Can I use hose / clamps for pwr steering? #2972299
10/09/21 07:43 AM
10/09/21 07:43 AM
BDW Offline OP
BDW  Offline OP
I have a mismatched set of parts, and can't find the correct hose for the pressure side hose from pump to gear.
Wondering if I can cut the end off and connect another end with a short piece of hose and clamps.
I know the pressure is ~1000 psi, will this work?
Going from a 76 Saginaw box that needs a 0.3125 male with o-ring to a Borgeson box that needs 0.375 female flare
Can't find a stock hose in this configuration. Just need a short term solution before changing out the whole set-up.
Thx
Re: Can I use hose / clamps for pwr steering? [Re: BDW] #2972300
10/09/21 08:04 AM
10/09/21 08:04 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
That would be a hard no.
If the hose you are using has the female flare and the box requires an O ring fitting, there is a fitting that will solve that for you.
Kevin
Re: Can I use hose / clamps for pwr steering? [Re: Twostick] #2972314
10/09/21 09:15 AM
10/09/21 09:15 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Kevin
What would probably be useful is a link to the part rather than a picture.
Re: Can I use hose / clamps for pwr steering? [Re: BDW] #2972330
10/09/21 09:55 AM
10/09/21 09:55 AM
Andrewh Offline
Andrewh  Offline
also if you are still stuck, find a local semi truck shop. they can usually make hoses. I had one make a hose out of the 2 I had so I could use the newer ps pump and my old steering box for the high pressure side.
5.9 mag motor to a 65 coronet.
Re: Can I use hose / clamps for pwr steering? [Re: Andrewh] #2972338
10/09/21 10:27 AM
10/09/21 10:27 AM
BDW Offline OP
BDW  Offline OP
More info, don’t have enough room for adapter on pump, so I need something that goes from hose to Borgeson adapter, or from hose to box without adapter.
I believe the Borgeson is 1.5 x 16 whatever that means
Re: Can I use hose / clamps for pwr steering? [Re: BDW] #2972353
10/09/21 11:10 AM
10/09/21 11:10 AM
Guitar Jones Offline
Search power steering adapters at Summit.
power steering adapters.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Can I use hose / clamps for pwr steering? [Re: Guitar Jones] #2972395
10/09/21 01:17 PM
10/09/21 01:17 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Pressure side would be effective at rust-proofing everything underhood...
Not sure of Rock Auto & etc would have the hose & line, or something you could use.
Re: Can I use hose / clamps for pwr steering? [Re: topside] #2972433
10/09/21 04:08 PM
10/09/21 04:08 PM
BDW Offline OP
BDW  Offline OP
Nothing is ever easy is it...........
The crappy part is I just need this to work for a couple of months.
Doing the Borgeson upgrade in preparation of swapping in a Gen3 motor.
Wanted to be able to drive the car and check out the steering while I gather parts.
All the steering hoses will need to be redone again.
Looks like I'll see if I can find a local place to swap/convert my old hose to fit.
Just hate throwing money at this, but I'm sure a couple of months will be longer.......
Re: Can I use hose / clamps for pwr steering? [Re: BDW] #2972475
10/09/21 06:59 PM
10/09/21 06:59 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I'm confused. Do you need to adapt the pump end or the box end? If there is no room at the pump end, use the hose that fits the pump and adapt the box end.
Kevin
Re: Can I use hose / clamps for pwr steering? [Re: BDW] #2972479
10/09/21 07:21 PM
10/09/21 07:21 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
BDW - where are you in Florida? I can give you a reference or two of places to go that make hydraulic hose assemblies. The suggestion earlier about going to a heavy truck parts place is the ticket. I'm in this industry, & there are some great places all over Florida.
Re: Can I use hose / clamps for pwr steering? [Re: Sunroofcuda] #2972512
10/09/21 08:52 PM
10/09/21 08:52 PM
BDW Offline OP
BDW  Offline OP
I'm in Melbourne, 1 hr east of Orlando
Re: Can I use hose / clamps for pwr steering? [Re: BDW] #2972516
10/09/21 08:57 PM
10/09/21 08:57 PM
BDW Offline OP
BDW  Offline OP
There might be another option, the plug that screws into the pump housing Is removable.
