Rocker shaft shimming
#2971182
10/05/21 10:39 PM
10/05/21 10:39 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
What are the reasons to shim the rocker shafts? Is it for adjusting the rocker to valve tip contact point/angle or is it for other reasons? Seems odd that such a small shim could actually help anything.Thanks. Copper
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
Re: Rocker shaft shimming
[Re: Copper Dart]
#2971210
10/06/21 12:48 AM
10/06/21 12:48 AM
Posts: 30,989 Oregon
AndyF
What are the reasons to shim the rocker shafts? Is it for adjusting the rocker to valve tip contact point/angle or is it for other reasons? Seems odd that such a small shim could actually help anything.Thanks. Copper It is a hack (or a bandaid if you prefer) from the old days. Most likely a waste of time for the parts in the picture since there wouldn't be much point in trying to correct the geometry when you have those loosy goosy stamped rocker arms floating around on the shaft. I'll attach an "old school" picture that makes a little more sense. This was an engine I worked on years ago where the customer wanted to run 906 heads and he wanted to make some RPM. We used a nodular rocker arm and then used blocks to adjust the geometry in order to narrow the wear pattern on the valve tip. It was a bunch of work and didn't really accomplish anything. Once I learned this lesson the hard way I stopped worrying about it but I had to prove to myself that it didn't matter before I could move on.
[Re: AndyF]
#2971213
10/06/21 01:53 AM
10/06/21 01:53 AM
Posts: 707 California
BigDaddy440
California
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: calrobb2000]
#2971217
10/06/21 03:07 AM
10/06/21 03:07 AM
Posts: 43,097 Bend,OR USA
Cab_Burge
hi those shims are to keep the push rods from compressing the plunger too far into hyd lifters when heads and block have been milled with stock rocker assembly ! NOT .020 " plunger depth is the goal ! If you want to use stock type rocker arms ( I won't ) your going to have to use custom length pushrods to get the preload you want on the lifter cups. Don't be surprised if you need several different length pushrods to get all of the preload exactly the same We use to have to buy and use adjustable pushrods on all our builds that didn't come with adjustable rocker arms on the motor to start with to use solid lifters The other option is adjustable rockers with the proper length custom pushrod
[Re: B1MAXX]
#2971240
10/06/21 08:18 AM
10/06/21 08:18 AM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
hi
X2 To lessen valve float for a few more rpm on a hydraulic. X3
[Re: Copper Dart]
#2971366
10/06/21 02:58 PM
10/06/21 02:58 PM
Posts: 4,205 New York
polyspheric
New York
"Correcting" the rocker geometry is a nice idea (and not significant with small errors). The real argument is not to correct them, but what is correct? Depends on what you're trying to do. 1. reduce the side thrust vector 2. create the largest "window area under the curve" of valve curtain area 3. move the window closer to a specific point of valve lift 4. move the window closer to a specific point of engine vacuum 5. achieve "mid lift", in which the stem is at 90 degrees to a line through the shaft and roller axle centers @ 50% lift
No, all of these cannot occur simultaneously.
Boffin Emeritus
[Re: polyspheric]
#2971372
10/06/21 03:12 PM
10/06/21 03:12 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
No, all of these cannot occur simultaneously. Making the valvetrain stable & not go NUTS is what matters
[Re: CSK]
#2971387
10/06/21 03:41 PM
10/06/21 03:41 PM
polyspheric
New York
True, but that includes limits of size, spring pressure, stiffness (resistance to bending), etc. A perfectly aligned set of shaft rockers on a 1/2" shaft will flop around like a palm tree in a hurricane.
Boffin Emeritus
[Re: BigDaddy440]
#2971389
10/06/21 03:46 PM
10/06/21 03:46 PM
polyspheric
New York
Thanks for posting. Please note the "crescent" shape of the B3 shims; this is extremely important. A simple curved piece of constant thickness is not only ineffective but fragile. The B3 piece shown is what you want.
Boffin Emeritus
[Re: polyspheric]
#2971400
10/06/21 04:00 PM
10/06/21 04:00 PM
CSK
Pattison Texas
Thanks for posting. Please note the "crescent" shape of the B3 shims; this is extremely important. A simple curved piece of constant thickness is not only ineffective but fragile. The B3 piece shown is what you want. & yes I have B3's correction spacers on my junker
[Re: Uberpube]
#2971870
10/07/21 09:04 PM
10/07/21 09:04 PM
polyspheric
New York
The B3 price is not just for small bits of metal, but includes all the R&D he put into it. You're buying his engineering.
Boffin Emeritus
