Re: 400-451 crank questions
[Re: hemienvy]
#2972716
10/10/21 02:58 PM
10/10/21 02:58 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
I measure one cylinder on each side of the 1971 block, I can't get a accurate measurement due to the dial calipers not fitting well in the cylinders but it looks like between 6.7 and 6.8 on the length of the cylinder walls on that block. I have to take the heads off of the 1970 block later this afternoon and I should be able to measure it better on the engine stand instead of on a wooden dolly like the 1971 block is on now I don't remember the differences in the low deck and RB block deck heights but it should be available on here some where Don't forget about the main bore size differences also
[Re: hemienvy]
#2972841
10/10/21 08:39 PM
10/10/21 08:39 PM
Cab_Burge
Probably a after market top fuel aluminum block, Milidon , TFX, KB or ? Seems to me that they used long stroke cranks along time ago
[Re: dodgefarmer]
#2973064
10/11/21 03:14 PM
10/11/21 03:14 PM
Posts: 31,068 Oregon
AndyF
It's been a while since I've built a stroked low deck , but IIRC it was not so much counterweight to block clearance as counterweight to piston pin boss clearance.
HTH Randy That depends on the rod length and the piston design.
[Re: AndyF]
#2973186
10/11/21 10:04 PM
10/11/21 10:04 PM
Posts: 1,072 The Sunny Shuswap
dodgefarmer
The Sunny Shuswap
HTH Randy That depends on the rod length and the piston design. Quite true. Built 12+ yrs. ago. KB 215 @ 1.722 CH and a 6.358 rod. Randy
[Re: AndyF]
#2973271
10/12/21 01:35 AM
10/12/21 01:35 AM
Posts: 610 Boise
Moparteacher
Boise
The first one (and the last) was started in the early 90's with inexpensive parts I hade purchased on the cheap. 66" 383 block, polished the factory 383 rods, TRW 2315F-030 pistons that I cut down .2" off the top on an old Wynona head milling machine. The underside of the pistons were trimmed with a carbide bit and die grinder. The crank mains were turned down to 383 size and the counter weights were cut to clear the block....THEN I had it balanced. Aaaaand $1000 in and Mallory metal later it all fit together. It's currently apart getting freshened. I think there's 6 or 7 sticks of heavy metal in the crank counter weights. Live and learn.
Since the original build a second set of TRW slugs have been made with valve notches, shortened pins, and piston pin locking rings to accommodate Eagle 383 rods added. I still haven't learned. It would have been cheaper to buy stroker pistons but that is a common mistake. I've seen lots of people try to build cheap motors who end up with stuff that doesn't work. Yes, but stroker pistons and stroker cranks were not shelf items back in the late 80's and early 90's when I started that project. Typical kid with big ambitions, dreams of powerful engines, and little money. Arias Pistons was the custom piston to get. May as well have been a million dollars. Unattainable at less than $1000 a month income. TRW slugs worked out really well for $100 and I had access to a milling machine. Crank was more than I anticipated. Took a couple of years to get it together back then. I cut the pistons in 86 or 87. Crank in was done in 90 or 91. OK, I just counted. 12 sticks of Mallory, of different diameters. OK, OK, I just measured. Counterweight diameter 6.874" on a factory 69 440 forged crank. Needed to clear the short 383 rods. Never occurred to me to run a 440 rod. It all works. Unconventional, but it works.
