Re: 400-451 crank questions [Re: Cab_Burge] #2972678
10/10/21 01:10 PM
10/10/21 01:10 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Cab, Yes that would be great, just to the nearest 1/16" or so, it's to compare to the low deck blocks.
Re: 400-451 crank questions [Re: hemienvy] #2972716
10/10/21 02:58 PM
10/10/21 02:58 PM
I measure one cylinder on each side of the 1971 block, I can't get a accurate measurement due to the dial calipers not fitting well in the cylinders but it looks like between 6.7 and 6.8 on the length of the cylinder walls on that block.
I have to take the heads off of the 1970 block later this afternoon and I should be able to measure it better on the engine stand instead of on a wooden dolly like the 1971 block is on now luck
I don't remember the differences in the low deck and RB block deck heights but it should be available on here some where scope
Don't forget about the main bore size differences also scope
Re: 400-451 crank questions [Re: hemienvy] #2972740
10/10/21 04:08 PM
10/10/21 04:08 PM
The 1970 block #8 cylinder on the motor mount side looks like 6.755 long from top of the block to the bottom of the cylinder wall. I think this block is stock, the 1971 motor had a aftermarket timing set and a set of -.010 rod and main bearings in it so who know on the deck heights confused
IHTHs, back to watching drag racing in TX boogie grin
Re: 400-451 crank questions [Re: Cab_Burge] #2972750
10/10/21 04:31 PM
10/10/21 04:31 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Cab, Thanks ! Big help.
So 10.725 - 6.755 = 3.97, this is the radius of the crankbox so the crank counterweights would have to be less than 7.94" diameter.
And they are, 440 counterweights are 7.500 diameter.
3.97 compares to 3.75 on a 383 block.
So most of the increased deck height on a 440 goes toward a longer bore length.
The crankbox radius on a 440 is less than 1/4" bigger than the 383.
Long ago I came across an aftermarket billet crank that would not fit in a 440 block, the counterweights hit.
I can only wonder what block it came out of.
Re: 400-451 crank questions [Re: hemienvy] #2972841
10/10/21 08:39 PM
10/10/21 08:39 PM
Probably a after market top fuel aluminum block, Milidon , TFX, KB or ? twocents scope
Seems to me that they used long stroke cranks along time ago
Re: 400-451 crank questions [Re: Cab_Burge] #2973029
10/11/21 01:08 PM
10/11/21 01:08 PM
The Sunny Shuswap
dodgefarmer Offline
dodgefarmer  Offline
The Sunny Shuswap
It's been a while since I've built a stroked low deck , but IIRC it was not so much counterweight to block clearance as counterweight to piston pin boss clearance.
HTH
Randy
Re: 400-451 crank questions [Re: dodgefarmer] #2973064
10/11/21 03:14 PM
10/11/21 03:14 PM
AndyF Offline
AndyF  Offline
HTH
Randy
That depends on the rod length and the piston design.
Re: 400-451 crank questions [Re: AndyF] #2973186
10/11/21 10:04 PM
10/11/21 10:04 PM
The Sunny Shuswap
dodgefarmer Offline
dodgefarmer  Offline
The Sunny Shuswap
HTH
Randy
Quite true. Built 12+ yrs. ago. KB 215 @ 1.722 CH and a 6.358 rod.
Randy
Re: 400-451 crank questions [Re: dodgefarmer] #2973198
10/11/21 10:49 PM
10/11/21 10:49 PM
AndyF Offline
AndyF  Offline
A 6.70 inch Chevy rod keeps the piston away from the crank and shaves a bunch of weight off the piston.
Re: 400-451 crank questions [Re: AndyF] #2973271
10/12/21 01:35 AM
10/12/21 01:35 AM
Boise
Moparteacher Offline
Boise
Originally Posted by Moparteacher
The first one (and the last) was started in the early 90's with inexpensive parts I hade purchased on the cheap. 66" 383 block, polished the factory 383 rods, TRW 2315F-030 pistons that I cut down .2" off the top on an old Wynona head milling machine. The underside of the pistons were trimmed with a carbide bit and die grinder. The crank mains were turned down to 383 size and the counter weights were cut to clear the block....THEN I had it balanced. Aaaaand $1000 in and Mallory metal later it all fit together. It's currently apart getting freshened. I think there's 6 or 7 sticks of heavy metal in the crank counter weights. Live and learn.
Since the original build a second set of TRW slugs have been made with valve notches, shortened pins, and piston pin locking rings to accommodate Eagle 383 rods added. I still haven't learned.
It would have been cheaper to buy stroker pistons but that is a common mistake. I've seen lots of people try to build cheap motors who end up with stuff that doesn't work.
Yes, but stroker pistons and stroker cranks were not shelf items back in the late 80's and early 90's when I started that project. Typical kid with big ambitions, dreams of powerful engines, and little money. Arias Pistons was the custom piston to get. May as well have been a million dollars. Unattainable at less than
$1000 a month income. TRW slugs worked out really well for $100 and I had access to a milling machine. Crank was more than I anticipated. Took a couple of years to get it together back then. I cut the pistons in 86 or 87. Crank in was done in 90 or 91.
OK, I just counted. 12 sticks of Mallory, of different diameters.
OK, OK, I just measured. Counterweight diameter 6.874" on a factory 69 440 forged crank. Needed to clear the short 383 rods. Never occurred to me to run a 440 rod. It all works. Unconventional, but it works.
Re: 400-451 crank questions [Re: AndyF] #2973399
10/12/21 12:43 PM
10/12/21 12:43 PM
A 7.100 long BB Chevy type rod works even better on the 3.91 stroke and shorter motors up scope twocents
Re: 400-451 crank questions [Re: Cab_Burge] #2973792
10/13/21 07:34 AM
10/13/21 07:34 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
7.100 rod and 3.91 stroke won't fit in a low deck. There is no piston that thin, you would need a piston with a compression height of .92" I don't think you would even find one for 3.75 stroke and a 7.100 (1.002).