Can I just replace this receptacle with an older version that matches the hose end?
When I say plug, there's a sleeve that screws in to the Saginaw housing, then the hose screws into that.
I guess I have a 76 up version that takes a lip with o-ring.
If I could find a 70 version that accepts the inverted flare style?
Screenshot_20211009-210502_kindlephoto-25776988.pngScreenshot_20211009-210808_kindlephoto-26012985.pngScreenshot_20211009-210829_kindlephoto-25983461.png
Re: Can I use hose / clamps for pwr steering? [Re: BDW] #2972550
10/09/21 09:57 PM
10/09/21 09:57 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Check out places in Florida here: https://vipar.com/distributors (look for places that list parts and services)
Also check out any CAT dealers by you. LOTS of hydraulic repairs on the big equipment.
Re: Can I use hose / clamps for pwr steering? [Re: BDW] #2972560
10/09/21 11:08 PM
10/09/21 11:08 PM
Boise
Moparteacher Offline
Boise
The female hole in the P.S. box is 16 millimeters in diameter. The thread pitch is 1.5 millimeters distance per thread. The large side of the adapter, pictured, threads into the ps box. The Borgeson box requires an adapter that either seals with an inverted flare at the bottom of the hole, or a flanged gasket/o-ring at the mounting surface.
Take a close look at the parts required at the Borgeson website, and then take a look at the adapters they offer. Keep in mind the adapter you require, or a pressure hose, might be found at a wrecking yard. The ps box that Borgeson uses comes from the Jeep Cherokee, or so I'm led to believe.
Easiest thing to do would be to aquire a hose that fits the box and a hose that fits the pump, install both, lay them next to each other in the car, mark them where they need to go together (include the clocking) and take the hoses to a hydraulic hose or Parker fitting store and have them biold a hose, or slice them together with the proper fitting.
Re: Can I use hose / clamps for pwr steering? [Re: BDW] #2972562
10/09/21 11:14 PM
10/09/21 11:14 PM
Boise
Boise
Yes, but pay attention to the size of the internal hole. It determines the flow rate of the pump. Too low of a flow rate for that ps box and it'll let you know.
Re: Can I use hose / clamps for pwr steering? [Re: Moparteacher] #2972662
10/10/21 12:28 PM
10/10/21 12:28 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
As was mentioned find a hydraulic hose shop around you and see if they have anything to solve the problem. Keep in mind if you need something that is not made you can cut two fitting in half and weld them together if a adapter is not available or you have space/clearance issues.
Re: Can I use hose / clamps for pwr steering? [Re: BDW] #2972862
10/10/21 09:57 PM
10/10/21 09:57 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Can't one of these places make one up to match what you need or combine the mis-match into a single function unit?
https://www.pirtekusa.com/locations/space-coast/
https://www.industrynet.com/listing/1164534/ecor-industries-inc
http://www.spacecoasthp.com/
Re: Can I use hose / clamps for pwr steering? [Re: TC@HP2] #2972892
10/10/21 11:37 PM
10/10/21 11:37 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Give Mancini a call? I got the hose and fittings from them to make this. Only thing they didn't have was the 16mm inverted flare to -6AN for the Borgeson box - got that from Summit. Lines are PTFE and the fittings are specific to that type of hose. I think They're Fragola Real Street.
Re: Can I use hose / clamps for pwr steering? [Re: BDW] #2972903
10/11/21 02:26 AM
10/11/21 02:26 AM
hooziewhatsit Offline
That's what I plan to do if/when I get the mag engine & power steering pump swapped into my 72 pickup.
I got that plug from the junkyard from a similar year ('72), and it looks identical to the one I took out of the '99 magnum PS pump (except for the hose threads, of course). So now I should be able to use my original '72 ps hose, with the magnum ps pump.
There should be a shuttle/spool behind it, with shims to set the pump pressure.
Re: Can I use hose / clamps for pwr steering? [Re: Andrewh] #2972993
10/11/21 11:56 AM
10/11/21 11:56 AM
IMGTX Offline
IMGTX  Offline
Beat me too it. My local NAPA can make hoses too.
