great but truck was rusted out. Selling as-is. I would think its worth my price in parts. $300
fas141@comcast.net
RS23L7 440 4-Speed
RS27L7 440 727
WS23L7 484 Hemi - 727 - Dana 4.10
Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts] #2974941
10/16/21 12:00 PM
10/16/21 12:00 PM
thebigO Offline
thebigO  Offline
1970 340 4-bbl 4-Speed Dual Point Distributor
$550 + shipping
Free delivery to Garlits (Nov 2021) with pre-payment.
Mike (813) 781-7489
Re: For Sale - Small Block Engine - 4th Quarter [Re: moparts] #2975101
10/16/21 06:46 PM
10/16/21 06:46 PM
San Jose,CA
migsBIG Offline
migsBIG  Offline
San Jose,CA
Holley street Dominator intake. Very nice and ready to bolt on.
$180 + shipping. PayPal only.
