2000-2001 Ram 1500 brake prop valve options?? #2970891
10/05/21 12:34 PM
10/05/21 12:34 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Anyone know of a source to replace or even rebuild a brake proportioning valve on a 2001 Ram 1500 2wd ?
OE part number is 5015419aa
Its no longer avail via Mopar and NO ONE shows one in stock .
Have a truck with a brake fluid leak and no parts to fix it
Re: 2000-2001 Ram 1500 brake prop valve options?? [Re: gtx6970] #2970920
10/05/21 01:11 PM
10/05/21 01:11 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Could this one linky be a possible solution?
https://www.ebay.com/itm/324714890647?
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 2000-2001 Ram 1500 brake prop valve options?? [Re: 3hundred] #2970946
10/05/21 02:01 PM
10/05/21 02:01 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Ive found a few used ones. The issue is , have 2 trucks with valves leaking to some degree. Would prefer new or rebuild the ones we have.
These trucks are going to stay in service for at least a few more years. So used is last resort in fear they start to leak as well in short order. Then Im in the same boat
Re: 2000-2001 Ram 1500 brake prop valve options?? [Re: gtx6970] #2971225
10/06/21 06:01 AM
10/06/21 06:01 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
They typically just have o rings for seals. Take one apart and clean it, fit new rings and try it.
Alternatively, Ditch it and just put an adjustable one in the rear line.
Angry white pureblood male
Re: 2000-2001 Ram 1500 brake prop valve options?? [Re: gtx6970] #2971675
10/07/21 12:14 PM
10/07/21 12:14 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Common sense is a flower that does not grow in everybody's garden
Re: 2000-2001 Ram 1500 brake prop valve options?? [Re: ruderunner] #2972682
10/10/21 01:17 PM
10/10/21 01:17 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
This particular truck is a spare , rarely used unit.
Once I can get my hands on it , I guess I will open the valve up and see if its repairable / new O rings will fix it . As Ive looked for days and found nothing as far as a new replacement or rebuild kit
What type material is brake fluid safe if I decided to get O rings ?
