Big Block PS pulleys and brackets..4X4 truck #2972940
10/11/21 09:52 AM
10/11/21 09:52 AM
Finally a HUSKER again
Moparnut426 Offline OP
OK, finally getting my big block stuck into my ol pickup. starter mocking it all up this weekend, Ive got a box of lower pulleys, and upper pulleys. nothing lines up crank to water pump. I found a dropped out 383 from a 70s C body. Im fine with using the car PS pump, and just use car brackets and pump, but Im curious how many different pulleys were optional? Ive got 6 different lower pulleys, and nothing lines up with anything. Ive got 3 different water pump pulleys. Im going to use the alternator brackets, and a 2 groove pulley alternator.
Re: Big Block PS pulleys and brackets..4X4 truck [Re: Moparnut426] #2972976
10/11/21 11:27 AM
10/11/21 11:27 AM
Alberta
440_Offroader Offline
Alberta
Do you have an aftermarket damper on the engine? I have a cast crank 400 and 440 with 2 groove pulleys and everything lines up, but it's all as built factory wise. I have a 4 groove pulley but doesn't seem to fit into the 440 cast crank damper. Not sure what the 4 groove is off of though.
Re: Big Block PS pulleys and brackets..4X4 truck [Re: 440_Offroader] #2972988
10/11/21 11:47 AM
10/11/21 11:47 AM
The damper is from Mancinni, the " pro street" I have it on several other engines without issues, I called Bouchelin performance, they gave me a measurement, 4 9/32" from face of water pump flange to the face of the damper hub, so Im gonna check that tonight, and hopefully its correct and Ill go from there and either buy all new stuff from them, or just go rob the parts of the 383 at a buddies place and leave a 30 pack of Bush Light in place of the parts LOL
Re: Big Block PS pulleys and brackets..4X4 truck [Re: Moparnut426] #2973028
10/11/21 01:06 PM
10/11/21 01:06 PM
Alberta
Alberta
That seems really odd that so many pulleys don't line up. Perhaps the damper isn't on all the way?
Re: Big Block PS pulleys and brackets..4X4 truck [Re: 440_Offroader] #2973037
10/11/21 01:33 PM
10/11/21 01:33 PM
I checked that already compared to my 434 on the other stand, its the same.
Re: Big Block PS pulleys and brackets..4X4 truck [Re: Moparnut426] #2973187
10/11/21 10:10 PM
10/11/21 10:10 PM
IL
furious70 Offline
furious70  Offline
IL
The simplest answer is always to rob a full set of pulleys with the right accessories for your needs from an engine. There are so many variations over the years that if you have to start mixing and matching, well, you'll be mixing and matching. We've got a big pile of pulleys from 30yrs of dismantling so we just start experimenting...
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Big Block PS pulleys and brackets..4X4 truck [Re: furious70] #2973300
10/12/21 08:29 AM
10/12/21 08:29 AM
Exactly what Im ending up doing. I meaured the distance from damper hub to water pump and its all ok.
